<title>Home - All Categories - C4 Corvettes  - Electrical and Ignition  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/electrical-and-ignition/66/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
										<description><![CDATA[1996: Engine Diagnostic Trouble Codes DTC P0100 MAF Sensor Circuit Insufficient Activity DTC P0101 Mass Air Flow (MAF) Sensor Performance DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency DTC P0103 Mass Air Flow (MAF) Sensor Circuit High...]]></description>
										<description><![CDATA[This information applies to 1996-2005 passenger cars, trucks and utilities.In the past, star washers have been used under most ground connections. It was believed using a star washer would improve continuity to ground and prevent the ground fastener...]]></description>
										<description><![CDATA[Subject: Starter Clicks, Engine Doesn't Start (Replace CCM)Model and Year: 1995 Chevrolet Corvette Prior to Vin Breakpoint S5110803Source: Chevrolet Dealer Service BulletinBulletin Number: 53-64-02CONDITION:THE STARTER WILL CLICK, BUT THE ENGINE WILL...]]></description>
										<description><![CDATA[ Subject:&nbsp;  Passive Keyless Entry   Model and Year:&nbsp;  1995 - 2004 Corvette   Source:&nbsp;  Chevrolet Pro Service News   Page Number:  &nbsp; 2   Date:&nbsp;  May 1998 - Volume 7 - Number 5
]]></description>
										<description><![CDATA[Subject: Left Rear Engine Wiring Harness RoutingModel and Year: 1994 Corvette with LT1 EngineSource: Product CampaignBulletin Number: 94C2194C21 MARCH, 1994PRODUCT CAMPAIGN 94C21 - LEFT REAR ENGINE WIRING HARNESS ROUTING1994 CORVETTE WITH LT1...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</guid>
										<title>1994 - 1996 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</link>
										<description><![CDATA[DTC #11:&nbsp; Malfunction Indicator Lamp Circuit.DTC #13:&nbsp; Bank #1 Heated Oxygen Sensor #1 Circuit: DTC #14:&nbsp; Engine Coolant Temperature Sensor Circuit Voltage Low.DTC #15:&nbsp; Engine Coolant Temperature Sensor Circuit Voltage High.DTC ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</guid>
										<title>1993 - 1996 Corvette: Service Bulletin: Shortened Range With Passive Keyless Entry (PKE) Transmitter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</link>
										<description><![CDATA[Model Year: 1993-96 CHEVROLET CORVETTESource: Chevrolet Dealer Service BulletinBulletin Number: 63-90-09CUSTOMERS MAY COMMENT THAT THE PASSIVE KEYLESS ENTRY (PKE) RANGE IS VERY SHORT AT TIMES - SOMETIMES ALMOST ZERO. AT OTHER TIMES, THE RANGE WILL BE...]]></description>
										<description><![CDATA[Subject: ENGINE BACKFIRE DURING W.O.T. 1-2 UPSHIFT (RPL. MEMCAL)Model and Year: 1992 CORVETTE WITH 5.7L ENGINE (RPO LT1) AND AUTOMATIC TRANSMISSIONSource: Chevrolet Service BulletinBulletin Number: 92-336-6E - (12/01/1992) CONDITION: Some owners of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</guid>
										<title>1992 Corvette: Recall: Optispark Distributor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</link>
										<description><![CDATA[ Subject:  OPTI-SPARK DIST. (REPLACE WITH NEW P/N)   Model and Year:  1992 CHEVROLET CORVETTE W/ LT1 ENGINE   Source:  Chevrolet Product Emission Campaign   Bulletin Number:  92C11 - (06/15/1992)  To: All Chevrolet Dealers  General Motors has...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<description><![CDATA[Description:This article was written by Mike Chaney who is a contributor to the F-body Listserv. He has done an excellent dissection of an Optispark distributor which appeared on 1992 - 1996 LT1 Corvettes. Below, he describes the replacement of an...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</guid>
										<title>1992 - 1996 Corvette: Service Bulletin: Engine Miss/Poor Driveability Symptoms</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</link>
										<description><![CDATA[Subject: Engine Miss/Poor Driveability Symptoms (Install Opti-Spark (ABITS) Distributor Assembly Service Kit)Model and Year:1994-96 Buick Roadmaster1994-96 Cadillac Fleetwood1992-96 Chevrolet Corvette1993-97 Chevrolet Camaro1994-96 Chevrolet...]]></description>
