<title>Home - All Categories - C5 Corvettes  - Body and Trim  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/body-and-trim/42/</link>
										<description><![CDATA[Description:This technical article was published in Composites Technology, September/October 1999, and looks at the C5 fixed roof coupe body structure and discusses the manufacturing and engineering techniques used in developing the hardtop model...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</guid>
										<title>Procedure for Replacing the Reveal Moldings Over Side Windows on a 2001 - 2004 Corvette Z06</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/procedure-for-replacing-the-reveal-moldings-over-side-windows-on-a-2001-2004-corvette-z06-1409.html</link>
										<description><![CDATA[by Ken Ribers The parts being replaced are 10331562 passenger side and 10331563 drivers side.  Materials needed: (purchased from toolmart@autobodytoolmart.com)  3M Adhesive Remover 08984 3M Calk 08578 3M Weatherstrip Adhesive 08011. Disposable...]]></description>
										<description><![CDATA[The service bulletin below was issued on May 10, 1972, but is applicable to all newer generations of Corvette.  Subject:  &nbsp;&nbsp;Removal of Haze or Film From the Inside Surface of Windshields and Other Body Glass   Model and Year: &nbsp;  NA  ...]]></description>
										<description><![CDATA[Subject: Deck Lid Not Flush With Left Hand Quarter Panel (Install Struts, Replace Right Deck Lid Hinge)Source: Chevrolet Dealer Technical Service BulletinNumber:&nbsp; #03-08-66-001 - (01/13/2003)Models: 2003 Chevrolet Corvette Convertible and Z06...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</guid>
										<title>2000 Corvette: Service Bulletin: Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-left-headlamp-door-does-not-stay-closed-455.html</link>
										<description><![CDATA[  Number:  00-08-42-002   Subject:  Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)   Model Year:  2000 Chevrolet Corvette    Condition    Some customers may comment that the left front headlamp door...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-bulletin-left-fuel-tank-to-underbody-contact-rattle-noise-456.html</guid>
										<title>1999 Corvette: Service Bulletin: Left Fuel Tank to Underbody Contact/Rattle Noise</title>
										<description><![CDATA[Subject: Left Fuel Tank to Underbody Contact/Rattle Noise (Install Foam Insulator Pad) Source: Chevrolet Service BulletinNumber: 99-06-04-052Models: 1999 Chevrolet CorvetteCondition: Some customers may comment on a rattle type noise that appears to...]]></description>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  01-08-58-001   Subject:  Windnoise Around B-Pillar (Add Sealer)   Model Year:  1999-2001 Corvette Hardtop    Condition   Some owners may comment on windnoise around the B-pillar.    Cause   The...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</guid>
										<title>1998 Corvette:  Service News:  Corvette Convertible Top Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-service-news-corvette-convertible-top-adjustment-888.html</link>
										<description><![CDATA[ Subject:  Corvette Convertible Top Adjustment   Model and Year:  1998 Corvette   Source:  Chevrolet Pro Service News   Page Number:  9 - 13   Date:  November 1997 - Volume 6, Issue #11
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Tonneau Cover Makes Noise When Going Over Bumps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-tonneau-cover-makes-noise-when-going-over-bumps-462.html</link>
										<description><![CDATA[  Subject:  TONNEAU COVER MAKES NOISE WHEN GOING OVER BUMPS (INSTALL TAPE)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  83-15-06 - (04/22/1998)   Models:  1998 CHEVROLET CORVETTE CONVERTIBLE    Condition:    SOME CUSTOMERS MAY...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Clicking Noise Coming From Folding Top</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-clicking-noise-coming-from-folding-top-463.html</link>
										<description><![CDATA[Subject: CLICKING/TICK NOISE COMING FROM FOLDING TOP (INSTALL INSULATOR STRIP #2 AND #3 BOW)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-15-04 - (04/08/1998)Models: 1998 CHEVROLET CORVETTE CONVERTIBLEConditionSOME CUSTOMERS MAY...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-convertible-top-operating-instructions-1292.html</guid>
										<title>1998 - 2004 Corvette:  Convertible Top Operating Instructions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-convertible-top-operating-instructions-1292.html</link>
										<description><![CDATA[Below is a PDF attachment showing 1998 - 2004 Corvette convertible top operating instructions:
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</guid>
										<title>1998 - 2003 Corvette Convertible: Trunk Door on Convertible Won`t Open All The Way</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-trunk-door-on-convertible-won-t-open-all-the-way-457.html</link>
										<description><![CDATA[The latch spring should be able to lift the trunk door enough to slide your fingers inside and open it the rest of the way. If this does not happen, check to see if the spring inside the latch assembly is missing. If it's not missing, have a service...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</guid>
										<title>1998 - 2003 Corvette Convertible: Prevention of Convertible Top From Rubbing Against the Paint Behind the Plastic Strip</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html</link>
										<description><![CDATA[If you raise the rear portion of the canvas top, you will see the strut rods on each side which can be adjusted. Each rod has a 13mm adjusting nut and a 15mm locking nut. Loosen this locking nut and slightly turn the adjusting nut a little at a time....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-squeak-from-rear-of-convertible-top-replace-protector-assembly-459.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  01-08-67-003   Subject:  Squeak From Rear of Convertible Top (Replace Protector Assembly)   Model Year:  1998-2001 Corvette    Condition   Some customers may comment on a squeak coming from the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-paint-wear-through-at-fifth-bow-replace-seal-460.html</guid>
										<title>1998 - 2001 Corvette Convertible: Service Bulletin: Paint Wear Through at Fifth Bow (Replace Seal)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2001-corvette-convertible-service-bulletin-paint-wear-through-at-fifth-bow-replace-seal-460.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 02-08-111-001Date: 02/05/2002Subject: Paint Wear Through at Fifth Bow (Replace Seal)Model Year: 1998-2001 Chevrolet CorvetteConditionSome customers may comment that the paint around the tonneau cover...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-461.html</link>
										<description><![CDATA[Number: 00-08-64-004Subject: Window Motor Noisy/Inoperative (Replace Motor/Regulator)Model Year: 1998-2000 Chevrolet CorvetteConditionSome customers may comment on:  An inoperative window motor. A growling type noise from inside the door as the glass...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</guid>
										<title>1997+ Corvette: Technical Article: Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-technical-article-corvette-converts-floor-panels-wheelhousings-from-glass-to-chopped-carbon-366.html</link>
										<description><![CDATA[Corvette Converts Floor Panels, Wheelhousings From Glass To Chopped Carbon By Composites Technology Magazine Staff | December 2005 Since 1953, General Motor's Chevrolet Corvette has been a trendsetter in glass-reinforced automotive composites and has...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-water-drips-into-rear-compartment-after-hatch-glass-has-been-opened-464.html</guid>
										<title>1997 Corvette: Service Bulletin: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-water-drips-into-rear-compartment-after-hatch-glass-has-been-opened-464.html</link>
										<description><![CDATA[  Subject:  Water Drips into Rear Compartment After Hatch/Glass Has Been Opened (Modify Weatherstrip)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  73-10-55    Models:  1997 Chevrolet Corvette    Condition:  Some owners may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</guid>
										<title>1997 Corvette: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</link>
										<description><![CDATA[  Subject:  Hatch Will Not Pop Up When Activated in Cold Weather   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  73-10-58   Models:  1997 Chevrolet Corvette    Condition:   Some owners may comment that the hatch will not pop up when...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: General Waterleak Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-general-waterleak-guide-466.html</link>
										<description><![CDATA[  Subject:  General Waterleak Guide   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  02-08-57-003    Models:  1997-2002 Chevrolet Corvette    Condition 1    Water is dripping on the passenger side transmission tunnel.    Cause    The...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</guid>
										<title>1997 - 2004 Corvette: Press Release: Not a Lightweight at All: New Composite from GM Is Stiff Enough for Structure, Resistant to Heat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-press-release-not-a-lightweight-at-all-new-composite-from-gm-is-stiff-enough-for-structure-resistant-to-heat-454.html</link>
