<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Driver Mode Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-driver-mode-control-2.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: PIC6193B: Cannot Save XM Favorites</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-107-dtc-u0184-set-radio-inoperative-blue-screen-am-clipping-noise-hd-on-off-status-not-retained-in-stations-time-lag-on-transitions-no-audio-with-internal-amp-park-assist-symbol-position-wrong-i-1303.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: #16-NA-107: DTC U0184 Set, Radio Inoperative, Blue Screen, AM Clipping Noise, HD On/Off Status Not Retained in Stations, Time Lag on Transitions, No Audio with Internal Amp, Park Assist Symbol Position Wrong i</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-16-na-107-dtc-u0184-set-radio-inoperative-blue-screen-am-clipping-noise-hd-on-off-status-not-retained-in-stations-time-lag-on-transitions-no-audio-with-internal-amp-park-assist-symbol-position-wrong-i-1303.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-update-performance-timer-missing-1262.html</guid>
										<title>2016 Corvette:  Service Update - Performance Timer Missing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</guid>
										<title>2017 Corvette: Service Bulletin: Vehicle Time Out for Parasitic Draw Testing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-1283.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-1283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</guid>
										<title>2015 Corvette:  GM TechLink:  Incorrect Song Information Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-incorrect-song-information-displayed-1185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PI1410A: Normal Characteristic - Instrument Panel Red Brake Light Intermittently Comes On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-lap-timer-function-is-missing-from-the-dic-jun-27-2016-1285.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin:  Lap Timer Function Is Missing From The DIC - (Jun 27, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-lap-timer-function-is-missing-from-the-dic-jun-27-2016-1285.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
