<title>Home - All Categories - C4 Corvettes  - Clutch and Transmission  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/clutch-and-transmission/62/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</guid>
										<title>Regarding Product Campaign Bulletin 95-C-16 High Shift Effort into Reverse Gear on Manual Transmission - 1995 Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</link>
										<description><![CDATA[ "I have a 1995 Chevy corvette that is having this exact issue and my vin is clearly within the parameters of the ones in this article. I have been disputing with GM about honoring this recall and I have been told that they cannot go off of this...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</guid>
										<title>1996 Corvette: Transmission Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</link>
										<description><![CDATA[1996:&nbsp; Transmission Diagnostic Trouble Codes DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input DTC P0560 System Voltage DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input DTC P0713 Transmission Fluid Temperature (TFT)...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</guid>
										<title>1996 Corvette: Service Bulletin: 3 - 2 Part Throttle Downshift Flare</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</link>
										<description><![CDATA[  Subject:  Service Bulletin: 3 - 2 Part Throttle Downshift Flare (Replace 3 - 2 Solenoid)   Model and Year:   1996 BUICK ROADMASTER  1996 CADILLAC FLEETWOOD  1996 CHEVROLET CAMARO, CAPRICE, CORVETTE  1996 PONTIAC FIREBIRD  1996 OLDSMOBILE BRAVADA ...]]></description>
										<description><![CDATA[Subject: Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)Source: Chevrolet Dealer Technical Service BulletinNumber: 01-07-30-023BModels:1996 Buick Roadmaster1996 Cadillac Fleetwood1999-2000 Cadillac Escalade1996...]]></description>
										<description><![CDATA[Subject: No Reverse, Second Gear, or Fourth Gear (Replace the Reaction Sun Shell)Source: Chevrolet Dealer Technical Service BulletinNumber: 00-07-30-022Models: 1996 Buick Roadmaster1996 Cadillac Fleetwood1996 Caprice1996-99 Chevrolet Camaro,...]]></description>
										<description><![CDATA[  Subject:  High Effort Shifting into Gears After Cold Soak (Contact Technical Assistance)   Model and Year:  1995 Chevrolet Corvette With 5.7L Engine (Vins J and P - RPOs LT5 and LT1) and 6-Speed Manual Transmission   Source:  Chevrolet Product...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</guid>
										<title>1995 Corvette: Service Bulletin: 3 - 2 Downshift Flare (Reflash Control Module)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
										<description><![CDATA[Subject: 3 - 2 Downshift Flare (Reflash Control Module)Model and Year: 1995 CHEVROLET CORVETTE WITH 4L60-E TRANSMISSION (RPO M30) AND 3.07 REAR AXLE RATIO BUILT BEFORE VIN BREAKPOINT 105682Source: Chevrolet Dealer Service BulletinBulletin Number: 57...]]></description>
										<description><![CDATA[Subject: Product Campaign - High Shift Effort Into Reverse Gear on Manual TransmissionModel and Year: 1995 Chevrolet CorvetteSource: Chevrolet Product CampaignBulletin Number: 95-C-16To: All Chevrolet/Geo DealersGeneral Motors has determined that...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</guid>
										<title>1995 - 1996 Corvette: Service Bulletin: Delayed Engagement (Replace Pump Cover Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</link>
										<description><![CDATA[  Subject:  Delayed Engagement (Replace Pump Cover Assembly)   Model and Year:   1995-96 BUICK ROADMASTER  1995-96 CADILLAC FLEETWOOD  1995-96 CHEVROLET CAPRICE, CAMARO, CORVETTE  1995-96 HOLDEN COMMODORE (VR AND VS)  1995-96 PONTIAC FIREBIRD  1995...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</guid>
										<title>1995 - 1996  Corvette: Service Bulletin: Transmission Fluid Leak From Pump Body</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</link>
										<description><![CDATA[  Subject:  Transmission Fluid Leak From Pump Body (Replace Bushing)   Model and Year:   1995-96 BUICK ROADMASTER  1995-96 CADILLAC FLEETWOOD  1995-96 CHEVROLET CAPRICE, CAMARO, CORVETTE  1995-96 PONTIAC FIREBIRD  1995-96 CHEVROLET AND GMC TRUCK C/K,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
