<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</guid>
										<title>1965 Corvette: Service Bulletin: Valve Spring Cap Failure - 425 H.P., 396 ci. Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Oil Level Gauges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-oil-level-gauges-1008.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Drive Line Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-drive-line-noise-1084.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</guid>
										<title>1965 Corvette:  Engineering Service Letter:  Engine Bucking and Faltering</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: Knowing How Your 1963 - 1982 Corvette`s Cooling System Can Prevent a Steaming Summer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
