<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: #PIC5049A: Fuel Tank Hard to Fill Or Displays 1/2 Tank After Filling - (Oct 22, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</guid>
										<title>2010 - 2011 Corvette:  GM TechLink: Engine Misfires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-2011-corvette-gm-techlink-engine-misfires-66.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-wipers-will-not-park-131.html</guid>
										<title>2005 - 2006 Corvette:  Service Bulletin:  Wipers Will Not Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-wipers-will-not-park-131.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-corvette-personal-audio-link-pal-installation-for-vehicles-equipped-with-factory-navigation-u3u-75.html</guid>
										<title>2006 - 2013 Corvette:  Corvette Personal Audio Link (PAL) Installation for Vehicles Equipped with Factory Navigation (U3U)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-corvette-personal-audio-link-pal-installation-for-vehicles-equipped-with-factory-navigation-u3u-75.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</guid>
										<title>2009 Corvette: Service Campaign: OnStar System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-service-campaign-onstar-system-inoperative-15.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</guid>
										<title>2006 Corvette: Electrical Schematic: Exterior Lamps Circuit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-exterior-lamps-circuit-206.html</link>
