<title>Home - All Categories - C3 Corvettes  - AC, Heating and Ventilation  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c3-corvettes/ac-heating-and-ventilation/44/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-air-conditioning-compressor-noise-954.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Air Conditioning Compressor Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-air-conditioning-compressor-noise-954.html</link>
										<description><![CDATA[ Subject:  &nbsp; Air Conditioning Compressor Noise   Model and Year: &nbsp;  1978 Corvette with RPO L48 Engine and M38 Automatic Transmission   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:&nbsp;  78-T-76    Section:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html</guid>
										<title>1976 Corvette: Service Bulletin: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html</link>
										<description><![CDATA[ Subject:  Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe   Model and Year:  1976 Corvette with A/C   Source:  Chevrolet Dealer Service Technical Bulletin   Bulletin Number:  76-T-43, Section Ia   Date:  Nov. 1976 TO:&nbsp; ALL...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<description><![CDATA[Below are the attachments for this service bulletin.
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</link>
										<description><![CDATA[ Subject:  &nbsp; Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance   Model and Year:  &nbsp; 1973 Corvette with 350 C.I.D. Engine   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 74-T-41    Section: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-refrigerant-leaks-air-conditioning-compressor-superheat-switch-838.html</guid>
										<title>1972 Corvette: Service News: Refrigerant Leaks Air Conditioning Compressor Superheat Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-refrigerant-leaks-air-conditioning-compressor-superheat-switch-838.html</link>
										<description><![CDATA[Subject: Refrigerant Leaks Air Conditioning Compressor Superheat Switch  Model and Year:  1972 Passenger Models Except Vega  Source:  Chevrolet Service News   Page Number:  Page 1   Date:  November 1972, Volume 44, Number 11 Investigation of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<description><![CDATA[ Subject:  &nbsp; Blown Thermal Fuse Diagnosis   Model and Year:  &nbsp; 1972 Passenger Car Air Conditioning Systems   Source:&nbsp;  Chevrolet Dealer Service Information Bulletin    Bulletin No:  &nbsp; 72-I-9    Section:  &nbsp; Ia    Date:  &nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</guid>
										<title>1971 Corvette:  Service Bulletin:  Air Conditioning Equipped Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</link>
										<description><![CDATA[ Subject:  &nbsp; Air Conditioning Equipped Vehicles   Model and Year:  &nbsp; 1971 Air Conditioning Equipped Vehicles   Source:&nbsp;  Chevrolet Service Bulletin&nbsp; - Zone #42 - Seattle, Washington    Bulletin No:  &nbsp; SER-71-41     Zone:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-heater-and-air-conditioning-1190.html</guid>
										<title>1970 Corvette:  Service News:  Heater and Air Conditioning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-heater-and-air-conditioning-1190.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Heater and Air Conditioning  Model and Year:&nbsp;  1970 Corvette  Source:&nbsp;  Chevrolet Service News   Page Number:  &nbsp; 2   Date:&nbsp; Section 1A, March 1970, Volume 42, Number 3 The 1970 Corvette heater and air...]]></description>
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</guid>
										<title>1969 - 1976 Corvette: Service Bulletin: Air Conditioning Compressor Drive Belt to Radiator Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</link>
										<description><![CDATA[ Subject:  Air Conditioning Compressor Drive Belt to Radiator Hose Interference   Model and Year:  1976 and Past Model Corvette Equipped with the 350 Cubic Inch Engine and Air Conditioning   Source:  Chevrolet Dealer Service Technical Bulletin  ...]]></description>
										<description><![CDATA[ Subject:  &nbsp; 1968 Corvette General Information   Model and Year: &nbsp;  1968 Corvette   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-43    Section:  &nbsp; XV    Date:&nbsp;&nbsp;&nbsp;  April 24, 1968...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Refrigerant Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</link>
										<description><![CDATA[ Subject:  &nbsp; Refrigerant Leak   Model and Year:  &nbsp; 1968 Vehicles with Air Conditioning   Source:&nbsp;  Chevrolet Dealer Service Technical Bulletin    Bulletin No:  &nbsp; 68-T-56    Section:  &nbsp; Ia    Date:  &nbsp; July 12, 1968   TO:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Condenser and Receiver-Dehydrator Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</link>
										<description><![CDATA[This General Motors Dealer Service Information Bulletins comes from General Motors Products of Canada Limited.&nbsp; Below is a revised procedure and shop manual update for removal the condenser and receiver-dehydrator on 1968 Corvettes:
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-service-news-false-a-c-compressor-seizure-vehicles-subjected-to-extended-storage-949.html</guid>
										<title>1968 - 1982 Corvette:  Service News:  False A/C Compressor Seizure - Vehicles Subjected to Extended Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-service-news-false-a-c-compressor-seizure-vehicles-subjected-to-extended-storage-949.html</link>
										<description><![CDATA[Subject:  False A/C Compressor Seizure - Vehicles Subjected to Extended Storage  Model and Year:&nbsp; 1968 - 1982 Corvette   Source:&nbsp;  Chevrolet Service News   Page Number:&nbsp; 1  Date:&nbsp; April 1972 - Volume 44 - Number 44 Slipping or...]]></description>
