<title>Home - All Categories - C3 Corvettes  - How-To Articles by CAC Forum Members  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c3-corvettes/how-to-articles-by-cac-forum-members/96/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-how-to-tpi-fuel-rail-removal-fuel-injector-replacement-827.html</guid>
										<title>1982 Corvette: How-To: TPI Fuel Rail Removal (Fuel Injector Replacement)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-how-to-tpi-fuel-rail-removal-fuel-injector-replacement-827.html</link>
										<description><![CDATA[1982 Corvette: How-To: TPI Fuel Rail Removal (Fuel Injector Replacement) Submitted by:&nbsp;  KANE  11-30-2007 Today I'm going to take you through a picture tutorial of what it looks like to break down the TPI system far enough to get the fuel rail...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-replacing-power-steering-hoses-811.html</guid>
										<title>1981 Corvette: Replacing Power Steering Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-replacing-power-steering-hoses-811.html</link>
										<description><![CDATA[Submitted by: Scott81 10-26-2006  The hoses are pretty easy to change. First step is jack up the Vette and get it level on 4 stands. Take off the front wheel then using a line wrench (please use a line wrench, it will be SO much easier and will...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-repairing-driver-side-sun-visor-807.html</guid>
										<title>1981 Corvette: Repairing Driver Side Sun Visor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-repairing-driver-side-sun-visor-807.html</link>
										<description><![CDATA[1981 Corvette: Repairing Driver Side Sun Visor  Submitted by: bill81vette  With a small screw driver pop off the plug covering the top hole where the visor keeps falling out of.  Remove the old clip(its probably broken) and the spring. Place the new...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-installing-c4-corvette-seats-in-a-c3-corvette-810.html</guid>
										<title>1968 - 1982 Corvette: Installing C4 Corvette Seats in a C3 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-installing-c4-corvette-seats-in-a-c3-corvette-810.html</link>
										<description><![CDATA[Submitted by: 69MyWay 10-26-2006  This topic comes up often, so I thought I would share what I have learned with others considering the mod.   Thanks to John AKA Black Thunder I have had the awesome opportunity to install a set of 1994 Corvette seats...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</guid>
										<title>1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</link>
										<description><![CDATA[1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years  Submitted by:&nbsp;  KANE  09-21-2008  Many folks have done the swap... I'm documenting some of the things that I have found that work well between...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-install-vette-brakes-spreader-bar-in-a-c3-corvette-809.html</guid>
										<title>1968 - 1982 Corvette: How to install Vette Brakes Spreader Bar in a C3 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-install-vette-brakes-spreader-bar-in-a-c3-corvette-809.html</link>
										<description><![CDATA[ Submitted by:  Eddie 70   March 15, 2009    I had been wanting to install one of the spreader bars for a long time just to firm up the front suspension. Well I finally broke down and spent the money. When the package finally arrived at my door I was...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-how-to-bleeding-brakes-830.html</guid>
										<title>1965 - 1982 Corvette: How-To: Bleeding Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-how-to-bleeding-brakes-830.html</link>
										<description><![CDATA[ 1965 - 1982 Corvette: How-To: Bleeding Brakes  Submitted by:&nbsp; Hib Halverson 05-03-2007 The 1965 - 1982 Corvette brake caliper is prone to air leaks. If you have not replaced your OE calipers with stainless steeel sleeved calipers, I'd do that...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-rotor-bearing-installation-812.html</guid>
										<title>1963 - 1982 Corvette: Rotor Bearing Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-rotor-bearing-installation-812.html</link>
										<description><![CDATA[ Submitted by:  GTR1999     Since this topic is another one that always comes up I figured I'd post some pictures of the job I was doing for a forum buddy.   This job is rebuilding the front spindles and installing new stock rotors. As a lot of you...]]></description>
