<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-temperature-gauge-reading-too-high-1014.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-rear-bulb-re-incarnation-243.html</guid>
										<title>1966 Corvette: Technical Article:  Rear Bulb Re-incarnation</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-wiring-diagrams-for-breakerless-ignition-systems-903.html</guid>
										<title>1966 Corvette:  Service News:  Wiring Diagrams for Breakerless Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-wiring-diagrams-for-breakerless-ignition-systems-903.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Distributor Breaker Point Burning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</guid>
										<title>1963 Corvette:  Delco Service Bulletins:  Delco Radio Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</guid>
										<title>1967 Corvette: Service Bulletin: Keys for 1967 Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</guid>
										<title>1966 Corvette:  Service News: Corvette Radio Speaker - Replace</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</link>
