<title>Home - All Categories - General Topics  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/general-topics/9/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</guid>
										<title>Tire Storage Recommendations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</link>
										<description><![CDATA[Description:The following text is a document from Engineering at Goodyear Tire and Rubber Company. Although the tips listed are directed mainly at warehouse facilities and dealers, they are helpful tips if you are planning on storing your Corvette's...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</guid>
										<title>Technical Article: Spring Thing - Putting the &quot;Spring&quot; Back In Your Corvette`s Step</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-spring-thing-putting-the-spring-back-in-your-corvette-s-step-254.html</link>
										<description><![CDATA[By John Hinckley, Corvette Enthusiast MagazineUsed here with permission.Copyright John Hinckley, Corvette Enthusiast MagazineTHE OBJECTIVE of this article is to show you the &ldquo;right&rdquo; way to rebuild/re-arch Corvette leaf springs, and to...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</guid>
										<title>Technical Article: Problems I have Seen with Commercially Rebuilt Q-Jets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html</link>
										<description><![CDATA[Problems I have Seen with Commercially Rebuilt Q-Jetsby Lars Grimsrud&copy;2010 Lars Grimsrud. This article may not be published or distributed without the written permission of the author Rev. D 10-2-10As the Q-Jet carbs keep getting older, fewer...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
										<description><![CDATA[Description:Not quite sure how to prepare your Corvette for long term or cold weather winter storage?&nbsp; This four page article with printable check list is just for you.Excerpt:" One of the most popular questions among Corvette owners is "how...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</guid>
										<title>Technical Article: Leak Less - Swapping the Centerhead in Your Corvette and Keeping Leaks at Bay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
										<description><![CDATA[By John Hinckley, Corvette Enthusiast MagazineUsed here with permission.Copyright John Hinckley, Corvette Enthusiast MagazineThe objective of this article is to walk you through an intake manifold swap and identify the tools, materials, and tips...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</guid>
										<title>Technical Article: How to Set Up a BG Speed Demon (basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</link>
										<description><![CDATA[How to Set Up a BG Speed Demon (basic) by Lars Grimsrud&copy;2010 Lars Grimsrud. This article may not be published or distributed without the written permission of the author Rev. C 1-2-10 This tech paper will discuss basic set-up of the Barry Grant...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</guid>
										<title>Technical Article: How to Repair &amp; Rebuild your Alternator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</link>
										<description><![CDATA[How to Repair &amp; Rebuild your Alternator by Lars Grimsrud&copy;2010 Lars Grimsrud.  This article may not be published or distributed without the written permission of the author Rev. C 1-2-10 This tech paper will discuss the disassembly,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</guid>
										<title>Technical Article: How to Install a BG Speed Demon (Basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<description><![CDATA[How to Install a BG Speed Demon (basic) by Lars Grimsrud&copy;2010 Lars Grimsrud. This article may not be published or distributed without the written permission of the author Rev. D 4-2-10 Getting a BG Speed Demon carb set up and running right on...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</guid>
										<title>Technical Article: Air Conditioning System Maintenance and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-air-conditioning-system-maintenance-and-repair-297.html</link>
										<description><![CDATA[Posted By: Joe on 8-21-2001 - 6:11PMSubject: HC's,R-12 systems, etc.OK. Here we go My name is Joe and I have over 20yrs experience in the field of automotive repair. Over the past 1&frac12; years one of the shops I own has charged over 132 passenger...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<description><![CDATA[By John HinckleyUsed here with permission.Copyright John HinckleyIn this day and age, when modern automotive powertrains are computer-controlled and engines don&rsquo;t even HAVE distributors any more, the knowledge of what distributors did and how...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</guid>
										<title>Technical Article:  Synthetic Oil Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</link>
										<description><![CDATA[From Jim Ingle, GM Powertrain Engineer (this question was asked in terms of adding Mobil 1 to a ZR-1 after engine break-in):"There is probably more misunderstanding of lubricants and "old wive's tales" about them than any other automotive issue. A...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<description><![CDATA[By John Hinckley, Corvette Enthusiast MagazineUsed here with permission.Copyright John Hinckley, Corvette Enthusiast MagazineFROM THE FACTORY: Since bolts don&rsquo;t hold very well just driven intofiberglass, your Corvette has a lot of steel tapping...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</guid>
										<title>Technical Article:  Mapping Your Advance Curve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</link>
										<description><![CDATA[By John HinckleyUsed here with permission.Copyright John HinckleyThe objective of this article is to show how to verify the operation of these systems and make necessary corrections at home, using ordinary tools; there&rsquo;s no need for a classic...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</guid>
