<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-1021.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</guid>
										<title>1988 - 1992 Corvette: Service Bulletin: A/C Compressor Sealing Washer (New Design)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</guid>
										<title>1990 Corvette: Service Bulletin: L98 and LT5: Revised Air Conditioning Control Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</guid>
										<title>2005 Corvette: GM TechLink: HVAC Module Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</guid>
										<title>1991 Corvette: Service Bulletin: Loss of Heat/Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-no-heat-a-c-control-unit-725.html</guid>
										<title>1984 Corvette: Service Bulletin: No Heat - A/C Control Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-no-heat-a-c-control-unit-725.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</guid>
										<title>1986 - 1988 Corvette:  Service Bulletin:  New Heater and Air Condition Control Head Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</link>
