<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-engine-exchange-program-1018.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Hard Start on Hot Restart / Increased Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</guid>
										<title>1990 Corvette: Recall: Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Diagnosing Low Tire Pressure Warning System Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-november-7-1996-chevrolet-lt5-impala-ss-tim-allen-s-way-of-saying-get-me-to-the-show-on-time-835.html</guid>
										<title>GM Press Release:  November 7, 1996:  Chevrolet LT5 Impala SS: Tim Allen`s Way of Saying &lsquo;Get Me To The Show On Time`</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-november-7-1996-chevrolet-lt5-impala-ss-tim-allen-s-way-of-saying-get-me-to-the-show-on-time-835.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Noise - Install Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</guid>
										<title>1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</guid>
										<title>1994 - 1995 Corvette ZR-1: Characteristics of A.L. Dunn Cylinder Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-zr-1-characteristics-of-a-l-dunn-cylinder-heads-478.html</link>