										<title>Technical Article:  Horsepower vs. Torque</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-horsepower-vs-torque-280.html</link>
										<description><![CDATA[Description:An excellent look at the differences between horsepower and torque and how each rating is achieved during engine development by Corvette Powertrain Engineer, Jim Ingle.Excerpt:"Two views of the same measurement are involved: power and...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-performance-testing-281.html</guid>
										<title>Technical Article:  Corvette Performance Testing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-performance-testing-281.html</link>
										<description><![CDATA[Description:An in-depth look at how Corvette performance numbers are generated by the Corvette Development team. This article was written by Jim Ingle who used to be a Corvette Powertrain Engineer.Excerpt:"This is another discussions best illustrated...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</guid>
										<title>Technical Article:  Corvette - New Application Test Car of the Future - by Dave McLellan - Corvette Chief Engineer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</link>
										<description><![CDATA[Corvette - New Application Test Car of the Future - By Dave McLellan - Corvette Chief Engineer Talk Give to the 33rd Annual Conference of the Reinforced Plastics and Composite Institute - February 9, 1978 In this the Corvette's 25th Anniversary year,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
										<description><![CDATA[By John Hinckley, Corvette Enthusiast MagazineUsed here with permission.Copyright John Hinckley, Corvette Enthusiast MagazineREADER&rsquo;S QUESTION: My &rsquo;69 restoration is about half done; the body is at the painter, and I&rsquo;ve completed...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-chevrolet-engine-crankshaft-specifications-284.html</guid>
										<title>Small Block Chevrolet Engine Crankshaft Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-chevrolet-engine-crankshaft-specifications-284.html</link>
										<description><![CDATA[Small Block Chevrolet Crankshaft Specifications   Casting #EngineForged/CastJournalStroke of crankRear main seal  1130 327 Forged Medium 3.25" 2-piece   1178 302 Forged Medium 3.25" 2-piece   1181 305/350 Cast Medium 3.48" 2-piece   1182 350 Forged...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<description><![CDATA[  Bore &amp; Stroke Chart Small Block Engine EngineYearsBore DiameterStrokeRod LengthMain Bearing DiameterRod Bearing DiameterMain CapsJournal SizeNotes    262 1975-76 3.671 3.10 5.7 2.45 2.10 2-bolt Medium &nbsp;   265 1955-56 3.75 3.00 5.7 2.30 2...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</guid>
										<title>Service Bulletin: Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-removal-of-tight-wheels-277.html</link>
										<description><![CDATA[Subject: Removal of Tight WheelsModel and Year: All Passenger CarsSource: Chevrolet Service BulletinBulletin Number: Number 85-28, Section 3E (X), Feb., 1985 TO:&nbsp; ALL CHEVROLET DEALERS Sometimes wheels can be difficult to remove from the car due...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</guid>
										<title>Service Bulletin: Minor Paint Repair Without Repainting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-minor-paint-repair-without-repainting-295.html</link>
										<description><![CDATA[Note: This service bulletin is not specific to Corvettes but can be applied to them.&nbsp; It was published in April of 1967 but can be applied to several different model years.Subject: Minor Paint Repair Without RepaintingSource: Chevrolet Dealer...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</guid>
										<title>Service Bulletin: Fluid Leak Detection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</link>
										<description><![CDATA[The following service bulletin was issued by Chevrolet in May of 1986 and contains excellent tips for tracking down hard to find fluid leaks which can be applied to all vehicle lines.Subject: Fluid Leak DetectionSource: Chevrolet Dealer Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<description><![CDATA[Subject: Delco Freedom Battery Diagnosis Information Model and Year: Corvette - All YearsSource: Chevrolet Dealer Service BulletinBulletin Number: 83-T-8Date:&nbsp; (06/16/1983) Recent service experience indicates nearly 45% of all batteries replaced...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</guid>
										<title>Service Bulletin: Cleaning, Coating and Painting of Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</link>
										<description><![CDATA[Model Year: NASubject: Cleaning, Coating and Painting of Aluminum WheelsSource: Chevrolet Dealer Service Information BulletinNumber: 80-I-83, Section XDate: October, 1980To: All Chevrolet DealersAluminum wheels can be cleaned, coated and painted...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</guid>
										<title>Product Review:  Best All-Round:  We Test the Goodyear F1 GS-D3</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</link>
										<description><![CDATA[   Best All-Round: We Test the Goodyear F1 GS-D3          It's one thing for an ultra-performance tire to work well when the road is dry. It's another for an ultra-performance tire to work well in both wet weather as well as in the dry. Relatively...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</guid>
										<title>Product Evaluation: K&N Air Filter vs. The Green Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-k-n-air-filter-vs-the-green-filter-285.html</link>
										<description><![CDATA[Product Evaluation:&nbsp; K&amp;N vs. The Green Filter  by Hib Halverson  &copy;2003 by Shark Communications  NO USE WITHOUT PERMISSION  &nbsp;        Side by side comparison of the panel filter for 90-96 C4. Right is K&amp;N. Left is Green Filter....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</guid>
										<title>Product Evaluation: 3M Scotchcal Car Bra</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</link>
