<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Increased Capacity Fuel Pump</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-corvette-fuel-injection-modifications-735.html</guid>
										<title>1963 Corvette: Zone Letter: Corvette Fuel Injection Modifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-corvette-fuel-injection-modifications-735.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</guid>
										<title>1964 - 1965 Corvette: Technical Article: &quot;30-30&quot; Solid Lifter Cam Valve Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-technical-article-30-30-solid-lifter-cam-valve-adjustment-733.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</guid>
										<title>1966 Corvette: Technical Article:  Adjusting the Fast-Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-adjusting-the-fast-idle-speed-239.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</guid>
										<title>1964 Corvette: Service Bulletin: Recalibration of Carter AFB Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</guid>
										<title>1966 Corvette:  Product Data Book:  Radiator Grille Supports</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</guid>
										<title>1965 Corvette:  Engineering Service Letter:  Engine Bucking and Faltering</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</link>
