<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-fuel-injector-and-oil-ring-seal-replacement-1011.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Engine Repair with Crankshaft Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-service-bulletin-100-octane-fuel-calibration-1320.html</guid>
										<title>2015 - 2016 Corvette Z06: Service Bulletin: 100 Octane Fuel Calibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-service-bulletin-100-octane-fuel-calibration-1320.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</guid>
										<title>2017 Corvette Z06:  Service Bulletin:  #PIP5485: Supercharger Whine Noise - (Mar 14, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</guid>
										<title>2014 - 2015 Corvette:  Service Bulletin:  16009 Primary Tank Inlet Check Valve Fuel and Vapor Leaks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #PIP5498B: SES Lamp P050D P0300 Setting On A Cold Start And/Or a Run Rough Warm with No codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-reminder-2016-2017my-z51-grand-sport-and-z06-corvettes-required-maintenance-chevrolet-complete-care-1355.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: Reminder - 2016/2017MY - Z51, Grand Sport and Z06 Corvettes - Required Maintenance/Chevrolet Complete Care</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-reminder-2016-2017my-z51-grand-sport-and-z06-corvettes-required-maintenance-chevrolet-complete-care-1355.html</link>
