<title>Home - All Categories - C3 Corvettes  - Electrical and Ignition  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c3-corvettes/electrical-and-ignition/65/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</guid>
										<title>2006 Corvette:  Electrical Schematic: Wiper Washer System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</link>
										<description><![CDATA[Attached below are two electrical schematics of the wiper washer system for the 2006 Corvette in PDF format.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</link>
										<description><![CDATA[ Subject:  Fuel injection Diagnosis Chart   Model and Year:&nbsp;  1982 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:&nbsp;  Page 5   Date:&nbsp;  January/February 1983 - Volume 55 - Number 1
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</guid>
										<title>1982 Corvette: Service Bulletin: Spark Plug Fouling/Driveability Improvements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</link>
										<description><![CDATA[Subject: SPARK PLUG FOULING/DRIVEABILITY IMPROVEMENTS - 1982 CORVETTE WITH FEDERAL EMISSIONSModel and Year: 1982 Corvette with Federal EmissionsSource: Chevrolet Dealer Service Technical BulletinBulletin Number: 82-T-101Number: VItSection: Aug.,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</guid>
										<title>1982 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</link>
										<description><![CDATA[Code #12:&nbsp; Normal System No Codes.Code #13:&nbsp; Oxygen Sensor Circuit.Code #14:&nbsp; Coolant Sensor Circuit Low.Code #15:&nbsp; Coolant Sensor Circuit High.Code #21:&nbsp; Throttle Position Sensor High.Code #22:&nbsp; Throttle Position Sensor...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<description><![CDATA[Source:&nbsp; Chevrolet Dealer Service BulletinNumber: 91-14-8ASubject: Parasitic Drain on Battery Ammeter Connecting ProcedureModel Year: 1982-91 All Passenger Cars and TrucksVehicles that have one or more on-board solid state control module (such...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<description><![CDATA[Subject: DAMAGED ECM/PCM AND/OR MIS-DIAGNOSED ECM/PCM SYMPTOMS DUE TO INCORRECT "TAP-TESTING" PROCEDURESModel and Year:1982-91 ALL PASSENGER CARS AND TRUCKSSource: Chevrolet Service BulletinBulletin Number: 91-384-6E - (07/24/1991) CONDITION: Because...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<description><![CDATA[ Subject:  CHECKING CONNECTOR TERMINAL CONTACT - METRI - PACK   Model and Year:  1982-91 PASSENGER CARS AND TRUCKS   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-85-8A - (09/21/1990)  TO: ALL CHEVROLET DEALERS  When diagnosing an...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-vehicle-speed-sensor-servicing-677.html</guid>
										<title>1981 Corvette: Service Bulletin: Vehicle Speed Sensor Servicing</title>
										<description><![CDATA[Subject: Vehicle Speed Sensor ServicingModel and Year: 1981 CorvettesSource: Chevrolet Dealer Service Information BulletinBulletin Number: 81-I-17Section: VItDate:&nbsp; January, 1981 TO:&nbsp; ALL CHEVROLET DEALERS Beginning with the 1980 1/2 model...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</guid>
										<title>1981 Corvette: Service Bulletin: Glow Around Wiper Switch Rework Wiper Switch Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</link>
										<description><![CDATA[  Subject:  GLOW AROUND WIPER SWITCH REWORK WIPER SWITCH BEZEL   Model and Year:  1981 Corvette   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  81-I-19   Section:  I   Date:  January 1981   SOME EARLY 1981 CORVETTES WITH SILVER, RED,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</guid>
										<title>1981 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-ecm-codes-693.html</link>
										<description><![CDATA[Code #12: No Distributor Reference Pulse. Code #13: Oxygen Sensor Circuit.Code #14: Shorted Coolant Sensor Circuit.Code #15: Open Coolant Sensor Circuit.Code #21: Throttle Position Sensor Circuit.Code #23: Mixture Control Solenoid Circuit.Code #24:...]]></description>
										<description><![CDATA[Subject: Engine Miss, Hesitation, and Rough, Pierced Secondary Ignition ComponentsModel and Year: 1980-93 ALL PASSENGER CARS AND TRUCKSSource: Chevrolet Service BulletinBulletin Number: 93-35-6D - (10/01/1992) THIS BULLETIN CANCELS AND SUPERSEDES...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</guid>
										<title>1979 Corvette: Service Bulletin: Halogen Sealed Beams</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</link>
										<description><![CDATA[Subject:&nbsp; Halogen Sealed BeamsModel Year:&nbsp; 1979 Chevrolet and CorvetteDate:&nbsp; January 1979Bulletin Number: 79-I-4, Section XII TO:&nbsp; ALL CHEVROLET DEALERS This Bulletin is being reissued for P/N correction.&nbsp; The Corvette P/N...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
