<title>Home - All Categories - C3 Corvettes  - Clutch and Transmission  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c3-corvettes/clutch-and-transmission/61/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</guid>
										<title>1982 Corvette:  Service Bulletin:  Output Shaft Speedo Gear Clip Holes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</link>
										<description><![CDATA[ Subject:  &nbsp; Output Shaft Speedo Gear Clip Holes   Model and Year:  &nbsp; 1982 THM 700-R4 Transmission   Source:&nbsp;  Chevrolet Dealer Service Information Bulletin    Bulletin No:  &nbsp; 82-I-126    Section:  &nbsp; VIIc    Date:&nbsp;&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<description><![CDATA[  Subject:  BUZZING NOISE AT IDLE (INSTALL PRESSURE REGULATOR VALVE)   Model and Year:   1982-93 CAPRICE, CAMARO AND CORVETTE  1982-93 C/K, R/V, S/T, M/L AND G TRUCKS WITH 4L60 AUTOMATIC TRANSMISSION    Transmission Applications:  1982-1993 HYDRA...]]></description>
										<description><![CDATA[ Subject:  TRANSMISSION STUCK IN FIRST GEAR   Model and Year:   1982-91 CAPRICE, CAMARO AND CORVETTE  1982-91 C/K, G, S/T'  1985-91 M VAN  1987-91 RN AND 1990-91 L VAN WITH 4L60 AUTOMATIC TRANSMISSION   Source:  Chevrolet Service Bulletin   Bulletin...]]></description>
										<description><![CDATA[Subject: NEW OUTPUT SHAFTS &amp; SEALS (PRODUCT SERVICE INFORMATION)Model and Year:1982-91 CAPRICE, CAMARO AND CORVETTE1982-91 C1/C2, G1/G2, K1/K2, S/T1987-91 R/V1985-91 M AND1990-91 L TRUCKS WITH 4L60/THM 700-R4 AUTOMATIC TRANSMISSIONSource:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<description><![CDATA[ Subject:  EVALUATING PEENED SPACER PLATE (Service Information)   Model and Year:  1982-1991 ALL PASSENGER CARS AND TRUCKS WITH AUTOMATIC TRANSAXLES AND TRANSMISSIONS (EXCEPT GEO)   Source:  Chevrolet Service Bulletin   Bulletin Number:  91-396-7A - ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;3-4 Clutch / 2-4 Band Service Information   Model and Year: &nbsp;  1982-91 Caprice, Camaro and Corvette and 1982-91 All Trucks with 4L60 Automatic Transmission   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:...]]></description>
										<description><![CDATA[Subject: SERVICE REPLACEMENT TRANS ASSY (SRTA) UPDATEModel and Year: 1982-90 CAPRICE, CAMARO AND CORVETTE1982-90 C1/C2, K1/K2, G1/G2, S1/S2 TRUCK 1987-90 R1/R2, V1/V2 TRUCK 1985-90 M1, 1990 L1 TRUCKSource: Chevrolet Service BulletinBulletin Number:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-loss-of-front-pump-prime-350c-transmissions-703.html</guid>
										<title>1981 Corvette: Service Bulletin: Loss of Front Pump Prime 350C Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-loss-of-front-pump-prime-350c-transmissions-703.html</link>
										<description><![CDATA[Subject: LOSS OF FRONT PUMP PRIME 350C TRANSMISSIONSModel and Year: Early 1981 CorvettesSource: Chevrolet Dealer Service BulletinBulletin Number: 81-T-38SOME 1981 CORVETTES AND CAMAROS WITH 350C (MX3) AUTOMATIC TRANSMISSIONS MAY EXPERIENCE A...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</guid>
										<title>1981 Corvette:  Service Bulletin:  Whistle or Whine in Reverse or Lo 1 at Idle - THM 350C (MX3)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Whistle or Whine in Reverse or Lo 1 at Idle - THM 350C (MX3)   Model and Year: &nbsp;  1981 Corvette with THM 350C (MX3)   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:&nbsp;&nbsp;  81-T-20   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</guid>
										<title>1980 Corvette: Service Bulletin: Propeller Shaft Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</link>
										<description><![CDATA[Subject: Propeller Shaft AssembliesModel and Year: 1980 Corvettes euipped with automatic transmissionsSource: Chevrolet Dealer Sevice&nbsp;BulletinBulletin Number: 80-I-67, Section IVDate: July, 1980 TO:&nbsp; ALL CHEVROLET DEALERS Some early 1980...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</guid>
										<title>1976 - 1990 Corvette: Service Bulletin: New On-Vehicle Service Procedure to Remove Rear Case or Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