										<description><![CDATA[Description:This press release, released from GM on July 24, 1998 takes an in-depth look at the Corvette's sheet molded composite body structure.Excerpt:"The automotive consumer may not even be aware of GM's latest product innovation. But a new...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</guid>
										<title>1997 - 2000 Corvette: Chevrolet Pro Service News:  Corvette Windnoise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-chevrolet-pro-service-news-corvette-windnoise-36.html</link>
										<description><![CDATA[ Source:  &nbsp; Chevrolet Pro Service News   Date:&nbsp;  September 1998, Volume 7, Issue #9
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Loose or Missing Headlamp Door Bezel Plug</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html</link>
										<description><![CDATA[  Subject:  Loose or Missing Headlamp Door Bezel Plug (Install New Bezels and Plugs)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  99-08-42-005   Models:  1997-99 Chevrolet Corvette   This bulletin is being revised to add the 1999...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Door Handles on White Painted Cars Turning Yellow</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-door-handles-on-white-painted-cars-turning-yellow-468.html</link>
										<description><![CDATA[Subject: DOOR HANDLES ON WHITE PAINTED VEHICLES TURNING YELLOW Source: Chevrolet Dealer Technical Service BulletinNumber: 83-17-04Models: 1997-1999 Chevrolet Corvette (1992-98 BUICK SKYLARK 1995-99 BUICK RIVIERA 1997-99 BUICK CENTURY, REGAL 1992-99...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html</link>
										<description><![CDATA[  Subject:  WATERLEAK ABOVE DOOR GLASS (RESEAL BLOWOUT CLIP)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  83-15-08    Models:  1997-1998 Chevrolet Corvette Coupe and 1998 Chevrolet Corvette Convertible    Condition:  SOME OWNERS...]]></description>
										<description><![CDATA[Subject: MUFFLED CLATTER TYPE NOISE COMING FROM CENTER OF PASSENGER COMPARTMENT (REPLACE TRANSMISSION MOUNT ASSEMBLY)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-34-07 - (03/27/1998)Models: 1997-98 CHEVROLET CORVETTE - BUILT PRIOR TO...]]></description>
										<description><![CDATA[  Source:  &nbsp; Chevrolet Dealer Service Bulletin   Number:  &nbsp; 73-15-12A   REVISION: 07/14/98 DIVS INVL 1 7   THIS BULLETIN IS BEING REVISED TO ADD 1998 VIN BREAKPOINT INFORMATION. PLEASE DISCARD CORPORATE BULLETIN NUMBER 73-15-12 (SECTION 10 ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-hiss-type-noise-coming-from-weatherstrip-when-closing-right-or-left-door-472.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Hiss Type Noise Coming From Weatherstrip When Closing Right or Left Door</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-hiss-type-noise-coming-from-weatherstrip-when-closing-right-or-left-door-472.html</link>
										<description><![CDATA[  Subject:  HISS TYPE NOISE COMING FROM WEATHERSTRIP WHEN CLOSING RIGHT AND/OR LEFT DOOR (ADD RELIEF HOLE)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  83-15-07    Models:  1997-1998 Chevrolet Corvette Coupe and 1998 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Front Fender to Door Fit/Appearance (Install Retainer)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-front-fender-to-door-fit-appearance-install-retainer-473.html</link>
										<description><![CDATA[Subject: FRONT FENDER TO DOOR FIT/APPEARANCE (INSTALL RETAINER)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-15-13 - (07/17/1998)Models: 1997-1998 Chevrolet CorvetteCondition:SOME OWNERS MAY COMMENT THAT THE REAR UPPER CORNER OF THE...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Discoloration or Staining of Plenum (Cowl) Air Inlet Screen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</link>
										<description><![CDATA[  Subject:  Discoloration or Staining of Plenum (Cowl) Air Inlet Screen   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  83-15-11    Models:  1997-1998 Chevrolet Corvette    Condition:  SOME CUSTOMERS MAY COMMENT THAT THERE ARE...]]></description>
										<description><![CDATA[ Source:  &nbsp; Chevrolet Pro Service News   Date:&nbsp;  June 1998, Volume 7, Issue Number 6   Subject:  &nbsp; Corvette Water Leak Repair
]]></description>
										<description><![CDATA[#PI0754D: Rear and Side Tempered Glass Spots (Quench Marks) - (Nov 6, 2020)    Subject:&nbsp; Rear and Side Tempered Glass Spots (Quench Marks) &nbsp;   Models:&nbsp; 2021 and Prior GM Passenger Cars and Trucks   Attention:&nbsp; This PI also applies...]]></description>