										<description><![CDATA[Source:&nbsp; Corvette ABS/ASR Operation and Diagnosis, STG Manual 13003.02-1Page:&nbsp; 4-5, 4-6Copyright: 1991, General Motors Corporation Code-Based Diagnosis &nbsp;   CodeDescriptionDisable  21 RF Wheel Speed Sensor Fault ABS/ASR   23 RF Wheel...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</guid>
										<title>1992 - 1993 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</link>
										<description><![CDATA[Code #12:&nbsp; Normal No Codes.Code #13:&nbsp; Left Oxygen Sensor Circuit.Code #14:&nbsp; Coolant Temperature Sensor Circuit High.Code #15:&nbsp; Coolant Temperature Sensor Circuit Low.Code #16:&nbsp; Opti-Spark Ignition Timing System.( Low Pulse...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</guid>
										<title>1991 Corvette: Service Bulletin: Information / Installation of Underhood / Courtesy Lamp</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</link>
										<description><![CDATA[ Subject:  INFORMATION/INSTALLATION OF UNDERHOOD/COURTESY LAMP FUSE   Model and Year:  1991 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-116-8C - (11/14/1990)  TO: ALL CHEVROLET DEALERS  The underhood lamp fuse on the 1991 Y...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</guid>
										<title>1991 Corvette: Service Bulletin: Delayed Accessory Bus (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</link>
										<description><![CDATA[Subject: DELAYED ACCESSORY BUS (DAB) SERVICE INFORMATION Model and Year:1991 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-115-8B - (01/15/1991) The 1991 Corvette is equipped with a Delayed Accessory Bus (DAB) which allows operation...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Starter Inoperative/Clicks/No Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</link>
										<description><![CDATA[  Subject:  Starter Inoperative/Clicks/No Start   Model and Year:  1991-92 Corvette with Automatic Transmission   Source:  Chevrolet Service Bulletin   Bulletin Number:  92-322-6D    Condition:    The starter may not operate (no sound), or may click ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
										<description><![CDATA[Subject: S.I.R. SYSTEM DIAG. ENERGY RESERVE MODULE EXCHANGEModel and Year:1990 CAMARO, METRO (CONVERTIBLE ONLY), STORM 1991-92 CORSICA, BERETTA, CAMARO, CORVETTE, METRO (CONVERTIBLE ONLY), STORM AND CAPRICESource: Chevrolet Service BulletinBulletin...]]></description>
										<description><![CDATA[  Subject:  SERV MANUAL UPDATE-SEC.6E3 DRIVEABILITY AND EMISSIONS   Model and Year:  1990 CORVETTE WITH 5.7L L98 (VIN CODE 8) ENGINE   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-350-6E - (09/13/1990)   The attached Code 34 diagnostic...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</guid>
										<title>1990 Corvette: Service Manual Update: SEC. 6D4 Spark Plug Coding Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
										<description><![CDATA[Subject: SERVICE MANUAL UPDATE-SEC. 6D4 SPARK PLUG CODING CHART Model and Year: 1990 CORVETTESource: Chevrolet Service BulletinBulletin Number: 90-253-6D - (06/26/1990)The Spark Plug Coding Chart shown in Figure 2, Page 6D4-3, in Section 6D4 ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<description><![CDATA[Subject: TECH 1 REVISED ODOMETER RECALIBRATION PROCEDURE Model and Year: 1990 CorvetteSource: Chevrolet Service BulletinBulletin Number: 90-373-8C - (11/21/1990)TO: ALL CHEVROLET DEALERSTHIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN NO....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Revised Code 42 Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  90-229-9   Subject:  Service Manual Update - SIR Revised Code 42 Chart   Model Year:  1990 Y Car   This bulletin serves to revise the Code 42 Chart on page 9J-A-43 in Section 9J-A "Supplemental...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  90-175-6D   Subject:  Service Manual Update Sec. 6D1 - Battery Spec. Chart   Model Year:  1990 Y Car   This bulletin reflects revisions made to the General Specifications Chart which appears in...