										<description><![CDATA[  Subject:  Garage Shift Delay Engagement (New Garage Shift Package)   Model and Year:   1994 BUICK ROADMASTER  1994 CADILLAC FLEETWOOD  1994 CHEVROLET CAMARO, CAPRICE AND CORVETTE  1994 PONTIAC FIREBIRD  1994 CHEVROLET AND GMC TRUCK C/K AND S/T...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</guid>
										<title>1993 Corvette: Service Bulletin: Transmission &quot;Whine&quot; Noise, Loss of Motion in all Gears, or Missing Clutch Disc Rivets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</link>
										<description><![CDATA[  Subject:  TRANSMISSION "WHINE" NOISE, LOSS OF MOTION IN ALL GEARS, OR MISSING CLUTCH DISC RIVETS (REPLACE TRANSMISSION CLUTCH HOUSING)   Model and Year:  1993 CHEVROLET CORVETTE WITH SIX-SPEED MANUAL TRANSMISSION AND 5.7L (LT1) ENGINE (VIN CODE P) ...]]></description>
										<description><![CDATA[Subject: No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts)Model and Year: 1993-2005 Corvette with 4L60/65-E Automatic Transmission (RPOs M30 or M32)Source: Chevrolet Dealer Sevice&nbsp...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</guid>
										<title>1992 Corvette: Service Bulletin: Harsh 1-2 Upshift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</link>
										<description><![CDATA[ Subject:  HARSH 1-2 UPSHIFT INSTALL SERVICE PACKAGE   Model and Year:  1992 CAPRICE, CAMARO AND CORVETTE 1992 C/K, G, L/M, S/T TRUCKS   Source:  Chevrolet Service Bulletin   Bulletin Number:  92-318-7A - (09/15/1992) TRANSMISSION APPLICATIONS:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</guid>
										<title>1990 Corvette: Service Bulletin: New Low and Reverse Clutch Support Selective Plate Dimensions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</link>
										<description><![CDATA[ Subject:  NEW LO &amp; REV. CLUTCH SUPPORT SELECTIVE PLATE DIMENSIONS   Model and Year:  1990 B, F, Y CARS AND ALL TRUCKS AND VANS WITH 4L60 (700-R4) AUTOMATIC TRANSMISSION   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-223-7A - (05/21...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</guid>
										<title>1990 Corvette: Service Bulletin: Clutch Apply Plate Material Changed to Powdered Metal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</link>
										<description><![CDATA[ Subject:  CLUTCH APPLY PLATE MATERIAL CHANGED TO POWDERED METAL   Model and Year:  1990 ALL CARS, TRUCKS, VANS WITH 4L60 (700-R4) AUTOMATIC TRANSMISSION   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-189-7A - (03/06/1990) This bulletin...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<description><![CDATA[Number: 02-07-30-024Subject: Info - Diagnosis of Cracked or Broken Transmission Case Model Year: 1990-1993 Buick Roadmaster, Estate Wagon1990-1996 Cadillac Fleetwood1990-1996 Chevrolet Caprice1990-2002 Chevrolet Camaro1990-2003 Chevrolet Corvette1995...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-3-2-coast-down-clunk-600.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: 3-2 Coast Down Clunk</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-3-2-coast-down-clunk-600.html</link>
										<description><![CDATA[ Subject:  3-2 COAST DOWN CLUNK (INSTALL SERVO SPRING)   Model and Year:  1990-91 CORVETTE WITH 4L60 AUTOMATIC TRANSMISSION   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-372-7A - (06/27/1991) TRANSMISSION MODELS: OYDM, 1 YDM, 1 YHM ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<description><![CDATA[  Model Year:  1989-96 CHEVROLET CORVETTE WITH ZF 6-SPEED MANUAL TRANSMISSION (ML9)   Subject:  INFORMATION ON CORVETTE ZF 6-SPEED MANUAL TRANSMISSION SERVICE PROCEDURE   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  77-72-04  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<description><![CDATA[From ZF regarding ZF transmission noise and differences between the ZF used in early and late ZR-1s - July 12, 2000: "All S6-40 transmissions installed in the C4 Corvette contain 100% helical gears.&nbsp; In fact, all of the gearboxes ZF produces for...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: No/Delayed Reverse When Cold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
