<title>Home - All Categories - C4 Corvettes  - How-To Articles by CAC Forum Members  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/how-to-articles-by-cac-forum-members/97/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</guid>
										<title>1995 Corvette: Replacing Rear Wheel Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</link>
										<description><![CDATA[1995 Corvette: Replacing Rear Wheel Bearings  Submitted by: nelsonvette  Just wanted to post this now while it was still fresh in my mind. Replacing a rear wheel bearing is not that bad of a job. I read some post before I did mine that made me...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-air-filter-replacement-803.html</guid>
										<title>1993 Corvette: Air Filter Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-air-filter-replacement-803.html</link>
										<description><![CDATA[ Submitted by:  93*Corvette      DISCLAIMER:&nbsp; This How-To article contains information from other Corvette owners and enthusiasts that are members of the Corvette Action Center forums. Any information used from this How-To section is used at...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-fixing-erratic-digital-display-804.html</guid>
										<title>1990 - 1996 Corvette: Fixing Erratic Digital Display</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-fixing-erratic-digital-display-804.html</link>
										<description><![CDATA[ Submitted by:  Gorgon       I am offering this write-up for those that have problems with the digital dash of the 90 to 96 model Corvettes. This interior has analog gauges with a digital LCD in the center of the instrument cluster. My experience...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</guid>
										<title>1985 - 1991 Corvette: L-98 Engine Start Sequence</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</link>
										<description><![CDATA[L-98 Engine Start Sequence  Posted by Grumpyvette  Info that might help - (before you ask, yeah the LT1 is very similar).  L-98 Engine Start Sequence  When you start an L-98 engine Corvette, a series of events take place that causes the engine to run...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-increasing-instrument-cluster-illumination-805.html</guid>
										<title>1984 Corvette: Increasing Instrument Cluster Illumination</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-increasing-instrument-cluster-illumination-805.html</link>
										<description><![CDATA[ Submitted by  geekinavette  (Bill Hitchcock)    I've had a problem with the photocell in my '84 cluster since I bought it. During the day the cluster is too dim to see...unless you turn the park lights on. What I did temporarily to "fix" it so that...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</guid>
										<title>1984 - 1996 Corvette: Re-Dyeing Seats</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</link>
										<description><![CDATA[ From:  &nbsp;  toms94   Title:&nbsp; Re-Dyeing Leather Seats   Posted:&nbsp;  11-16-06 I wanted to show you the job I just finished on my seats. My 1994 sport seats were, like nearly everyone's, showing wear. Particularly in the drivers seat and...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</guid>
										<title>1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</link>
										<description><![CDATA[1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years  Submitted by:&nbsp;  KANE  09-21-2008  Many folks have done the swap... I'm documenting some of the things that I have found that work well between...]]></description>