										<description><![CDATA[          Click image for larger view    Envisage Design Labs', Daniel Cook, begins the Transparent Bra application by cleaning the surfaces to which the Bra will be applied in a manner that will allow Scotchcal's adhesive to form a strong bond. ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
										<description><![CDATA[General Motors Media Press Release FOR RELEASE: December 20, 1996CONTACT:&nbsp; Kathy BommaritoPhone:&nbsp; (313) 974-7136, fax (313) 974-0321CONTACT:&nbsp; Dan DolanPhone:&nbsp; (810) 257-7723, fax (810) 257-2085 Batteries 101--How lead-acid...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</guid>
										<title>Paint: Orange Peel as it Applies to Corvette Paint Quality</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</link>
										<description><![CDATA[Description:Dan Stauft was a Paint Process Engineer at the Corvette manufacturing facility in Bowling Green, Kentucky back in October of 1995. At that time, he was a member of the ZR-1 Net - an online group of Corvette enthusiasts dedicated to the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</guid>
										<title>Head Casting Numbers: Chevrolet Small Block Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</link>
										<description><![CDATA[  Chevrolet Small Block Head Casting Numbers Casting #Combustion Chamber Size (CCs)Intake ValveExhaust ValveProduction YearsMisc.Engine Size (ci)  10033867 62cc 2.02 1.60 &nbsp; over the counter 23 degree, angle plug, 196cc intake runner, aluminum ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<description><![CDATA[General Motors Media Press Release FOR RELEASE: April 22, 1996  CONTACT(S):&nbsp; Chevrolet Communications  Phone:&nbsp; (800) CHEVY-MI or: (810) 492-8841  Fax: (810) 492-8853 Zora Arkus-Duntov He was called the "Father of the Corvette," a dream...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</guid>
										<title>Error Codes On GM Radios Explained</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<description><![CDATA[Cassette Errors E10 : Tight tape error Cause(s): A restricted cassette tape transport or broken cassette drive belt Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco&reg; Service Center....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</guid>
										<title>Engine Casting Numbers: Chevrolet V8 Passenger Cars</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/engine-casting-numbers-chevrolet-v8-passenger-cars-287.html</link>
										<description><![CDATA[Casting Numbers:&nbsp; Chevrolet V8 Passenger Cars &nbsp;   IDCID LiterYearVIN/CylinderApplicationBlockCrankHead  1 283 4.6 58-62 V8 OHV; RWD Hydraulic cam;threaded pulley hole 3756519 3789935 3794226 3837739 3849852 3735236 3836266 3815822 3731554...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<description><![CDATA[From Jerry Watts, retired Corvette Engineer, National Corvette Museum:If you own any GM car that has a resistor pellet in the key, it would be in your best interest to record the resistance value of the pellet in the vent that you lose your keys...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</guid>
										<title>Corvette Demographics - 2009</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/corvette-demographics-2009-142.html</link>
										<description><![CDATA[This article was released from the Specialty Equipment Market Association (SEMA) and outlines interesting statistics and demographics for Corvette owners across the United States in 2009:Link:&nbsp; http://www.corvetteactioncenter.com/tech...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-tire-radial-force-variation-rfv-203.html</guid>
										<title>Chevrolet Service Bulletin: Information on Tire Radial Force Variation (RFV)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-tire-radial-force-variation-rfv-203.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 00-03-10-006A Date:&nbsp;June 2005 Subject:&nbsp; Information on Tire Radial Force Variation (RFV) Model(s): 2006 and Prior Passenger Cars and Light Duty Trucks2006 and Prior HUMMER H22006 HUMMER H32000 - 2005 Saturn L...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</guid>
										<title>Chevrolet Service Bulletin: Information on Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/chevrolet-service-bulletin-information-on-proper-tire-pressure-202.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 00-00-90-002C Date:&nbsp;August 2005 Subject:&nbsp; Information on Proper Tire Pressure Model(s): 2006 and Prior Passenger Cars and Trucks (Including Saturn)2006 and Prior HUMMER H22006 HUMMER H32005 - 2006 Saab 9-7XThis...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</guid>
										<title>Buying: Buying a Corvette and What to Look For</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</link>
										<description><![CDATA[Description:Buying a used Corvette can be quite intimidating if your new to Vettes and not sure what all the jargon is or what to look for. Use our handy check list (printable) to help you purchase your next Corvette.Excerpt:"Buying your first...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/big-block-chevrolet-engine-crankshaft-specifications-288.html</guid>
										<title>Big Block Chevrolet Engine Crankshaft Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/big-block-chevrolet-engine-crankshaft-specifications-288.html</link>
										<description><![CDATA[Big Block Chevrolet Crankshaft Specifications &nbsp;   Casting #EngineForged/CastStrokeRear Main SealNotes  6223 396 / 402 / 427 Forged 3.76" Stroke 2-piece 1053 steel   7115 396 / 402 / 427 Forged 3.76" Stroke 2-piece Nitrided, cross drilled, 5140...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</guid>
										<title>All Corvettes:  Service Bulletin:  Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</link>
										<description><![CDATA[ Subject:  &nbsp; Removal of Tight Wheels  Model and Year:  &nbsp; All Passenger Cars   Source:&nbsp;  Chevrolet Dealer Service Bulletin   Bulletin No:  &nbsp; 85-28   Section:  &nbsp;&nbsp; 3E (X)   Date:  &nbsp; Feb., 1985   TO:&nbsp; ALL CHEVROLET...]]></description>
