<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-170-brake-pulsation-and-or-vibration-during-brake-apply-1270.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: #16-NA-170: Brake Pulsation and/or Vibration During Brake Apply</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-170-brake-pulsation-and-or-vibration-during-brake-apply-1270.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: #17267: Service Update - Brake Wear Indicator Not Functioning Properly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-17-na-239-information-on-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-1450.html</guid>
										<title>2014 - 2020 Corvette:  Service Bulletin: #17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pic6061b-change-brake-pads-message-displayed-in-dic-1367.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIC6061B: Change Brake Pads - Message Displayed In DIC</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pic6061b-change-brake-pads-message-displayed-in-dic-1367.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</guid>
										<title>2015 Corvette Z06:  GM TechLink:  Brake Pad Wear Sensor Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</guid>
										<title>2019 Corvette Z06:  Service Bulletin: 18096 Brake Deflector for Street Use Not Installed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</guid>
										<title>2009 - 2017 Corvette: Service Bulletin: #PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIC6083A: Normal Characteristic - Vehicle Unable To Move After Being Parked For An Extended Period Of Time - (Mar 27, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</link>
