<title>Home - All Categories - C1 Corvettes  - Chassis, Frame and Suspension  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c1-corvettes/chassis-frame-and-suspension/55/</link>
										<description><![CDATA[ Source:  &nbsp; Chevrolet Pro Service News   Date:&nbsp;  June 1998, Volume 7, Issue Number 6   Subject:  &nbsp; Corvette Water Leak Repair
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-drive-line-vibration-corvette-51.html</guid>
										<title>1959 Corvette:  Service News:  Drive Line Vibration - Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-drive-line-vibration-corvette-51.html</link>
										<description><![CDATA[Source:&nbsp;&nbsp; Chevrolet Service NewsPage:&nbsp; 4Date:&nbsp; July-August, 1959Subject:&nbsp;&nbsp;&nbsp;Drive Line Vibration -- Corvette If excessive drive line vibration is encountered on a 1959 Corvette it is probably due to excessive rear C...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Excessive Driveline Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</link>
										<description><![CDATA[ Subject:  &nbsp; Excessive Drive Line Vibration   Model and Year: &nbsp;  1959 Corvette   Source:&nbsp;  General Motors of Canada Service Bulletin    Bulletin No:&nbsp;  NA    Section:  &nbsp; Part B - Page 83    Date:&nbsp;  September 30, 1959    ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-bulletin-front-and-rear-coil-spring-heights-785.html</guid>
										<title>1959 - 1961 Corvette: Service Bulletin: Front and Rear Coil Spring Heights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-bulletin-front-and-rear-coil-spring-heights-785.html</link>
										<description><![CDATA[Subject: Front and Rear Coil Spring HeightsModel and Year: 1959-1961 Passenger CarsSource: Chevrolet Technical Service BulletinBulletin Number: DR #437, Section IIIDate: June 30, 1961 In the event a side-to-side or front-to-rear out-of-trim condition...]]></description>
										<description><![CDATA[Note:&nbsp; Product Engineering bulletins like the one listed below went to Chevrolet Zone Offices located in various states across the United States, and did not get entered into the Chevrolet dealer Bulletin system.  Subject:&nbsp; Drive Line ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-zone-letter-steering-gear-lube-leaking-from-directional-signal-housing-792.html</guid>
										<title>1959 - 1960 Corvette: Zone Letter: Steering Gear Lube Leaking From Directional Signal Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-zone-letter-steering-gear-lube-leaking-from-directional-signal-housing-792.html</link>
										<description><![CDATA[Model Year: 1959-1960Subject: Corvette Steering Gear Lube Leaking from the Directional Signal HousingSource: Chevrolet Zone LetterZone:&nbsp; #41 Wichita, KansasNumber: 83Date: December 8, 1959In the event the steering gear lube should work up the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-instability-above-60-mph-962.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Instability  Above 60 MPH</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-instability-above-60-mph-962.html</link>
										<description><![CDATA[ Subject:  &nbsp; Instability&nbsp; Above 60 MPH   Model and Year: &nbsp;  1956 Corvettes (Serial Numbers Listed)   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:&nbsp;  DR #267    Section:  &nbsp; III    Date:&nbsp;  October 10,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-frame-specifications-258.html</guid>
										<title>1953 - 1962 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-frame-specifications-258.html</link>
										<description><![CDATA[Below is a one page PDF featuring 1953 - 1962 Corvette frame specifications.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-technical-article-summary-report-on-changes-to-achieve-improvement-in-corvette-handling-and-ride-85.html</guid>
										<title>1953 - 1954 Corvette: Technical Article: Summary Report on Changes to Achieve Improvement in Corvette Handling and Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-technical-article-summary-report-on-changes-to-achieve-improvement-in-corvette-handling-and-ride-85.html</link>
										<description><![CDATA[Summary Report on Changes to Achieve Improvement in Corvette Handling and Ride Below is a Chevrolet Inter-Organizational Letter dated March 29th, 1954 by Zora Arkus-Duntov addressing Maurice Olley's concerns about the Corvette's ride and handling...]]></description>