										<description><![CDATA[ Subject:  Corvette Auxilliary Cooling Fan Wiring Revision   Model and Year:  1979 Corvette Equipped with 5.7L (350 Cu. In.) V-8 RPO L82 and Air Conditioning   Source:  Chevrolet Service News   Page Number:&nbsp;&nbsp;  3   Date:  Volume 51, Number 1...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<description><![CDATA[ Subject:  &nbsp; Power Antenna Rod and Cable Service Package   Model and Year: &nbsp;  1979-81 Malibu, 1979-84 Impala, Caprice, Camaro and Corvette - 1981-82 Citation, 1982-84 Monte Carlo and El Camino   Source:&nbsp;  Chevrolet Dealer Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</guid>
										<title>1979 - 1982 Corvette:  Service Bulletin:  No AM Reception with Replacement Power Antenna Mast</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</link>
										<description><![CDATA[ Subject:  No AM Reception with Replacement Power Antenna Mast   Model and Year:  1979 - 1982 All Carlines with Power Antennas   Source:  Chevrolet Dealer Service Technical Bulletin   Bulletin Number:  82-T-145, Section XII   Date:  &nbsp; July, 1983...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Tamper Resistant Choke</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</link>
										<description><![CDATA[ Subject:  &nbsp; Tamper Resistant Choke   Model and Year:  &nbsp; 1978 Corvette with Federal (L-48) A/C and Automatic Transmission   Source:&nbsp;  Chevrolet Dealer Service Information Bulletin    Bulletin No:  &nbsp; 78-I-44     Section:  &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</guid>
										<title>1978 - 1980 Corvette:  Service News:  Speedometer System Noise Diagnosis and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Speedometer System Noise Diagnosis and Repair   Model and Year:&nbsp;  1978 - 1980 Corvette - All Vehicles   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; NA   Date:&nbsp;  Part E. , Volume 52-3, May - June...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</guid>
										<title>1978 - 1979 Corvette: Service Bulletin: Power Antenna Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</link>
										<description><![CDATA[ Subject:  &nbsp; Power Antenna Operation   Model and Year:  1978-79 Vehicles with CB or RPO U75   Source:  Chevrolet Dealer Service Technical Bulletin    Bulletin&nbsp;No:   79-T-8    Section:   XII    Date:   April, 1979   TO:&nbsp; ALL CHEVROLET...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm System Interim Modifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Anti-Theft Alarm System Interim Modifications   Model and Year: &nbsp;  1977 Corvette   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 77-I-38    Section:  &nbsp; XII    Date:&nbsp;&nbsp;&nbsp;  May...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<description><![CDATA[ Subject:  &nbsp; Anti-Theft Alarm Switch - Protective Grease   Model and Year: &nbsp;  1977 Corvette   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:  &nbsp; 77-T-57    Section:  &nbsp; XII    Date:&nbsp;&nbsp;&nbsp;  Oct., 1977...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</guid>
										<title>1977 - 1982 Corvette:  Service Bulletin:  Care and Maintenance of Tape Players and Cartridges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</link>
										<description><![CDATA[ Subject:  &nbsp; Care and Maintenance of Tape Players and Cartridges   Model and Year:  &nbsp; NA   Source:&nbsp;  Chevrolet Dealer Service Information Bulletin    Bulletin No:  &nbsp; 75-I-19    Section:  &nbsp; XII    Date:&nbsp;&nbsp;&nbsp;  Oct....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles   Model and Year:  1976 - 1977 Chevrolet Passenger Vehicles   Source:  Chevrolet Dealer Service Information Bulletin   Bulletin Number:  77-I-4   Date:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-high-energy-ignition-system-service-update-1079.html</guid>
										<title>1975 Corvette:  Service News:  High Energy Ignition System - Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-high-energy-ignition-system-service-update-1079.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  High Energy Ignition System - Service Update   Model and Year:&nbsp;  1975 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 3-5   Date:&nbsp;  June 1975 - Volume 47 - Number 6 Below is a valuable...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</guid>
										<title>1973 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</link>