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<description><![CDATA[Subject: TECH 1 REVISED ODOMETER RECALIBRATION PROCEDUREModel and Year: 1990 CORVETTESource: Chevrolet Service BulletinBulletin Number: 90-373-8C - (11/21/1990) TO: ALL CHEVROLET DEALERS THIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN NO...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<description><![CDATA[#93-163-8A - REPLACEMENT OF ISOLATION DIODESMANY OF THE ELECTRICAL SYSTEMS ON OUR VEHICLES USE A DIODE TO ISOLATE CERTAIN CIRCUITS AND PROTECT THEM FROM VOLTAGE SPIKES. SOME OF THE CIRCUITS WHICH MAY USE SUCH A DIODE ARE LISTED BELOW:* A/C COMPRESSOR...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</guid>
										<title>1990 Corvette: Service Bulletin: Radio May Lose Some Functions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</link>
										<description><![CDATA[Subject:&nbsp;RADIO MAY LOSE SOME FUNCTIONS&nbsp;Model and Year: 1990 CORVETTESource: Chevrolet Dealer Service BulletinBulletin Number: 90-360-9ASection: 9ADate: October 1990Corporate Bulletin No.: 039004TO: ALL CHEVROLET DEALERSCondition:The radio...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</guid>
										<title>1990 Corvette: Service Bulletin: Inflatable Restraint Indicator Lamp Stays On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<description><![CDATA[Subject: INFLATABLE RESTRAINT INDICATOR LAMP STAYS ON Model and Year: 1990 Y CARSource: Chevrolet Service BulletinBulletin Number: 90-98-0A - (01/03/1990) CONDITION: The "INFL REST" indicator lamp may stay lit after the 5 second (ignition on) bulb...]]></description>
										<description><![CDATA[ Subject:  SERVICE MANUAL UPDATE SEC. 5E1 ABS DIAGNOSIS-REVISED CODE 63   Model and Year:  1990 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-430-5 - (08/21/1991) This bulletin serves to update the ABS Code 63 (Page 1 of 3)...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</guid>
										<title>1990 Corvette: Recall: Product Campaign 90C07 Instrument Panel Wire Abrasion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</link>
										<description><![CDATA[  Model Year:  1990 w/ L98 or LT5 Engine   Subject:  Product Campaign 90C07 Instrument Panel Wire Abrasion   Source:  Chevrolet Dealer Product Campaign Bulletin   Number:  90C07   Section:  &nbsp; 8C   Date:  January, 1990   TO: ALL CHEVROLET DEALERS...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<description><![CDATA[Subject: CAMPAIGN: INSTRUMENT PANEL WIRE ABRASION - REPAIR Model and Year: 1990 CHEVROLET CORVETTE W/ L98 OR LT5 ENGINESource: Chevrolet Service BulletinBulletin Number: 90-C-07 - (01/17/1990) General Motors has determined that certain 1990 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</guid>
										<title>1990 - 1991 Corvette: Service Information: Service Tips for Supplemental Inflatable Restraint (SIR)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</link>
										<description><![CDATA[Subject: SERVICE TIPS FOR SUPPLEMENTAL INFLATABLE RESTRAINT (SIR) Model and Year: 1991 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-107-9Section: 9Date: (November 1990)Corporate Bulletin No.: 039007 TO: ALL CHEVROLET DEALERSThe 1991...]]></description>
										<description><![CDATA[Subject: SIR SYSTEM SERVICE TIPS REVISED SYSTEM Model and Year:1991 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-107-9 - (10/25/1990) TO: ALL CHEVROLET DEALERS The 1991 Supplemental Inflatable Restraint (SIR) system on the Y car is...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Radio May Lose Some Functions, Inspect Radio Fuse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</link>
										<description><![CDATA[Subject: RADIO MAY LOSE SOME FUNCTIONS INSPECT RADIO FUSE Model and Year: 1990-91 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-229A-9A - (06/01/1992)THIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN NO. 91-229-9A DATED...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Radio Condition Remove/Replace Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</link>
