<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</guid>
										<title>1968 Corvette Convertible:  Engineering Service Letter:  Rear Courtesy Light Shorting Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</guid>
										<title>1968 - 1970 Corvette:  Service Bulletin:  Depressed Park Windshield Wipers Unable to Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1988-corvette-service-bulletin-damage-to-wiring-terminals-on-engine-sensors-metri-pack-150-series-1242.html</guid>
										<title>1985 - 1988 Corvette:  Service Bulletin:  Damage to Wiring Terminals on Engine Sensors - Metri-Pack 150 Series</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1988-corvette-service-bulletin-damage-to-wiring-terminals-on-engine-sensors-metri-pack-150-series-1242.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-whine-noise-in-radio-1113.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Whine Noise in Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-whine-noise-in-radio-1113.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</guid>
										<title>1968 Corvette: Service Bulletin: Windshield Wiper System - Operation and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm System Interim Modifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</guid>
										<title>1987 Corvette:  Service Bulletin:  Engine Harness Cut by Casting Flash on Transmission Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</link>