										<description><![CDATA[ Subject:  NO/DELAYED REVERSE WHEN COLD INSTALL REV. INPUT CLUTCH SEAL   Model and Year:   1989-91 CAPRICE CAMARO AND CORVETTE  1989-91 C/K, R/V, S/T, G AND M TRUCKS  1990 L TRUCKS WITH 4L60 AUTOMATIC TRANSMISSION   Source:  Chevrolet Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Transmission Exchange Program 6 Speed M/T (ML9)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</link>
										<description><![CDATA[Subject: TRANS. EXCHANGE PROGRAM 6 SPEED M/T (ML9)Model and Year: 1989-91 CORVETTE ZF 6-SPEED MANUAL TRANSMISSION WITH ML9 OPTIONSource: Chevrolet Service BulletinBulletin Number: 91-89-7B - (10/31/1990) TO: ALL CHEVROLET DEALERS THIS BULLETIN...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</guid>
										<title>1989 - 1990 Corvette: Howling, or Squealing Sound Coming From Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</link>
										<description><![CDATA[From Jim Ingle, GM Powertrain Engineer:"The problem you're most likely experiencing is a noisy crankshaft pilot bushing. There is a later design released for service that tends to retain grease better than the one you have and therefore doesn't...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Click/Whine in 3rd/4th Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</link>
										<description><![CDATA[Subject: CLICK/WHINE IN 3RD/4TH GEAR INST. NEW CLUTCH FIBER PLATESModel and Year:1988-93 CAPRICE, CAMARO AND CORVETTE 1988-93 C/K, RN, S/T, M AND G TRUCKS 1990-93 L VANSource: Chevrolet Service BulletinBulletin Number: 93-228-7ATHIS BULLETIN CANCELS...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<description><![CDATA[Subject: NEW 3-4 CLUTCH PLATES (STEEL) 4L60 TRANSMISSIONSModel and Year:1987-91 CAPRICE, CAMARO, CORVETTE WITH 4L60 AUTOMATIC TRANSMISSION1987-91 C/K, G, M, RN, S/T TRUCK1990-91 L TRUCK WITH 4L60 AUTOMATIC TRANSMISSIONSource: Chevrolet Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: 4L60 Low &amp; Reverse Clutch New Plate Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</link>
										<description><![CDATA[ Subject:  4L60 LOW &amp; REVERSE CLUTCH NEW WAVE PLATE IS AVAILABLE   Model and Year:  1987-91 CAPRICE, CAMARO, CORVETTE AND 1987-91 C/K, RN, S/T TRUCKS, G, M VANS AND 1990-91 L VAN WITH 4L60 AUTOMATIC TRANSMISSION   Source:  Chevrolet Service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</guid>
										<title>1986 - 1987 Corvette:  Service Bulletin:  Clutch Master Cylinder Push Rod Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</link>
										<description><![CDATA[  Subject:&nbsp;  Clutch Master Cylinder Push Rod Bushing   Model Year:&nbsp;&nbsp;  1986 - 1987 Corvette with Manual Transmission   Source:  Chevrolet Dealer Service Bulletin   Bulletin No:  87-114, Section 7C   Date:  April, 1987     TO:&nbsp; ALL...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-low-idle-speed-and-launch-stalls-609.html</guid>
										<title>1985 Corvette: Service Bulletin: Low Idle Speed and Launch Stalls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-low-idle-speed-and-launch-stalls-609.html</link>
										<description><![CDATA[Subject: Low Idle Speed and Launch StallsModel and Year: 1985 CorvetteSource: Chevrolet Dealer Sevice&nbsp;BulletinBulletin Number: 85-186, Section 6EDate: Mar., 1986 TO:&nbsp; ALL CHEVROLET DEALERS Some 1985 Corvettes with manual transmission may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-transmission-maintenance-information-four-speed-manual-transmission-with-automatic-overdrive-1002.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Transmission Maintenance Information - Four-Speed Manual Transmission with Automatic Overdrive</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-transmission-maintenance-information-four-speed-manual-transmission-with-automatic-overdrive-1002.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Transmission Maintenance Information - Four-Speed Manual Transmission with Automatic Overdrive   Model and Year: &nbsp;  1984 Corvette   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:&nbsp;&nbsp;  84-213   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</guid>
