<title>Home - All Categories - C4 Corvettes  - Interior Parts and Trim  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/interior-parts-and-trim/82/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</guid>
										<title>Technical Article:  Inflatable Lumbar Seat Repair on C4 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</link>
										<description><![CDATA[One of the common problems with the inflatable lumbar seats is that the pump may fail. The pump may continue to work, but the air bladders located in the seat do not inflate. There is a rubber membrane within the pump which can puncture. Below are...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</guid>
										<title>1994 - 1996 Corvette:  Service Bulletin:  Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)   Models: &nbsp;  1994 - 1996 Chevrolet Corvette  Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:&nbsp;&nbsp; 63-16-03    Section:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</guid>
										<title>1992 Corvette: Recall: Instrument Panel/Left Hand Lower Trim/Brake Pedal Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</link>
										<description><![CDATA[ Subject:  PRODUCT CAMPAIGN 92C10 - INSTRUMENT PANEL LEFT HAND LOWER TRIM PANEL/BRAKE PEDAL INTERFERENCE   Model and Year:  1992 CHEVROLET CORVETTE   Source:  Chevrolet Product Campaign   Bulletin Number:  92C10 - (04/23/1992)  To: All Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<description><![CDATA[ Subject:  SQUEAK AND RATTLE DIAG. GUIDE DIAGNOSTIC AID/CORRECTION   Model and Year:  1991 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-264-10 - (03/25/1991) The following information is being distributed as an aid in squeak...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<description><![CDATA[Subject: S.I.R. SYSTEM DIAG. ENERGY RESERVE MODULE EXCHANGEModel and Year:1990 CAMARO, METRO (CONVERTIBLE ONLY), STORM 1991-92 CORSICA, BERETTA, CAMARO, CORVETTE, METRO (CONVERTIBLE ONLY), STORM AND CAPRICESource: Chevrolet Service BulletinBulletin...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</guid>
										<title>1990 - 1996 Corvette: Inner Door Panel Screw Locations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</link>
										<description><![CDATA[  The article and pictures here are used with permission by Craig Marcho, the author and photographer.        Find all the hidden screws on your '90+ door panel!    I had to remove the door panel on my '90 to fix a broken clip that connected the door...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Steering Wheel Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</link>
										<description><![CDATA[Subject: STEERING WHEEL REMOVAL SPECIAL TOOL USAGEModel and Year:1990-91 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-321-3B - (05/10/1991) If difficulty is noted in the removal of the steering wheel on 1990-91 Y-cars when using the...]]></description>
										<description><![CDATA[Subject: SIR SYSTEM SERVICE TIPS REVISED SYSTEM Model and Year:1991 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-107-9 - (10/25/1990) TO: ALL CHEVROLET DEALERS The 1991 Supplemental Inflatable Restraint (SIR) system on the Y car is...]]></description>
										<description><![CDATA[ Subject:  PROPER INSTALLATION AND SEATING OF THE SIR COIL ASSEMBLY   Model and Year:  1989-91 CAPRICE, CAMARO, CORVETTE, CORSICA AND BERETTA   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-204-3B - (01/23/1991)  CONDITION:  The lower...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Improved Access to Inboard Seat Belt Buckle / New Extender</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-improved-access-to-inboard-seat-belt-buckle-new-extender-506.html</link>
										<description><![CDATA[  Subject:  IMPROVED ACCESS TO INBOARD SEAT BELT BUCKLE/NEW EXTENDER   Model and Year:  1989-90 CORVETTE WITH AQ9 SEATS   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-291-10 - (06/22/1990)    CONDITION:    To increase customer...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</guid>
										<title>1988 Corvette: Service Bulletin: 1988 Anniversary Model: Discolored Door Armrest</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</link>
										<description><![CDATA[Model Year: 1988 Y-Car Anniversary ModelSubject: Discolored Door ArmrestSource: Chevrolet Dealer Service BulletinBulletin Number: 88-399-10, Section 10Date: April, 1989TO: ALL CHEVROLET DEALERSOwners of 1988 Corvette "Anniversary Edition" models who...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-dealer-installed-anchor-for-child-seat-with-top-strap-anchor-installation-945.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-dealer-installed-anchor-for-child-seat-with-top-strap-anchor-installation-945.html</link>
