<title>Home - All Categories - C4 Corvettes  - Tires and Wheels  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/tires-and-wheels/86/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-c4-c5-corvette-emt-run-flat-tire-servicing-492.html</guid>
										<title>Technical Article: C4/C5 Corvette EMT Run-Flat Tire Servicing</title>
										<description><![CDATA[Description:This four page article details the proper method for servicing C4 and C5 Corvette EMT Run-Flat tires and comes from Hunter Engineering. Hunter Engineering Company is a world leader in automotive service equipment. Hunter Engineering...]]></description>
										<description><![CDATA[Run Flat Facts        Goodyear EMT tires are identified by this unique label.  Image:&nbsp; Author      by Hib Halverson  &copy;2004 all rights reserved.  The first run-flat tire was developed by Goodyear in 1978. The first application of a run-flat...]]></description>
										<description><![CDATA[The correct color code for the 1994 - 1995 Corvette ZR-1 5-spoke wheels is Dupont #C9201 or GM #WH9819.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-ltpws-parts-numbers-and-sensor-color-codes-revised-1105.html</guid>
										<title>1991 Corvette:  Service Bulletin:  LTPWS Parts Numbers and Sensor Color Codes Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-ltpws-parts-numbers-and-sensor-color-codes-revised-1105.html</link>
										<description><![CDATA[ Subject:  &nbsp; LTPWS Parts Numbers and Sensor Color Codes Revised   Model and Year: &nbsp;  1991 Corvette   Source:&nbsp;  Chevrolet Service Update Bulletin    Bulletin No:  &nbsp; 91-418-3E    Section:  &nbsp; 3E    Date:&nbsp;&nbsp;&nbsp;  Sept....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-ltpws-light-on-tire-pressure-is-correct-493.html</guid>
										<title>1990 Corvette: Service Bulletin: &quot;Service LTPWS&quot; Light On, Tire Pressure is Correct</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-ltpws-light-on-tire-pressure-is-correct-493.html</link>
										<description><![CDATA[Subject: 'SERVICE LTPWS' LIGHT ON, TIRE PRESSURE IS CORRECT Model and Year: 1990 CORVETTESource: Chevrolet Service BulletinBulletin Number: 90-389-3E - (12/31/1990)TO: ALL CHEVROLET DEALERSTHIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-tire-rotation-procedure-35.html</guid>
										<title>1989 Corvette:  Service Bulletin:  Tire Rotation Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-tire-rotation-procedure-35.html</link>
										<description><![CDATA[ Subject:  &nbsp; Tire Rotation Procedure   Model and Year:  &nbsp; 1989 Y Car with Optional Low Tire Pressure Warning System   Source:  &nbsp; Chevrolet Dealer Service Bulletin   Number:  &nbsp; 89-299-3E   Section:  &nbsp; 3E   Date:  &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-low-tire-pressure-warning-system-sensor-part-numbers-494.html</guid>
										<title>1989 - 1996 Corvette: Low Tire Pressure Warning System Sensor Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-low-tire-pressure-warning-system-sensor-part-numbers-494.html</link>
										<description><![CDATA[These part numbers refer to the low tire pressure warning system sensors that wrap around the wheels.1989-1992 ModelsRF (blue) - 10098494LF (green) - 10098495RR (orange) - 10098496LR (yellow) - 100984971993-1996 ModelsLR -10161854RF -10161855LF -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</guid>
										<title>1988 Corvette:  Product Safety Campaign:  Product Safety Campaign No. 88C09 - Possible Missing Wheel Weld</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-product-safety-campaign-product-safety-campaign-no-88c09-possible-missing-wheel-weld-1243.html</link>
										<description><![CDATA[Most early 1988 Corvette were involved in this safety recall on 17" wheels.&nbsp; This bulletin states that the first 8,432 1988 Corvettes with the Z-51 or Z-52 options could have 17" wheels with missing wheel welds.  Subject:  Product Safety...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Tires Slipping on Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-tires-slipping-on-wheels-495.html</link>
										<description><![CDATA[Subject: TIRES SLIPPING ON WHEELS (USE PROPER TIRE MOUNTING PROCEDURE) Model Year: 1988-93 ALL PASSENGER CARS AND LIGHT DUTY TRUCKSSource: Chevrolet Service BulletinNumber: 93-169-3ESome incidents of tires slipping (rotating) on wheels have been...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-dynamic-wheel-balance-496.html</guid>
										<title>1986 Corvette: Service Bulletin: Dynamic Wheel Balance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-dynamic-wheel-balance-496.html</link>
										<description><![CDATA[Model Year: 1986 CorvetteSubject: Dynamic Wheel BalanceSource: Chevrolet Dealer Service BulletinBulletin Number: 86-97, Section 3EDate: June, 1986TO: ALL CHEVROLET DEALERSAs of VIN G5 124200 (Coupe) and G5 900800 (Convertible), all Corvettes are...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-coated-wheel-weights-for-aluminum-wheels-497.html</guid>
										<title>1985 - 1991 Corvette: Service Bulletin: Coated Wheel Weights For Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-coated-wheel-weights-for-aluminum-wheels-497.html</link>
										<description><![CDATA[ Subject:  COATED WHEEL WEIGHTS FOR ALUMINUM WHEELS   Model and Year:  1985-91 MODELS WITH CAST ALUMINUM WHEELS   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-35-3E - (06/29/1990)  TO: ALL CHEVROLET DEALERS  THIS BULLETIN CANCELS AND...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Cast Aluminum Wheel Porosity Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-cast-aluminum-wheel-porosity-repair-82.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinSubject: Cast Aluminum Wheel Porosity RepairModel and Year: All Models with Cast Aluminum WheelsBulletin Number: 87-89Section: 3EDate: Mar., 1987TO: ALL CHEVROLET DEALERSShould a vehicle with&nbsp;cast...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-uneven-wear-outer-ribs-on-corvette-tires-40.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Uneven Wear-Outer Ribs on Corvette Tires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-uneven-wear-outer-ribs-on-corvette-tires-40.html</link>
										<description><![CDATA[Subject:&nbsp; Uneven Wear-Outer Ribs on Corvette TiresModel and Year:&nbsp;&nbsp;1984 - 1986&nbsp;CorvetteSource:&nbsp; Chevrolet Dealer Service BulletinNumber:&nbsp; 86-62Section:&nbsp; 3EDate:&nbsp; Apr., 1986 TO:&nbsp; ALL CHEVROLET DEALERS Some...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</guid>
										<title>1981 - 1990 Corvette:  Service Bulletin:  Procedures on Scuff/Scratch Removal from Clear Coat on Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-procedures-on-scuff-scratch-removal-from-clear-coat-on-aluminum-wheels-1061.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Procedures on Scuff/Scratch Removal from Clear Coat on Aluminum Wheels   Model and Year:    1981-85 Citation 1982-90 Cavalier 1985-88 Monte Carlo 1981-90 Caprice, Camaro, Corvette 1985-90 Celebrity 1990 Lumina   Source:&nbsp; ...]]></description>