										<title>1984 - 1992 Corvette: Service Bulletin: Intermittent Transmission Downshift / Slip Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</link>
										<description><![CDATA[Subject: INTERMITTENT TRANSMISSION DOWNSHIFT, SLIP OR BUSY/CYCLING TCC Model and Year: 1983-92 ALL PASSENGER CARS AND TRUCKS WITH AUTOMATIC TRANSMISSIONSource: Chevrolet Service BulletinBulletin Number: 92-42-7A - (11/07/1991) Some owners may comment...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</guid>
										<title>1984 - 1989 Corvette:  Service Bulletin: Steering Gear Intermediate Shaft Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</link>
										<description><![CDATA[Bulletin Number:&nbsp;&nbsp; 89-258-3BSection:&nbsp; 3BDate:&nbsp; September 1989Subject:&nbsp;&nbsp;&nbsp;Steering Gear Intermediate Shaft Torque Specifications&nbsp;Models:&nbsp;&nbsp;&nbsp;1984-89 Y Car&nbsp;To:&nbsp; All Chevrolet DealersThe...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
										<description><![CDATA[Nash Thrash  Rebuilding the Doug Nash 4+3 Overdrive Unit.  by David Fulcher&nbsp; 1984-88 manual shift Corvettes came through with the Doug Nash 4+3 overdrive transmission. The '84 and '85 units were almost identical, with the only difference being a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Improperly Installed Reverse Idler Shaft Roll Pin</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</link>
										<description><![CDATA[ Subject:  IMPROPERLY INSTALLED REVERSE IDLER SHAFT ROLL PIN   Model and Year:  1984-1985 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  85-31 - (01/09/1985) Damage to the manual transmission may occur if the roll pin securing the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</guid>
										<title>1984 - 1985 Corvette:  Service Bulletin:  Noise in Direct Drive 4-Speed Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</link>
										<description><![CDATA[ Subject:  &nbsp; Noise in Direct Drive 4-Speed Manual Transmission   Model and Year: &nbsp;  1984 - 1985 Corvette   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 85-111    Section:  &nbsp; 7B    Date:&nbsp;&nbsp;&nbsp; ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<description><![CDATA[  Subject:  BUZZING NOISE AT IDLE (INSTALL PRESSURE REGULATOR VALVE)   Model and Year:   1982-93 CAPRICE, CAMARO AND CORVETTE  1982-93 C/K, R/V, S/T, M/L AND G TRUCKS WITH 4L60 AUTOMATIC TRANSMISSION    Transmission Applications:  1982-1993 HYDRA...]]></description>
										<description><![CDATA[ Subject:  TRANSMISSION STUCK IN FIRST GEAR   Model and Year:   1982-91 CAPRICE, CAMARO AND CORVETTE  1982-91 C/K, G, S/T'  1985-91 M VAN  1987-91 RN AND 1990-91 L VAN WITH 4L60 AUTOMATIC TRANSMISSION   Source:  Chevrolet Service Bulletin   Bulletin...]]></description>
										<description><![CDATA[Subject: NEW OUTPUT SHAFTS &amp; SEALS (PRODUCT SERVICE INFORMATION)Model and Year:1982-91 CAPRICE, CAMARO AND CORVETTE1982-91 C1/C2, G1/G2, K1/K2, S/T1987-91 R/V1985-91 M AND1990-91 L TRUCKS WITH 4L60/THM 700-R4 AUTOMATIC TRANSMISSIONSource:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<description><![CDATA[ Subject:  EVALUATING PEENED SPACER PLATE (Service Information)   Model and Year:  1982-1991 ALL PASSENGER CARS AND TRUCKS WITH AUTOMATIC TRANSAXLES AND TRANSMISSIONS (EXCEPT GEO)   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-396-7A - ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;3-4 Clutch / 2-4 Band Service Information   Model and Year: &nbsp;  1982-91 Caprice, Camaro and Corvette and 1982-91 All Trucks with 4L60 Automatic Transmission   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:...]]></description>
										<description><![CDATA[Subject: SERVICE REPLACEMENT TRANS ASSY (SRTA) UPDATEModel and Year: 1982-90 CAPRICE, CAMARO AND CORVETTE1982-90 C1/C2, K1/K2, G1/G2, S1/S2 TRUCK 1987-90 R1/R2, V1/V2 TRUCK 1985-90 M1, 1990 L1 TRUCKSource: Chevrolet Service BulletinBulletin Number:...]]></description>