										<description><![CDATA[Subject: INTERMITTENT RADIO CONDITION REMOVE/REPLACE RADIO Model and Year:1990-91 CORVETTESource: Chevrolet Service BulletinBulletin Number: 91-343-9A - (06/03/1991) Condition: The radio on the 1990-91 Y Car may show one or more of several...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-electrical-conditions-repair-diagnosis-procedures-532.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Electrical Conditions - Repair/Diagnosis Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-electrical-conditions-repair-diagnosis-procedures-532.html</link>
										<description><![CDATA[ Subject:  INTERMITTENT ELECT. CONDITIONS REPAIR/DIAGNOSIS PROCEDURES   Model and Year:  1990-91 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-337-6D - (05/30/1991)  Condition:  The electrical system on the 1990-91 Y Car may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</guid>
										<title>1989 Corvette: Service Bulletin: Bose Amplifiers Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 89-218-9ASection: 9ADate: July, 1989Subject: Service Program for Bose Amplifiers and EnclosuresModel and Year: 1989 F and Y CarsTO: ALL CHEVROLET DEALERSBose amplifiers are no longer repaired under...]]></description>
										<description><![CDATA[ Subject:  PROPER INSTALLATION AND SEATING OF THE SIR COIL ASSEMBLY   Model and Year:  1989-91 CAPRICE, CAMARO, CORVETTE, CORSICA AND BERETTA   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-204-3B - (01/23/1991)  CONDITION:  The lower...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-new-delco-loc-ii-setting-procedure-and-information-571.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: New Delco-Loc II Setting Procedure and Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-new-delco-loc-ii-setting-procedure-and-information-571.html</link>
										<description><![CDATA[Subject: NEW DELCO-LOC II SETTING PROCEDURE &amp; INFORMATION Model and Year:1989-91 CAMARO AND CORVETTE1990-91 U-VAN (APV)Source: Chevrolet Service BulletinBulletin Number: 91-138-9A - (12/31/1990) TO: ALL CHEVROLET DEALERS THIS BULLETIN CANCELS AND...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-wiper-motor-starts-in-high-speed-only-572.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Wiper Motor Starts in High Speed Only</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-wiper-motor-starts-in-high-speed-only-572.html</link>
										<description><![CDATA[  Subject:  WIPER MOTOR STARTS IN HIGH SPEED ONLY   Model and Year:  1989-90 CELEBRITY CAMARO, CORSICA, BERETTA, LUMINA AND CORVETTE   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  90-420-8E   THIS BULLETIN CANCELS AND SUPERSEDES...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<description><![CDATA[Subject: POWER ANTENNA MAY NOT RETRACT SEND RADIO TO DELCO FOR REPAIR Model and Year:1989-90 CAMARO,CORVETTE 1989-90 C/K TRUCK 1990 U VAN (These are the car and truck lines affected:&nbsp; F, Y; C/K, and U Van Trucks)Source: Chevrolet Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-intermittent-no-start-no-crank-diagnostic-service-procedure-574.html</guid>
										<title>1988 - 1991 Corvette: Service Bulletin: Intermittent No-Start/No-Crank Diagnostic Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-intermittent-no-start-no-crank-diagnostic-service-procedure-574.html</link>
										<description><![CDATA[Subject: INTERMITTENT NO-START/NO-CRANK DIAGNOSTIC SERVICE PROCEDURE Model and Year:1988-91 CORVETTE WITH 5.7L ENGINESource: Chevrolet Service BulletinBulletin Number: 91-231-6D - (02/26/1991) Condition: An intermittent no start condition, with no...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<description><![CDATA[Subject: INTERMITTENT NO START/CRANKS REPLACE MASS AIR FLOW RELAYS Model and Year: 1988-89 CHEVROLET CORVETTESource: Chevrolet Service BulletinBulletin Number: 89-327-6D - (07/10/1991) Condition: On the 1988 - 89 Y Car, the engine may have...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</guid>
