<title>Home - All Categories - C4 Corvettes  - AC, Heating and Ventilation  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c4-corvettes/ac-heating-and-ventilation/43/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</guid>
										<title>2005 Corvette: GM TechLink: HVAC Module Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-hvac-module-service-622.html</link>
										<description><![CDATA[This information applies to the 2004 Cadillac XLR and the 2005 Chevrolet Corvette and newer.Use special care when removing or installing the HVAC module for service. The HVAC module is seated between a non-removable upper and lower tie bar(fig. 11 -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</guid>
										<title>1991 Corvette: Service Bulletin: Loss of Heat/Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</link>
										<description><![CDATA[Subject: LOSS OF HEAT/COOLING CONTROL REVISED PROGRAMER AVAILABLE Model and Year:1991 CORVETTE WITH 5.7L ENGINESource: Chevrolet Service BulletinBulletin Number: 91-200-1A - (02/04/1991) Condition: On some vehicles the temperature of air coming from...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</guid>
										<title>1990 Corvette: Service Bulletin: Replacement of Isolation Diodes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-replacement-of-isolation-diodes-217.html</link>
										<description><![CDATA[#93-163-8A - REPLACEMENT OF ISOLATION DIODESMANY OF THE ELECTRICAL SYSTEMS ON OUR VEHICLES USE A DIODE TO ISOLATE CERTAIN CIRCUITS AND PROTECT THEM FROM VOLTAGE SPIKES. SOME OF THE CIRCUITS WHICH MAY USE SUCH A DIODE ARE LISTED BELOW:* A/C COMPRESSOR...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<description><![CDATA[Subject: Loss of Heating or Cooling Control - New ProgrammerModel and Year: 1990 CORVETTESource: Chevrolet Service BulletinBulletin Number: 90-378-1A - (10/25/1990)TO: ALL CHEVROLET DEALERSCondition:The customer may comment on a loss of heating or...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</guid>
										<title>1990 Corvette: Service Bulletin: L98 and LT5: Revised Air Conditioning Control Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</link>
										<description><![CDATA[  Subject:  REVISED AIR CONDITIONING CONTROL CIRCUIT DIAGNOSIS   Model and Year:  1990 CORVETTE WITH 5.7L L98 AND LT5 ENGINES   Source:  Chevrolet Dealer Service Bulletin   Bulletin Number:  90-400-6E   THIS BULLETIN CANCELS AND SUPERSEDES DEALER...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-1021.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-1021.html</link>
										<description><![CDATA[ Subject:  &nbsp; Loss of Heating or Cooling Control   Model and Year: &nbsp;  1990 Y Car with Electronic Air Conditioning (C68) Option   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:&nbsp;&nbsp;  90-101-1A  (Corporate Bulletin No:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-hvac-diagnostic-codes-723.html</guid>
										<title>1990 - 1996 Corvette: HVAC Diagnostic Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-hvac-diagnostic-codes-723.html</link>
										<description><![CDATA[On 1990 to 1996 Corvettes equipped with RPO C68 (electronic climate control), it is possible to read the HVAC system diagnostic codes from the climate control panel on the dashboard.  To enter the diagnostic mode, press the fan up and down arrow...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</guid>
										<title>1990 - 1995 Corvette | ZR-1: AC Compressor Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</link>
										<description><![CDATA[Type: NippondensoDisplacement: LT5 - 10.0 cubic inches L98 - 12.7 cubic inches
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</guid>
										<title>1988 - 1992 Corvette: Service Bulletin: A/C Compressor Sealing Washer (New Design)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</link>
										<description><![CDATA[ Subject:  A/C COMPRESSOR SEALING WASHER USAGE (NEW DESIGN)   Model and Year:  1988-92 ALL PASSENGER CARS AND TRUCKS EXCEPT GEO   Source:  Chevrolet Service Bulletin   Bulletin Number:  92-35-1D - (10/11/1991) THIS BULLETIN CANCELS AND SUPERSEDES...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
										<description><![CDATA[ Subject:  &nbsp; Hood Rubs Air Conditioning Hose   Model and Year: &nbsp;  1988 - 1989 Corvette   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 89-183-1B    Section:  &nbsp; 1B    Date:&nbsp;&nbsp;&nbsp;  June 1989   TO:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</guid>
										<title>1986 - 1988 Corvette:  Service Bulletin:  New Heater and Air Condition Control Head Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</link>
										<description><![CDATA[ Subject:  &nbsp; New Heater and Air Condition Control Head Assembly   Model and Year: &nbsp;  1986 - 1988 Corvette Coupes Only   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 88-230-1A    Section:  &nbsp; 1A    Date:&nbsp;...]]></description>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinSubject: Moan or Vibration with Air Conditioning RunningModel and Year: 1985 - 87 CorvetteBulletin Number: 87-206Section: 1BDate: Sept., 1987TO: ALL CHEVROLET DEALERSSome 1985 -87 Corvettes may exhibit a moan...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-no-heat-a-c-control-unit-725.html</guid>
										<title>1984 Corvette: Service Bulletin: No Heat - A/C Control Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-no-heat-a-c-control-unit-725.html</link>
										<description><![CDATA[  Model Year:  1984   Subject:  No Heat - A/C Control Unit   Source:  Chevrolet Dealer Service Technical Bulletin   Bulletin Number:  83-T-70, Number Ia   Date:  August, 1983   TO: ALL CHEVROLET DEALERS   Conditions of "no heat" may be the result of...]]></description>
										<description><![CDATA[ Subject:  &nbsp; Engine Stops Running When Starting with Air Conditioning "On"   Model and Year:  &nbsp; 1984 Corvette with Automatic Transmissions   Source:&nbsp;  Chevrolet Dealer Service Bulletin    Bulletin No:  &nbsp; 84-240     Section:  &nbsp...]]></description>
