<title>Home - All Categories - C4 Corvettes  - 1996 Corvette LT4  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/1996-corvette-lt4/93/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
										<description><![CDATA[1996: Engine Diagnostic Trouble Codes DTC P0100 MAF Sensor Circuit Insufficient Activity DTC P0101 Mass Air Flow (MAF) Sensor Performance DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency DTC P0103 Mass Air Flow (MAF) Sensor Circuit High...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-lt4-recall-rocker-arm-attaching-pin-not-fully-seated-516.html</guid>
										<title>1996 Corvette LT4: Recall: Rocker Arm Attaching Pin Not Fully Seated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-lt4-recall-rocker-arm-attaching-pin-not-fully-seated-516.html</link>
										<description><![CDATA[Model Year: 1996 Corvettes With LT4 EngineSubject: INADEQUATE RETAINING LOAD HOLDING ROCKER ARM ROLLER PIN IN PLACESource: Chevrolet Product CampaignNumber: 96-C-07ATO: ALL CHEVROLET DEALERSGeneral Motors has decided that CERTAIN 1996 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</guid>
										<title>1992 - 1996 Corvette: Service Bulletin: Engine Miss/Poor Driveability Symptoms</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</link>
										<description><![CDATA[Subject: Engine Miss/Poor Driveability Symptoms (Install Opti-Spark (ABITS) Distributor Assembly Service Kit)Model and Year:1994-96 Buick Roadmaster1994-96 Cadillac Fleetwood1992-96 Chevrolet Corvette1993-97 Chevrolet Camaro1994-96 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<description><![CDATA[  Model Year:  1989-96 CHEVROLET CORVETTE WITH ZF 6-SPEED MANUAL TRANSMISSION (ML9)   Subject:  INFORMATION ON CORVETTE ZF 6-SPEED MANUAL TRANSMISSION SERVICE PROCEDURE   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  77-72-04  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</guid>
										<title>1988 -1996 Corvette : Visual Differences Between Production Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</link>
										<description><![CDATA[1988 - 1996 Corvette Caliper Pictorial  The following pictures and information are used here with permission by Jeff Kopp, Wholesale Parts Manager, Superior Chevrolet, Merriam, KS.   Below are some pictures and descriptions that show some of the...]]></description>