										<description><![CDATA[ Subject:  &nbsp; Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation   Model and Year: &nbsp;  1984 Corvette   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:&nbsp;  84-121    Section:  &nbsp; 10 (I) ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-sun-visor-repair-tips-149.html</guid>
										<title>1984 - 1996 Corvette: Sun Visor Repair Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-sun-visor-repair-tips-149.html</link>
										<description><![CDATA[From Jerry Watts, Retired Corvette Action Center engineer:The windshield sun visor on a C4 has a fold about four inches from the windshield post where the visor rests when not in use.&nbsp; After some time, this fold may get weak, allowing the end of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</guid>
										<title>1984 - 1991 Corvette: Recall: Left &amp; Right Side Safety Belt Retractor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</link>
										<description><![CDATA[Source: Chevrolet Product CampaignNumber: 91C25 &amp; 91C26Subject: PRODUCT SAFETY CAMPAIGN 91C25 &amp; 91C26 SAFETY BELT RETRACTORS (LEFT SIDE - 91C25; RIGHT SIDE - 91C26)Model and Year: 1984-91 CHEVROLET CORVETTEThe National Traffic and Motor...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Service Part For Seat Cushion Retaining Wire</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-service-part-for-seat-cushion-retaining-wire-507.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  90-154-10   Subject:  Service Part For Seat Cushion Retaining Wire   Model Year:  1984-1990 Y Car   GMSPO has released for service a cushion retainer wire service kit, P/N 10153686. On current...]]></description>
										<description><![CDATA[  Subject:  POWER SEAT INOP/BLOWS FUSES REPAIR/REPLACE HARNESS   Model and Year:  1984-90 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-412-10 - (03/18/1991)    Condition:    Power Seat (AQ9) inoperative and/or blows fuse.   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</guid>
										<title>1984 - 1989 Corvette: Digital Dash Cluster Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<description><![CDATA[From Bob Golden: My name is Bob Golden and my home e-mail is &lt;withheld&gt;.&nbsp; I wanted you to now how I enjoyed reading your publication on the repairs of the famous digital cluster. For 20 years I was the General manager at Speedometer...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Loose Corvette Door Trim Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</link>
										<description><![CDATA[  Model Year:  1984-1987   Subject:  Loose Corvette Door Trim Panel   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  87-116, Number 10   Date:  April, 1987   TO: ALL CHEVROLET DEALERS   Some 1984-87 Corvette door trim pads may be...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-rattle-from-turn-signal-lever-1202.html</guid>
										<title>1984 - 1987 Corvette:  Service Bulletin:  Rattle From Turn Signal Lever</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-rattle-from-turn-signal-lever-1202.html</link>
										<description><![CDATA[ Subject:  Rattle From Turn Signal Lever   Model and Year:  1983 - 1987 Chevrolet Vehicles with Multi-Function Turn Signal Levers   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  87-224, Section 10   Date:  &nbsp; Oct., 1987 TO:&nbsp;...]]></description>
										<description><![CDATA[ Subject:  &nbsp; Power Seat Transmission Usage and Identification   Model and Year: &nbsp;  1984 to 1987 Corvettes   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:&nbsp;&nbsp;  87-86    Section:  &nbsp; 9    Date:&nbsp;&nbsp;&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-seat-adjuster-excessive-movement-511.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Seat Adjuster Excessive Movement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-seat-adjuster-excessive-movement-511.html</link>
										<description><![CDATA[Subject: Power Seat Adjuster - Excessive MovementModel and Year: 1984 - 1986&nbsp;CorvetteSource: Chevrolet Dealer Sevice&nbsp;BulletinBulletin Number: 86-117, Section 9 &amp; 8BDate:&nbsp;July, 1986 TO:&nbsp; ALL CHEVROLET DEALERS Customer comments...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1990-corvette-service-bulletin-loose-carpet-on-side-wall-trim-pads-repair-procedure-683.html</guid>
										<title>1980 - 1990 Corvette: Service Bulletin: Loose Carpet on Side Wall Trim Pads (Repair Procedure)</title>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 90-92-10Subject: Loose Carpet on Side Wall Trim Pads (Repair Procedure)Model Year: 1980-90 A, B, F, J, L, W, X, Y CarsCarpet inserts attached to side wall, door, quarter and tailgate trim panels which...]]></description>
