<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-drive-axle-boot-pliers-100.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-power-steering-shudder-or-vibration-at-idle-153.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Power Steering Shudder or Vibration at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-power-steering-shudder-or-vibration-at-idle-153.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</guid>
										<title>2005 - 2006 Corvette: Rear Wheel Drive Shaft Nut Torque Specification Requirements and Information on Replacement Shafts for Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-61.html</guid>
										<title>2005 - 2009 Corvette:  Service Bulletin:  Tapping or Scraping Noise From Rear Wheel Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-61.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