										<description><![CDATA[ Subject:  NEW ON-VEHICLE SERV. PROCEDURE REMOVE REAR CASE OR EXT. BUSH   Model and Year:  1976-90 B, F, G, Y CARS &amp; 1976-90 C, G, K, L, M, R, S, T, V TRUCKS WITH THM 200-4R, THM 200-C, THM 200 &amp; 4L60/THM 700R4 AUTOMATIC TRANSMISSION   Source...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</guid>
										<title>1974 Corvette:  Service News:  New Warner 4-Speed Released Interim 1974 Production</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  &nbsp;New Warner 4-Speed Released Interim 1974 Production   Model and Year:&nbsp;  1974 Camaro and Corvette Models   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 1-7   Date:&nbsp;  February, 1974 - Volume 46 -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</guid>
										<title>1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
										<description><![CDATA[Model Year: 1974-1975Subject: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. TransmissionSource: Chevrolet Dealer Service Technical BulletinNumber: 75-T-3Date: Jan. 17, 1975TO: ALL CHEVROLET DEALERSOn 1974 and 1975 Corvettes with 4...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</guid>
										<title>1974 - 1975 Corvette:  Service Bulletin:  Stripped Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</link>
										<description><![CDATA[Subject:&nbsp; Stripped Speedometer Driven GearModel and Year: 1974 - 1975 Corvette with 4-Speed TransmissionSource: Chevrolet Dealer Service Technical BulletinBulletin No: 75-T-3Section:&nbsp; XIIDate: January 17, 1975To:&nbsp; All Chevrolet Dealers...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<description><![CDATA[Attached below is the electrical schematic for the automatic transmission kickdown switch in the 1973 Corvette.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</guid>
										<title>1973 + Corvette: Service News: Gear Tooth Contact Pattern Check - All Rear Axle Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</link>
										<description><![CDATA[ Subject:  Gear Tooth Contact Pattern Check - All Rear Axle Assemblies  Model and Year:  1973 Corvette   Source:  Chevrolet Service News   Page Number:  Page 1   Date:  November 1972, Volume 44, Number 11 The intent of this article is to re-emphasize...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<description><![CDATA[Subject:&nbsp; Speedometer Shaft FailureModel and Year: 1969 Corvette&nbsp; w/ 4-Speed TransmissionDate:&nbsp; NA UPC XII - ELECTRIC AND INSTRUMENTS E.S.L. SPEEDOMETER SHAFT FAILURE - 1969 Corvette w/ 4-Speed Transmission (#1106) (D.S.T.) The...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</guid>
										<title>1968 Corvette: Service Bulletin: Driveline Clicking or Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</link>
										<description><![CDATA[Subject:&nbsp; Driveline Clicking or Snapping NoiseModel Year:&nbsp; 1968 Passenger Cars and 10 Series TrucksDate:&nbsp; September 3, 1968Bulletin Number: 68-T-61, Section IV TO:&nbsp; ALL CHEVROLET DEALERS Driveline click or snapping type sounds...]]></description>
										<description><![CDATA[ Subject:  &nbsp; 1968 Corvette General Information   Model and Year: &nbsp;  1968 Corvette   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-43    Section:  &nbsp; XV    Date:&nbsp;&nbsp;&nbsp;  April 24, 1968...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</guid>
										<title>1968 - 1971 Corvette:  Service News:  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</link>
										<description><![CDATA[ Subject:&nbsp;  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission   Model and Year:&nbsp;  1968 - 1971 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 6   Date:&nbsp;  April 1971 -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</guid>
										<title>1968 - 1969 Corvette:  Chevrolet Service Engineering Letter: Service Procedures for Clutch Gear Slinger on Muncie 4-Speed Passenger Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</link>
										<description><![CDATA[Source:&nbsp; Chevrolet Engineering Service Letter:Section:&nbsp; 69-3 25Subject:&nbsp; Service Procedures for Clutch Gear Slinger on Muncie 4-Speed Passenger Transmissions - UPC - V116Models:&nbsp; 1968-69 All Chevrolet - Chevelle, Camaro, Chevy...]]></description>