										<description><![CDATA[Attached below are copies of the wiring diagrams from the 1973 factory service manual.&nbsp; These diagrams are of the main wiring harness running from front to back.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the engine in the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Rear Window Defogger</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the rear window defogger system on the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Power Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the power windows in the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Mono and Stereo Radio System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the mono and stereo radio systems in the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the automatic transmission kickdown switch in the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-headlamp-circuit-diagnosis-1101.html</guid>
										<title>1972 Corvette:  Service News:  Headlamp Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-headlamp-circuit-diagnosis-1101.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Headlamp Circuit Diagnosis   Model and Year:&nbsp;  1972 Passenger Cars and Trucks   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 5-6   Date:&nbsp;  June, 1972 The following headlamp circuit diagnosis data...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<description><![CDATA[ Subject:  &nbsp; Blown Thermal Fuse Diagnosis   Model and Year:  &nbsp; 1972 Passenger Car Air Conditioning Systems   Source:&nbsp;  Chevrolet Dealer Service Information Bulletin    Bulletin No:  &nbsp; 72-I-9    Section:  &nbsp; Ia    Date:  &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-anti-diesel-relay-1164.html</guid>
										<title>1971 Corvette:  Service Bulletin:  Anti-Diesel Relay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-anti-diesel-relay-1164.html</link>
										<description><![CDATA[ Subject:  &nbsp; Anti-Diesel Relay   Model and Year:  &nbsp; (1971) All Passenger Cars and Light Trucks with Air Conditioning Except Vega   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 71-T-44     Section:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<description><![CDATA[Model Year: 1969Subject: Headlamp Opening InterferenceSource: Chevrolet Dealer Service Technical BulletinNumber: 69-T-31, Section IDate: May 6, 1969To: ALL CHEVROLET DEALERSA condition could occur on 1969 Corvettes which would restrict the opening of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<description><![CDATA[Subject:&nbsp; Speedometer Shaft FailureModel and Year: 1969 Corvette&nbsp; w/ 4-Speed TransmissionDate:&nbsp; NA UPC XII - ELECTRIC AND INSTRUMENTS E.S.L. SPEEDOMETER SHAFT FAILURE - 1969 Corvette w/ 4-Speed Transmission (#1106) (D.S.T.) The...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</guid>
										<title>1969 Corvette:  Service News:  Directional Signal Switch Removal and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Directional Signal Switch Removal and Installation   Model and Year:&nbsp;  1969 Tilt-Telescoping Column   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 8   Date:&nbsp;  March 1969 - Volume 41 - Number 3...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</guid>
										<title>1969 Corvette:  Service News:  Battery with Side-Mounted Terminals</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</link>
										<description><![CDATA[Subject:  &nbsp;&nbsp;Battery with Side-Mounted Terminals   Model and Year:  1969 Camaro, Corvette and Chevy Van  Source:  Chevrolet Service News    Date: April 1969 - Volume 41 - Number 4 A new battery, which features relocated cable attachment...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</guid>
										<title>1969 Corvette:  Service Bulletin:  Choke Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</link>
										<description><![CDATA[ Subject:  &nbsp; Choke Problems  Model and Year: &nbsp;  1969 Corvette, 1970 Passenger with 350 cu. in. 300 H.P. Engines  Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:&nbsp;  70-T-2  Section:  &nbsp; VIm   Date:&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</guid>
										<title>1969 Corvette:  Inter-Organization Letter:  1969 Delcotron Generator with Integrated Voltage Regulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  1969 Delcotron Generator with Integrated Voltage Regulator  Model and Year:&nbsp;  1969 Corvettes  Source:&nbsp; Inter-Organization Letter - San Diego Zone, Los Angeles Zone, Pacific Coast Region  Page Number:  &nbsp; NA ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</guid>
