<title>Home - All Categories - C2 Corvettes  - AC, Heating and Ventilation  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c2-corvettes/ac-heating-and-ventilation/45/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-air-conditioning-diagnosis-845.html</guid>
										<title>1967 Corvette: Service News: Air Conditioning Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-air-conditioning-diagnosis-845.html</link>
										<description><![CDATA[ Subject:  Air Conditioning Diagnosis   Model and Year:  1967 Corvette   Source:  Chevrolet Service News   Page Number:  Page 8   Date:  July 1967 - Volume 39, Issue Number 8 The "Air Conditioning Diagnosis" chart given on page 8 will help pinpoint...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-air-conditioning-thermostatic-expansion-valve-replacement-759.html</guid>
										<title>1966 Corvette: Service News: Air Conditioning Thermostatic Expansion Valve Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-air-conditioning-thermostatic-expansion-valve-replacement-759.html</link>
										<description><![CDATA[Model Year: 1966Subject: Air Conditioning Thermostatic Expansion Valve Replace - 1966 CorvetteSource: Chevrolet Service NewsDate: August, 1966The service procedure for replacing the expansion valve on the 1966 Corvette is outlined below. This...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-heater-hose-routing-change-required-1039.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Heater Hose Routing Change Required</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-heater-hose-routing-change-required-1039.html</link>
										<description><![CDATA[ Subject:  &nbsp; Heater Hose Routing Change Required   Model and Year: &nbsp;  1966 Corvettes with 327 CU. IN. Engine and Air Conditioning   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:  &nbsp; DR #66-10    Section:  &nbsp; Ib...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<description><![CDATA[ Subject:  &nbsp; Crankshaft to Water Pump Drive Belt Failure   Model and Year: &nbsp;  1966 - 1967 Corvettes with 427 CU. IN. Engine and Air Conditioning   Source:&nbsp;  Chevrolet Service Technical Bulletin    Bulletin No:&nbsp;  67-T-26    Section...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 350 H.P. Factory A/C Operating Temperatures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</link>
										<description><![CDATA[Subject:&nbsp; 1965 Corvette 350 H.P. Factory A/C Operating TemperaturesModel and Year:&nbsp;1965 Corvette - 350 H.P Engine equipped with Factory A/CDate:&nbsp; T.N. #7 - June 30, 1965 SECTION VI - ENGINE CONTINUED MISCELLANEOUSThe following is an...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-air-conditioning-cooling-capacity-loss-1162.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Air Conditioning Cooling Capacity Loss</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-air-conditioning-cooling-capacity-loss-1162.html</link>
										<description><![CDATA[ Subject:  &nbsp; Air Conditioning Cooling Capacity Loss   Model and Year:  &nbsp; 1965 Chevrolet   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:  &nbsp; TSB #1166  , DR #768    Section:  &nbsp;&nbsp; XV     Date:  &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-lack-of-heat-with-controls-in-full-on-position-968.html</guid>
										<title>1964 Corvette:  Service Bulletin:  Lack of Heat with Controls in Full &quot;On&quot; Position</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-lack-of-heat-with-controls-in-full-on-position-968.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp;Lack of Heat with Controls in Full "On" Position   Model and Year: &nbsp;  1964 Corvette with Air Conditioning   Source:&nbsp;  Chevrolet Technical Service Bulletin    Bulletin No:&nbsp;  TSB #1012    Section:  &nbsp; I    Date...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-air-conditioning-changes-913.html</guid>
										<title>1963 - 1964 Corvette:  Service News:  Air Conditioning Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-air-conditioning-changes-913.html</link>
										<description><![CDATA[ Subject:  &nbsp; Air Conditioning Changes   Model and Year:  1963 - 1964 Corvette   Source:  Chevrolet Service News    Date:   March 1964 - Volume 36 - Number 3 On all 1963 and early 1964 Corvettes equipped with Air Conditioner RPO C60, it would be...]]></description>