										<title>1987 Corvette:  Service Bulletin:  Engine Harness Cut by Casting Flash on Transmission Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Engine Harness Cut by Casting Flash on Transmission Housing   Model and Year: &nbsp;  1987 Corvette   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 87-207    Section:  &nbsp; 8A    Date:&nbsp;&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-v-a-t-key-replacement-575.html</guid>
										<title>1986 Corvette: Service Bulletin: V.A.T. Key Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-v-a-t-key-replacement-575.html</link>
										<description><![CDATA[Model Year: 1986Subject: Key Replacement for Vehicles with Vehicle Anti-Theft System (VATS)Source: Chevrolet Dealer Service BulletinNumber: 86-38, Section 8ADate: Feb., 1986To: ALL CHEVROLET DEALERSThis bulletin is to inform dealers of the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<description><![CDATA[Subject: Spark Plug Service on Engines with Aluminum HeadsModel and Year: 1986&nbsp;Corvette 5.7 L PFI L98 (VIN&nbsp;Code 8) EngineSource: Chevrolet Dealer Sevice&nbsp;BulletinBulletin Number: 86-82, Section 6ADate:&nbsp;May, 1986 TO:&nbsp; ALL...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-product-campaign-86co2-a-reissue-vehicle-anti-theft-system-vats-1016.html</guid>
										<title>1986 Corvette:  Product Campaign 86CO2(a) Reissue: Vehicle Anti Theft System (VATS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-product-campaign-86co2-a-reissue-vehicle-anti-theft-system-vats-1016.html</link>
										<description><![CDATA[This product campaign bulletin is for 1986 Corvette coupes.&nbsp; The serial number range is from 1986 Corvette coupe #1 to #3,700.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Power Antenna Will Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 88-209-9ASection:&nbsp; 9ADate: May, 1988Subject: POWER ANTENNA WILL NOT RETRACTModel and Year:&nbsp; 1986-88 CORVETTE WITH ADVANCED ELECTRONICALLY TUNED RADIO AND POWER ANTENNA (U65)TO:&nbsp; ALL...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<description><![CDATA[Subject: Low Coolant Warning LightNumber: 88-43Section:&nbsp; 6BDate:&nbsp; Sept., 1987Models: 1986-88 CorvettesTo: All Chevrolet Dealers This bulletin cancels and supersedes Dealer Service Bulletin 87-11 (Section 6B) dated Oct., 1986.&nbsp; All...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 87-140Section: 8ADate: May, 1987Subject: INTERMITTENT NO-START CONDITION CAUSED BY THE VEHICLE ANTI-THEFT SYSTEM (VATS)Model Year: 1986-1987 CorvetteTO: ALL CHEVROLET DEALERSSome 1986-1987 Corvettes...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-high-output-ignition-coil-replacement-578.html</guid>
										<title>1985 Corvette: Service Bulletin: High Output Ignition Coil Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-high-output-ignition-coil-replacement-578.html</link>
										<description><![CDATA[Subject: High Output Ignition Coil ReplacementModel and Year: 1985 L69 Camaro and Monte Carlo, 1985 LB9 Camaro and 1985 L98 CorvetteSource: Chevrolet Service BulletinBulletin Number: 85-93 - June, 1985 TO:&nbsp; ALL CHEVROLET DEALERS Some 1985 Camaro...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</guid>
										<title>1985 - 1991 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</link>
										<description><![CDATA[Code #12: Normal No Codes.Code #13: Open Oxygen Sensor Circuit.Code #14: Coolant Sensor Circuit Low.Code #15: Coolant Sensor Circuit High.Code #21: Throttle Position Sensor High.Code #22: Throttle Position Sensor Low.Code #23: Manifold Air...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1988-corvette-service-bulletin-damage-to-wiring-terminals-on-engine-sensors-metri-pack-150-series-1242.html</guid>
										<title>1985 - 1988 Corvette:  Service Bulletin:  Damage to Wiring Terminals on Engine Sensors - Metri-Pack 150 Series</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1988-corvette-service-bulletin-damage-to-wiring-terminals-on-engine-sensors-metri-pack-150-series-1242.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  Damage to Wiring Terminals on Engine Sensors - Metri-Pack 150 Series   Model and Year:  1985-88 All Vehicles   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  88-101-8a, Number 8A   Date:  &nbsp; Dec., 1987 TO:...]]></description>
