<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-engine-bucking-and-faltering-1003.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</guid>
										<title>1963 Corvette:  Field Service Engineering:  Intake Manifold Baffle Rivet Hole Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</guid>
										<title>1965 Corvette: Service News:  Engine Removal Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</guid>
										<title>1966 Corvette:  Product Data Book:  Radiator Grille Supports</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-product-data-book-radiator-grille-supports-140.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-advance-information-engine-crankcase-backfire-1253.html</guid>
										<title>1963 Corvette:  Chevrolet Advance Information:  Engine Crankcase Backfire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-advance-information-engine-crankcase-backfire-1253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</guid>
										<title>1965 Corvette: Engineering Technical Information:  Holley Carburetor Changes on 396 CU. IN. Engines - 425 H.P.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-technical-information-holley-carburetor-changes-on-396-cu-in-engines-425-h-p-1010.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Dying on Quick Right Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Top Radiator Inlet Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Automatic Choke Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</link>
