<title>Home - All Categories - C6 Corvettes  - 2006 - 2013 Corvette Z06  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c6-corvettes/2006-2013-corvette-z06/90/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</guid>
										<title>2009 Corvette Z06 and ZR1: GM TechLink Article: Oil System Changes - LS7 and LS9</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<description><![CDATA[Changes have been made to the dry-sump engine oil system used in the 2009 Corvette   (fig. 1)  . This information pertains to these two engines:  &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - LS7 7.0L -- used in the Z06   &nbsp...]]></description>
										<description><![CDATA[#PIC6162D: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jan 19, 2021)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use        Brand...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2012-corvette-z06-gm-techlink-drive-belt-noise-and-crankshaft-balancer-runout-71.html</guid>
										<title>2009 - 2012 Corvette Z06: GM TechLink: Drive Belt Noise and Crankshaft Balancer Runout</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2012-corvette-z06-gm-techlink-drive-belt-noise-and-crankshaft-balancer-runout-71.html</link>
										<description><![CDATA[Source: GM TechlinkDate: October 2011Subject:&nbsp;&nbsp;Drive Belt Noise and Crankshaft Balancer RunoutModels: 2009 - 2012 Chevrolet Corvette Z06 On some 2010-2012 Camaro SS models and 2009-2012 Corvette models equipped with the 6.2L engine (RPOs...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-z06-gm-techlink-article-clutch-pedal-doesn-t-return-102.html</guid>
										<title>2008 Corvette Z06: GM TechLink Article: Clutch Pedal Doesn`t Return</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-z06-gm-techlink-article-clutch-pedal-doesn-t-return-102.html</link>
										<description><![CDATA[The clutch pedal on some 2008 Z06 Corvettes may stay on the floor when depressed and releasedBefore any parts are replaced, follow these steps:1. The engine should be off, transmission placed in neutral and the parking brake applied.2. Verify the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</guid>
										<title>2007 Corvette Z06: Dealer Bulletin: Addition Of Optional Z06 Chrome Wheel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-z06-dealer-bulletin-addition-of-optional-z06-chrome-wheel-313.html</link>
										<description><![CDATA[To: All Chevrolet Corvette DealersDate: October 11, 2006Re: Addition of optional Z06 chrome wheelWhile initial research had indicated that the polished wheel option would remain the predominant Z06 consumer choice, we have received an increasing...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-customer-satisfaction-program-engine-flywheel-clutch-interference-327.html</guid>
										<title>2006 Corvette: Customer Satisfaction Program: Engine Flywheel/Clutch Interference</title>
										<description><![CDATA[Note:&nbsp; A copy of this recall notice is attached below:  UPDATED INFORMATIONDate: April 5, 2006Subject: 06523A &ndash; Customer Satisfaction ProgramEngine Flywheel /Clutch InterferenceModels: 2006 Chevrolet Corvette Equipped with a 6.0 L V8 (RPO...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-service-bulletin-information-on-over-filling-dry-sump-oiling-system-and-maintaining-proper-oil-level-on-ls7-engine-314.html</guid>
										<title>2006 Corvette Z06: Service Bulletin: Information on Over-Filling Dry Sump Oiling System and Maintaining Proper Oil Level on LS7 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-service-bulletin-information-on-over-filling-dry-sump-oiling-system-and-maintaining-proper-oil-level-on-ls7-engine-314.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 05-06-01-032 Date: NA Subject:&nbsp; Creak or Popping Noise from Roof Near Windshield/"A" Pillar (Replace Plastic Guides In Roof Striker) Model(s): 2006 Chevrolet Corvette Z06 with 7.0L V8 engine (VIN E - RPO LS7)The 2006...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
										<description><![CDATA[VINAfter the first 140 Corvette Z06s were built with a VIN Y designation for the engine, it was changed to VIN E. The LS7 engine is installed in all of the cars.TIP: For these first 140 vehicles, it is necessary to use the letter E (instead of the Y...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-car-wash-tire-fitment-320.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Car Wash - Tire Fitment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-car-wash-tire-fitment-320.html</link>
										<description><![CDATA[Car WashThe Z06 may not fit on some car washes due to the use of wider tires (rear tires are 13.6 inches, 325 mm, on 12-inch wheels). An information hang tag is included on the gearshift lever. Source:&nbsp; GM Techlink, September, 2005 General...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</guid>
										<title>2006 Corvette Z06: Dry Sump Oiling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-dry-sump-oiling-system-315.html</link>
										<description><![CDATA[  The Corvette Z06's LS7 engine  (fig. 1)  has a dry sump oiling system designed to keep the engine fully lubricated during the high cornering loads the Corvette Z06 is capable of producing. Ths LS7's dry sump system was developed and tested on...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</guid>
										<title>2006 Corvette Z06:  GM Collison Repair and Complete Identification Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-collison-repair-and-complete-identification-manual-274.html</link>
										<description><![CDATA[Attached below is the complete 2006 Corvette Z06 collision repair manual that contains all identification numbers necessary for this model.It is a 1.6 MB PDF document.General Motors bulletins are intended for use by professional technicians, not a ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</guid>