										<description><![CDATA[Model Year: 1984 Corvettes with Automatic TransmissionSubject: Low Speed "Chuggle"Source: Chevrolet Dealer Service BulletinBulletin Number: 84-208, Section 6E, 7A (Vlt) (Vllc)Date: October, 1984TO: ALL CHEVROLET DEALERSSome 1984 Corvettes may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</guid>
										<title>1984 Corvette: Recall: Positive Battery Cable Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</link>
										<description><![CDATA[  Model Year:  1964 Corvette   Subject:  Product Safety Campaign 84C04 Positive Battery Cable Routing   Source:  Chevrolet Dealer Product Campaign Bulletin   Number:  84C04, Number XII   Date:  August, 1983
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<description><![CDATA[Electrical schematics for the 1984 Corvette - linked below (3.09MB Zip file):1984 Schematics
]]></description>
										<description><![CDATA[Code #12:&nbsp; Normal System No Codes.Code #13:&nbsp; Oxygen Sensor Circuit.Code #14:&nbsp; Coolant Sensor Circuit Low.Code #15:&nbsp; Coolant Sensor Circuit High.Code #21:&nbsp; Throttle Position Sensor High.Code #22:&nbsp; Throttle Position Sensor...]]></description>
										<description><![CDATA[The following article/comment was submitted to the Corvette Action Center:-----------------------------------------------------From: Mike Flaherty &lt;383_240z@surewest.net&gt;On the bottom right of page 6D-26, engine electrical, it tells you to...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Defogger Circuit Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</link>
										<description><![CDATA[ It should be noted that if your Corvette still has this problem, this Bulletin offers the exact fix with related wiring diagrams.&nbsp; This repair work is NOT for the average "do-it-yourselfer" and should only be conducted by qualified service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Generator Noise (Moan) at Idle with Air Conditioning On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  Generator Noise (Moan) at Idle with Air Conditioning "On"   Model and Year:  1984 Corvette   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  84-151, Section 6D (VIy)   Date:  &nbsp; June 1984 TO:&nbsp; ALL...]]></description>
										<description><![CDATA[ Subject:  &nbsp; Engine Stops Running When Starting with Air Conditioning "On"   Model and Year:  &nbsp; 1984 Corvette with Automatic Transmissions   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 84-240     Section:  &nbsp...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<description><![CDATA[Model Year:&nbsp;  1984 Corvette   Subject: &nbsp; Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly   Source:&nbsp;  Chevrolet Dealer Product Campaign Bulletin   Number:&nbsp; 84C22, Section 6D   Date: &nbsp;March, 1985      ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<description><![CDATA[  TransmissionGear RatioDrive GearColor# of TeethDriven GearColor# of TeethVehicle Speed Sensor 1984  MD8 with Export (VB4, VD1, VE1, VT7) 3.07 8640517 Red 17 25513047 Black 40 25007308   MD8 except Export (VB4, VD1, VE1, VT7) 3.07 8640517 Red 17...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</guid>
										<title>1984 - 1996 Corvette:  Wiring and Circuit Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
										<description><![CDATA[Below are tables showing the identification of wiring and circuits for 1984 - 1996 Corvettes:  &nbsp;
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Cleaning and Lubricating Power Antenna Mast Sections   Model and Year: &nbsp;  All Models with Power Antenna   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 84-159    Section:  &nbsp; 9    Date:&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-underhood-lamps-inoperative-or-staying-on-581.html</guid>
										<title>1984 - 1990 Corvette: Service Bulletin: Underhood Lamps Inoperative or Staying On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-underhood-lamps-inoperative-or-staying-on-581.html</link>
