<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-lubricant-leakage-3-speed-close-ratio-transmission-1043.html</guid>
										<title>1956 - 1957 Corvette:  Service Bulletin:  Lubricant Leakage 3-Speed Close Ratio Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-lubricant-leakage-3-speed-close-ratio-transmission-1043.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-conversion-from-3-speed-to-4-speed-transmission-787.html</guid>
										<title>1956 - 1957 Corvette: Service Bulletin: Conversion From 3-Speed to 4-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-conversion-from-3-speed-to-4-speed-transmission-787.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</guid>
										<title>1953 - 1954 Corvette:  Service News:  Powerglide Clutch Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</guid>
										<title>1958 - 1959 Corvette: Service Bulletin: Vacuum Modulation System Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</guid>
										<title>1953 Corvette:  Service Bulletin:  Powerglide Transmission Slippage and Chatter in Automatic Low and Drive Range</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</guid>
										<title>1958 Corvette: Service Bulletin: Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</guid>
										<title>1956 Corvette Service News:  Corvette Transmission Control Lever Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-news-corvette-transmission-control-lever-seal-1150.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</guid>
										<title>1955 Corvette: Service Bulletin: Foreign Material in Clutch Housings, Secondary Road Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</guid>
										<title>1957 - 1962 Corvette:  Chevrolet Advance Information:  New Clutch Pressure Plate Released for 1962 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Excessive Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</link>