										<title>2006 - 2013 Corvette Z06: Technical Article: Robotic trimming radically shortens Corvette fender production cycle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-technical-article-robotic-trimming-radically-shortens-corvette-fender-production-cycle-167.html</link>
										<description><![CDATA[  Robotic trimming radically shortens Corvette fender production cycle     High Performance Composites Magazine  By Staff |   November 2007     Plasan USA (Bennington, Vt.) molds the Chevrolet Z06 Corvette&rsquo;s front fenders with hand layed,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</guid>
										<title>2006 - 2013 Corvette Z06: Service Bulletin: Information on Customer Questions About Valve Guide Wear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html</link>
										<description><![CDATA[#13-06-01-001:&nbsp; Information on Customer Questions About Valve Guide Wear - (Jan 14, 2013) Subject:&nbsp; Information on Customer Questions About Valve Guide Wear Models:&nbsp; 2006-2013 Chevrolet Corvette 427, Corvette Z06 Equipped with 7.0L V8...]]></description>
										<description><![CDATA[Bulletin #:&nbsp; #08-06-01-019ASubject:&nbsp; Rattle/Tapping Type Noise Heard Under Hood (Diagnose and Replace Engine Oil Tank Transfer Tube Seal (O-Ring))Models:2006-2012 Chevrolet Corvette Z062009-2012 Chevrolet Corvette ZR12010-2012 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink: Excess Oil in Air Intake Snorkel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</link>
										<description><![CDATA[Some owners of a 2006-09 Corvette with a 7.0L engine (RPO LS7), a 2008-09 Corvette with 6.2L engine (RPO LS3) or a 2009 Chevrolet Corvette with 6.2L supercharged engine (RPO LS9) may complain of a SES light. Upon inspection, oil in the air cleaner, a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink Article: Oil Reservoir Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</link>
										<description><![CDATA[Some owners of a 2006-09 Corvette Z06 or a 2009 Corvette ZR1 with 6.2L or 7.0L Engine (VINs R, E -- RPOs LS9, LS7) may comment on a rattle or tapping type noise that is heard under the hood just above idle, usually 1200 to 2200 RPM. In some cases,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</guid>
										<title>2006 - 2007 Corvette Z06: Service Bulletin: Flushing Remote Oil Tank When Replacing Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-service-bulletin-flushing-remote-oil-tank-when-replacing-engine-316.html</link>
										<description><![CDATA[Date: November 3, 2006 Bulletin #:&nbsp; #06-06-01-024 Subject:&nbsp; Info - Flushing Remote Oil Tank When Replacing EngineModels: 2006-2007 Corvette Z06 with 7.0L Engine (VIN E - RPO LS7) Engine Replacement -- Oiling System DebrisNotice: Debris in...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</guid>
										<title>2006 - 2007 Corvette Z06: Customer Satisfaction Campaign 06092: Brake Pad Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2007-corvette-z06-customer-satisfaction-campaign-06092-brake-pad-inspection-318.html</link>
										<description><![CDATA[Date: October 11, 2006 Subject: Customer Satisfaction Campaign 06092 - Brake Pad InspectionModels: 2006-2007 Chevrolet Corvette Z06 ConditionThe owner manual for 2006 and 2007 Chevrolet Corvette vehicles indicates that all vehicles are equipped with...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvettes-all-models-grand-sport-stripe-kit-part-numbers-1184.html</guid>
										<title>2005 - 2013 Corvettes - All Models:  Grand Sport Stripe Kit Part Numbers</title>
										<description><![CDATA[The following information comes from Hib Halverson regarding the correct part numbers for the stripe kits used on 2010 - 2013 Grand Sport Corvettes as they apply to other C6 Corvettes:  I emailed with Jerry Parsell, again, on the Grand Sport stripe...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<description><![CDATA[Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid and Add Specified Limited-Slip Axle Additive) Number:&nbsp; #07-04-20-002Date:&nbsp; (04/16/2007)Models: 2004-2007 Cadillac XLR (Including V-Series and...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-campaign-removable-roof-panel-95.html</guid>
										<title>2005 - 2007 Corvette: Campaign: Removable Roof Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-campaign-removable-roof-panel-95.html</link>
										<description><![CDATA[       Vehicle Make / Model:  &nbsp;&nbsp;&nbsp; Model Year(s):    &nbsp;&nbsp;&nbsp;&nbsp; CHEVROLET / CORVETTE  &nbsp;&nbsp;&nbsp;  2005-2007   &nbsp;&nbsp;&nbsp;&nbsp; CHEVROLET / CORVETTE Z06  &nbsp;&nbsp;&nbsp;  2005-2006   Manufacturer: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<description><![CDATA[Document ID# 1982105 Subject: Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts - keywords contaminate fluid hydraulic #PIP4145 - (06/04/2007) Models: 2005-2007 Chevrolet Corvette, Corvette Z06...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: 2005-2006 Chevrolet Corvette Including Z06 Repair Procedure for Painted Roofs that may separate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-2005-2006-chevrolet-corvette-including-z06-repair-procedure-for-painted-roofs-that-may-separate-364.html</link>
										<description><![CDATA[UPDATED INFORMATIONDate: June 23, 2006 Subject: 06523A &ndash; 05112D &ndash; Customer Satisfaction Program, 2005-2006 Chevrolet Corvette Including Z06 Repair Procedure for Painted Roofs that may separateModels: 2005-2006 Chevrolet Corvette and Z06...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-painted-roof-adhesive-separation-273.html</guid>
										<title>2005 - 2006 Corvette: Recall: Painted Roof Adhesive Separation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-recall-painted-roof-adhesive-separation-273.html</link>
										<description><![CDATA[NOTE:&nbsp; The bulletin below was revised in June of 2006 to include the Z06 Corvette.&nbsp; Below is bulletin #05112D in PDF format.Custom Satisfaction&nbsp;Bulletin:&nbsp; #05112 Date: February 23, 2006 Subject:&nbsp; Customer Satisfaction Program...]]></description>