										<title>1969 Corvette:  Advance Information Inter-Organization Letter:  Anti-Theft Audio Alarm</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Anti-Theft Audio Alarm   Model and Year:&nbsp;  1969 Corvette   Source:  Chevrolet Advance Information Inter-Organization Letter   Bulletin Number:&nbsp;  A.I. 69-4   Date:  &nbsp; March 20, 1969 This letter is being...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Voltage Regulator Failures in the 1970 Integrated Delcotrons</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</link>
										<description><![CDATA[  Model Year:   1969 - 1970 Corvette    Subject:&nbsp;  Voltage Regulator Failures in the 1970 Integrated Delcotrons   Source:  Chevrolet Engineering Center   Number:&nbsp;  UPC VIy - Engine Electrical, 70-9 26   Date:&nbsp;  NA     MISC.   &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-chevrolet-engineering-service-letter-radio-service-update-910.html</guid>
										<title>1969 - 1970 Corvette: Chevrolet Engineering Service Letter:  Radio Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-chevrolet-engineering-service-letter-radio-service-update-910.html</link>
										<description><![CDATA[Subject:  &nbsp; 1969 and Future Corvette Suppression Material - U69  Model and Year:&nbsp;  1969 - 1970 Corvette  Date:  &nbsp; NA  Source:  &nbsp; Chevrolet Engineering Service Letter - 70-1-23 It is possible in weak signal areas that noise in the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<description><![CDATA[Model Year: 1968 Corvette 427 with Air ConditioningSubject: Spark Plug Removal TipSource: Chevrolet Service NewsDate: August, 1968Recent studies indicate that the two forward right bank spark plugs located under the air conditioning compressor on...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</guid>
										<title>1968 Corvette: Service Bulletin: Windshield Wiper System - Operation and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</link>
										<description><![CDATA[  Model Year:  1968   Subject:  1968 Corvette Windshield Wiper System - Operation and Diagnosis   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  68-T-34   Date:  Mar. 11, 1968    To: All Chevrolet Dealers    This bulletin is being...]]></description>
										<description><![CDATA[ Subject:  &nbsp; 1968 Corvette General Information   Model and Year: &nbsp;  1968 Corvette   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-43    Section:  &nbsp; XV    Date:&nbsp;&nbsp;&nbsp;  April 24, 1968...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-united-delco-bulletin-universal-horns-946.html</guid>
										<title>1968 Corvette:  United Delco Bulletin:  Universal Horns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-united-delco-bulletin-universal-horns-946.html</link>
										<description><![CDATA[Below is a chart issued in a United Delco Bulletin, 1A-93-12 - January 1968 regarding replacement horns for all passenger cars including the 1968 Corvette.  &nbsp;
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</guid>
										<title>1968 Corvette:  Service News:  Headlamp Aiming Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Headlamp Aiming Procedure   Model and Year:&nbsp;  1968 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; NA   Date:&nbsp;  November 1967 - Volume 39 - Number 10 1968 Corvette Headlamp Aiming...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  1968 Corvette 327 Cu. In. Engine Distributor Alignment   Model and Year:&nbsp;  1968 Corvette with 327 Cu. In. Engine   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 5   Date:&nbsp;  December 1967 The...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-whine-noise-in-radio-1113.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Whine Noise in Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-whine-noise-in-radio-1113.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Whine Noise in Radio   Model and Year:  &nbsp; All 1968 Vehicles   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-11    Section:  &nbsp; XII    Date:&nbsp;&nbsp;&nbsp;  January 2, 1968  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Holley Model 2300 Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</link>
										<description><![CDATA[Below, is a Dealer Service Bulletin from G.M. of Canada regarding revised Holley Model 2300 carburetor revisions for the 1968 Corvette:
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness at Starter Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</link>
										<description><![CDATA[ Subject:  &nbsp; Heat Damage to Engine Wiring Harness at Starter Solenoid   Model and Year: &nbsp;  1968 Corvette with 396 or 427 Cubic Inch Engine   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-66   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Heat Damage to Engine Wiring Harness   Model and Year: &nbsp;  1968 Passenger Vehicles with 396 or 427 Cubic Inch Engine   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:&nbsp;  68-T-25    Section:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Delcotron Noise (Moan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Delcotron Noise (Moan)   Model and Year: &nbsp;  1968 Passenger Cars Equipped with V-8 Engines and Delcotron High Speed Fan   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:  &nbsp; 68-T-63    Section:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</guid>
