<title>Home - All Categories - C5 Corvettes  - Tires and Wheels  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/tires-and-wheels/41/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-c4-c5-corvette-emt-run-flat-tire-servicing-492.html</guid>
										<title>Technical Article: C4/C5 Corvette EMT Run-Flat Tire Servicing</title>
										<description><![CDATA[Description:This four page article details the proper method for servicing C4 and C5 Corvette EMT Run-Flat tires and comes from Hunter Engineering. Hunter Engineering Company is a world leader in automotive service equipment. Hunter Engineering...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - Recommended Wheel Nut/Bolt Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-recommended-wheel-nut-bolt-torque-specifications-368.html</link>
										<description><![CDATA[Subject: Info - Recommended Wheel Nut/Bolt Torque Specifications Model and Year:Table 1: 2003 Passenger Cars Table 2: 2003 Light Duty Trucks Source: Chevrolet Service BulletinBulletin Number: 02-03-10-008 - (12/17/2002) This bulletin is being issued...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</guid>
										<title>2001 Corvette: Service Bulletin: Info - Proper Tire Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-info-proper-tire-pressure-369.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 00-00-90-002ASubject: Info - Proper Tire PressureModel Year: 2001 Passenger Cars and TrucksThis bulletin is being revised to correct/remove tire inflation pressure shown for F-Cars with 17" wheels....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-305.html</guid>
										<title>2001 - 2004 Corvette: Service Bulletin: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2004-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-305.html</link>
										<description><![CDATA[Service Bulletin: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire Replacement Source: Chevrolet Dealer Service Bulletin Number: 00-03-10-005 Subject: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire Replacement...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-low-tire-pressure-message-on-dic-slow-air-loss-370.html</guid>
										<title>2000 Corvette: Service Bulletin: Low Tire Pressure Message on DIC, Slow Air Loss</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-low-tire-pressure-message-on-dic-slow-air-loss-370.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  00-03-10-001   Subject:  Low Tire Pressure Message Repeatedly Displayed on DIC, Slow Air Loss From Tire and Wheel Assembly (Replace Wheel Assembly)   Model Year:  2000 Chevrolet Corvette Built...]]></description>
										<description><![CDATA[Tire Mounting and DismountingThis information applies to the 2000--05 Cadillac Deville, Seville, STS, 2004--05 Cadillac CTS, Escalade, SRX, XLR, 1999--2005 Chevrolet Corvette, 2004--05 Chevrolet Tahoe, Suburban, 2004--05 GMC Yukon, Yukon XL.When...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-info-refinishing-aluminum-wheels-367.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Info - Refinishing Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-info-refinishing-aluminum-wheels-367.html</link>
										<description><![CDATA[Subject: Refinishing Aluminum WheelsSource: Chevrolet Dealer Technical Service BulletinNumber:&nbsp; #99-08-51-007A - (03/07/2002)Models: 2003 and Prior Passenger Cars and Trucks This bulletin is being revised to add additional model years. Please...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-tire-pressure-monitoring-system-information-375.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Tire Pressure Monitoring System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-tire-pressure-monitoring-system-information-375.html</link>
										<description><![CDATA[ GM TechLink, January 2003  Tire Pressure Monitoring System Information Addition A tire pressure monitor (TPM) system is used on Cadillac DeVille, Seville and Chevrolet Corvette. This system was discussed in the November 2000 TechLink. This is a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-tire-pressure-monitoring-system-tpms-grommet-seal-availability-376.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Info - Tire Pressure Monitoring System (TPMS) Grommet/Seal Availability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-tire-pressure-monitoring-system-tpms-grommet-seal-availability-376.html</link>
										<description><![CDATA[Subject: Tire Pressure Monitoring System (TPMS) Grommet/Seal Availability Source: Chevrolet Dealer Technical Service BulletinNumber:&nbsp; 03-03-10-004 - (04/07/2003)Models:1999-2003 Chevrolet Corvette 2000-2003 Cadillac DeVille, DHS, DTS, Seville...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-372.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-info-wheel-pressure-sensors-unable-to-be-reprogrammed-after-tire-replacement-372.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 00-03-10-005Subject: Info - Wheel Pressure Sensors Unable to be Reprogrammed after Tire ReplacementModel Year: 1997-2001Some dealers may find it difficult to reprogram the wheel mounted air pressure...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-wheel-touch-up-paint-373.html</guid>
										<title>1997 - 1999 Corvette: Wheel Touch-Up Paint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-wheel-touch-up-paint-373.html</link>
										<description><![CDATA[Although an official GM touch-up paint is not available for the base 5-spoke wheels the following alternative available at your local autoparts store is available:Plasti-kote Scratch ColorGM 3845Followup from Corvette Action Center Member:"I could...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-remote-keyless-entry-system-rke-and-or-low-tire-pressure-monitoring-system-inoperative-374.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-remote-keyless-entry-system-rke-and-or-low-tire-pressure-monitoring-system-inoperative-374.html</link>
										<description><![CDATA[Subject: Remote Keyless Entry System (RKE) and/or Low Tire Pressure Monitoring System Inoperative (Replace RKE Module)Source: Chevrolet Dealer Technical Service BulletinNumber: 99-08-52-002 - (04/20/1999)Models: 1997-98 Chevrolet CorvetteCondition...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</link>
										<description><![CDATA[Subject: INOPERATIVE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR TIRE PRESSURE MONITOR (TPM) SYSTEM (REPLACE RECEIVER) Source: Chevrolet Dealer Technical Service BulletinNumber: 83-90-14Models: 1997-1998 Chevrolet CorvetteCONDITION:SOME CUSTOMERS MAY...]]></description>
										<description><![CDATA[Run Flat Facts        Goodyear EMT tires are identified by this unique label.  Image:&nbsp; Author      by Hib Halverson  &copy;2004 all rights reserved.  The first run-flat tire was developed by Goodyear in 1978. The first application of a run-flat...]]></description>