										<description><![CDATA[  Model Year:  1984-1990 Y-Car   Subject:  Underhood Lamps Inoperative or Staying On   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  90-248-8B   Date:  05-07-1990    Condition:    Underhood lamps that are inoperative, or that stay on...]]></description>
										<description><![CDATA[  Subject:  POWER SEAT INOP/BLOWS FUSES REPAIR/REPLACE HARNESS   Model and Year:  1984-90 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-412-10 - (03/18/1991)    Condition:    Power Seat (AQ9) inoperative and/or blows fuse.   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</guid>
										<title>1984 - 1989 Corvette: Digital Dash Cluster Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<description><![CDATA[From Bob Golden: My name is Bob Golden and my home e-mail is &lt;withheld&gt;.&nbsp; I wanted you to now how I enjoyed reading your publication on the repairs of the famous digital cluster. For 20 years I was the General manager at Speedometer...]]></description>
										<description><![CDATA[ Subject:  &nbsp; Power Seat Transmission Usage and Identification   Model and Year: &nbsp;  1984 to 1987 Corvettes   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:&nbsp;&nbsp;  87-86    Section:  &nbsp; 9    Date:&nbsp;&nbsp;&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<description><![CDATA[Subject: Electric Outside Rear View MirrorsModel and Year: 1984 - 1986&nbsp;CorvetteSource: Chevrolet Dealer Sevice&nbsp;BulletinBulletin Number: 86-176, Section 8BDate: Oct., 1986 TO:&nbsp; ALL CHEVROLET DEALERS Customer comments of inoperative...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<description><![CDATA[  Model Year:  1984-1985   Subject:  Door Ajar Switch Corrosion   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  85-43, Number 8B (XII) &amp; 10(I)   Date:  Feb., 1985    TO: ALL CHEVROLET DEALERS    SOME 1984 AND EARLY PRODUCTION...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-recall-notice-product-emission-campaign-85c22-high-output-ignition-coil-1130.html</guid>
										<title>1984 - 1985 Corvette:  Recall Notice: Product Emission Campaign 85C22 High Output Ignition Coil</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-recall-notice-product-emission-campaign-85c22-high-output-ignition-coil-1130.html</link>
										<description><![CDATA[ Subject:&nbsp;  Product Emission Campaign 85C22 High Output Ignition Coil   Model and Year:&nbsp;  1984 - 1985 Chevrolet Camaro Models with 5.0L V8 (RPO L69/LB9),  1985 Monte Carlo Models with 5.0L V8 (RPO L69) and 1984-85 Corvette Models With 5.7L...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<description><![CDATA[Source:&nbsp; Chevrolet Dealer Service BulletinNumber: 91-14-8ASubject: Parasitic Drain on Battery Ammeter Connecting ProcedureModel Year: 1982-91 All Passenger Cars and TrucksVehicles that have one or more on-board solid state control module (such...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<description><![CDATA[Subject: DAMAGED ECM/PCM AND/OR MIS-DIAGNOSED ECM/PCM SYMPTOMS DUE TO INCORRECT "TAP-TESTING" PROCEDURESModel and Year:1982-91 ALL PASSENGER CARS AND TRUCKSSource: Chevrolet Service BulletinBulletin Number: 91-384-6E - (07/24/1991) CONDITION: Because...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<description><![CDATA[ Subject:  CHECKING CONNECTOR TERMINAL CONTACT - METRI - PACK   Model and Year:  1982-91 PASSENGER CARS AND TRUCKS   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-85-8A - (09/21/1990)  TO: ALL CHEVROLET DEALERS  When diagnosing an...]]></description>
										<description><![CDATA[Subject: Engine Miss, Hesitation, and Rough, Pierced Secondary Ignition ComponentsModel and Year: 1980-93 ALL PASSENGER CARS AND TRUCKSSource: Chevrolet Service BulletinBulletin Number: 93-35-6D - (10/01/1992) THIS BULLETIN CANCELS AND SUPERSEDES...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<description><![CDATA[ Subject:  &nbsp; Power Antenna Rod and Cable Service Package   Model and Year: &nbsp;  1979-81 Malibu, 1979-84 Impala, Caprice, Camaro and Corvette - 1981-82 Citation, 1982-84 Monte Carlo and El Camino   Source:&nbsp;  Chevrolet Dealer Service...]]></description>