										<title>1968 Corvette:  Passenger Car Product Bulletin:  New Corvette Anti-Theft Warning System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;&nbsp;New Corvette Anti-Theft Warning System   Model and Year:&nbsp;  1968 Corvette   Source:&nbsp; Chevrolet Engineering Center - Passenger Car Product Bulletin - GM Confidential - 1968 Mid Season Production Change   Page...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<description><![CDATA[Subject:  &nbsp; Engine Harness Replacement Corvette Transistor Ignition  Model and Year:&nbsp;  1968 Corvette K66 (#960) (S.N.)  Date:  &nbsp; NA  Source:  &nbsp; Chevrolet Engineering Service Letter There is no separate released engine harness for...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<description><![CDATA[Subject:  &nbsp; Discharged Battery  Model and Year:&nbsp;  1968 Corvette with Base Equipment  Date:  &nbsp; February - March 1968, ESC 68-8, Part E  Source:  &nbsp; Chevrolet Engineering Service Letter With the increase of electrical accessory loads...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</guid>
										<title>1968 Corvette:  Chevrolet Service News:  1968 Corvette Courtesy Light Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  &nbsp;Courtesy Light Inoperative (SN-68-31)   Model and Year:  &nbsp; 1968 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 8   Date:&nbsp;  August 1968 An undetermined number of 1968 Corvette...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</guid>
										<title>1968 Corvette Convertible:  Engineering Service Letter:  Rear Courtesy Light Shorting Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</link>
										<description><![CDATA[ Subject:  &nbsp; Rear Courtesy Light Shorting Out   Model and Year: &nbsp;  1968 Corvette Convertible (#974) S.N.)   Source:&nbsp;  Chevrolet Engineering Service Letter    Bulletin No:&nbsp;&nbsp;  NA    Section:  &nbsp; NA    Date:&nbsp;&nbsp;&nbsp...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-delco-service-bulletin-quadrajet-carburetor-service-charts-1135.html</guid>
										<title>1968 - 1982 Corvette:  Delco Service Bulletin:  Quadrajet Carburetor Service Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-delco-service-bulletin-quadrajet-carburetor-service-charts-1135.html</link>
										<description><![CDATA[ Subject:  &nbsp; Troubleshooting The QuadraJet 4 MC - 4 MV Carburetor   Model and Year:  &nbsp; All 1968 -1981 Corvettes   Source:&nbsp;  Delco Bulletin    Bulletin No:  &nbsp; 9D-5T    Section:  &nbsp; NA    Date:&nbsp;&nbsp;&nbsp;  June 1980    ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</guid>
										<title>1968 - 1970 Corvette:  Service Bulletin:  Depressed Park Windshield Wipers Unable to Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</link>
										<description><![CDATA[ Subject:  &nbsp; Depressed Park Windshield Wipers Unable to Park   Model and Year:  1968 - 1970 Corvette   Source:  Chevrolet Dealer Service Technical Service Bulletin    Bulletin No:   70-T-59   Section:  &nbsp; XII    Date:&nbsp;  May 5, 1971   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<description><![CDATA[ Subject:  &nbsp; Heat Shield - Starting Motor Solenoid   Model and Year:&nbsp;  1968 - 1969 Corvette with MArk IV Engine (427ci)   Date:  &nbsp; February - March 1968, ESC 68-8   Source:  &nbsp; Chevrolet Engineering Service Letter To protect the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  Ignition Pulse Amplifier (SN-C-1)   Model and Year:  1965 - 1972 Corvette   Source:  Chevrolet Service News    Date:&nbsp;   November 1966 - Volume 38 - Number 10 Examination of failed transistor ignition pulse amplifiers shows...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<description><![CDATA[Subject:  &nbsp; Moisture Entering Pulse Amplifier - Transistor Ignition Systems  Model and Year: &nbsp;  1965 - 1972 Corvette   Source:&nbsp;  Chevrolet Dealer Service Technical Service Bulletin    Bulletin No:&nbsp;   68-T-8  Section:  &nbsp; VIy  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</guid>
										<title>1953 - 1982 Corvette:  Parking Brake Alarm Components and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</link>
										<description><![CDATA[Below is a listing of 1953 - 1982 Corvette parking brake alarm components and their related part numbers:  &nbsp;
]]></description>
