<title>Home - All Categories - C6 Corvettes  - 2009 - 2013 Corvette ZR1  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c6-corvettes/2009-2013-corvette-zr1/89/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-service-guide-unique-characteristics-dealer-service-information-for-2009-chevrolet-corvette-zr1-155.html</guid>
										<title>2009 Corvette ZR1: Service Guide, Unique Characteristics, Dealer Service Information for 2009 Chevrolet Corvette ZR1</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-service-guide-unique-characteristics-dealer-service-information-for-2009-chevrolet-corvette-zr1-155.html</link>
										<description><![CDATA[#08-00-89-030: Service Guide, Unique Characteristics, Dealer Service Information for 2009 Chevrolet Corvette ZR1 - (Aug 13, 2008) Subject: Service Guide, Unique Characteristics, Dealer Service Information for 2009 Chevrolet Corvette ZR1 Models: 2009...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</guid>
										<title>2009 Corvette ZR1: Campaign Recall:  Clutch Spring Fracture-Replace Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-campaign-recall-clutch-spring-fracture-replace-clutch-121.html</link>
										<description><![CDATA[#09160: Customer Satisfaction - Clutch Spring Fracture-Replace Clutch - (Jul 6, 2009)Subject: 09160 -- Clutch Spring Fracture -- Replace ClutchModels: 2009 Chevrolet Corvette ZR1 -----------------------------------------------------------------------...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</guid>
										<title>2009 Corvette ZR1:  Front Fascia Valence Panel Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-zr1-front-fascia-valence-panel-installation-151.html</link>
										<description><![CDATA[Below are the installation instructions for the carbon fiber front fascia valence panel on the 2009 ZR1:
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</guid>
										<title>2009 Corvette Z06 and ZR1: GM TechLink Article: Oil System Changes - LS7 and LS9</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-z06-and-zr1-gm-techlink-article-oil-system-changes-ls7-and-ls9-106.html</link>
										<description><![CDATA[Changes have been made to the dry-sump engine oil system used in the 2009 Corvette   (fig. 1)  . This information pertains to these two engines:  &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - LS7 7.0L -- used in the Z06   &nbsp...]]></description>
										<description><![CDATA[#PIC6162D: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jan 19, 2021)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use        Brand...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-lifting-the-corvette-zr1-107.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Lifting the Corvette ZR1</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-lifting-the-corvette-zr1-107.html</link>
										<description><![CDATA[  IMPORTANT:   Some of the ZR1 carbon fiber trim is not installed to the vehicle at the assembly plant, to avoid shipping damage. The rocker moldings, front valance panels and rear wheel flare moldings must be installed at the dealership during new...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-installing-zr1-body-kit-108.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Installing ZR1 Body Kit</title>
										<description><![CDATA[Some of the carbon fiber trim is not installed to the ZR1 at the assembly plant, to avoid shipping damage. The body side lower rear (rocker) moldings, front valance panels and rear wheel opening front flares must be installed at the dealership during...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-ceramic-brake-rotors-113.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Ceramic Brake Rotors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-ceramic-brake-rotors-113.html</link>
										<description><![CDATA[The ZR1 Corvette is equipped with ceramic brake rotors  (fig. 4 and 5)  , which offer a number of benefits over cast iron rotors:  &nbsp;  - No fading   - Wet effectiveness   - No thermal deflection   - Consistent pedal travel   - No corrosion   -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-brake-burnish-procedure-129.html</guid>
										<title>2009 - 2013 Corvette ZR1:  GM TechLink: Brake Burnish Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-brake-burnish-procedure-129.html</link>
										<description><![CDATA[This is a followup to the article on ZR1 ceramic brakes in the November 2008 issue of TechLink.    NOTICE:  These procedures are specific to the ZR1 with ceramic brake rotors.  This procedure should not be run on other Corvette models as damage may...]]></description>
										<description><![CDATA[Bulletin #:&nbsp; #08-06-01-019ASubject:&nbsp; Rattle/Tapping Type Noise Heard Under Hood (Diagnose and Replace Engine Oil Tank Transfer Tube Seal (O-Ring))Models:2006-2012 Chevrolet Corvette Z062009-2012 Chevrolet Corvette ZR12010-2012 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink: Excess Oil in Air Intake Snorkel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</link>
										<description><![CDATA[Some owners of a 2006-09 Corvette with a 7.0L engine (RPO LS7), a 2008-09 Corvette with 6.2L engine (RPO LS3) or a 2009 Chevrolet Corvette with 6.2L supercharged engine (RPO LS9) may complain of a SES light. Upon inspection, oil in the air cleaner, a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink Article: Oil Reservoir Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-article-oil-reservoir-rattle-112.html</link>
										<description><![CDATA[Some owners of a 2006-09 Corvette Z06 or a 2009 Corvette ZR1 with 6.2L or 7.0L Engine (VINs R, E -- RPOs LS9, LS7) may comment on a rattle or tapping type noise that is heard under the hood just above idle, usually 1200 to 2200 RPM. In some cases,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvettes-all-models-grand-sport-stripe-kit-part-numbers-1184.html</guid>
										<title>2005 - 2013 Corvettes - All Models:  Grand Sport Stripe Kit Part Numbers</title>
										<description><![CDATA[The following information comes from Hib Halverson regarding the correct part numbers for the stripe kits used on 2010 - 2013 Grand Sport Corvettes as they apply to other C6 Corvettes:  I emailed with Jerry Parsell, again, on the Grand Sport stripe...]]></description>
										<description><![CDATA[#PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)    Subject: Torque Tube Fully Serviceable   Models: 2004 - 2009 Cadillac XLR, XLR-V   1997 - 2011 Chevrolet Corvette, Corvette Z06   2009 - 2011 Chevrolet Corvette ZR1     This PI was...]]></description>
