<title>Home - All Categories - C5 Corvettes  - Interior Parts and Trim  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/interior-parts-and-trim/40/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-seatbelt-retractor-377.html</guid>
										<title>2004 Corvette: GM TechLink: Seatbelt Retractor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-seatbelt-retractor-377.html</link>
										<description><![CDATA[From GM TechLink, October 2004: Owners of some 2004 Chevrolet Corvettes may state that the driver or passenger seatbelt will not extend from the seatbelt retractor.If a resolution can't be found through normal diagnosis, replace the affected seatbelt...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-news-corvette-telescoping-steering-wheel-travel-883.html</guid>
										<title>1999 Corvette: Service News: Corvette Telescoping Steering Wheel Travel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-service-news-corvette-telescoping-steering-wheel-travel-883.html</link>
										<description><![CDATA[Subject: Corvette Telescoping Steering Wheel Travel  Model and Year: 1999 Corvette   Source:  Chevrolet Pro Service News   Page Number:  NA   Date: November 1998 - Volume 7, Issue #11 The 1999 Corvette features a telescoping steering wheel that is...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-378.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-service-bulletin-window-motor-noisy-inoperative-378.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 00-08-64-004Subject: Window Motor Noisy/Inoperative (Replace Motor/Regulator)Model Year: 1998-2000 Chevrolet CorvetteConditionSome customers may comment on:  An inoperative window motor. A growling...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-seat-back-twisting-resynchronize-seat-back-recliner-219.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Seat Back Twisting (Resynchronize Seat Back Recliner)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-seat-back-twisting-resynchronize-seat-back-recliner-219.html</link>
										<description><![CDATA[Bulletin No: 04.08.50.005Subject: Seat Back Twisting (Resynchronize Seat Back Recliner) Models: 1997-2004 Chevrolet Corvette ConditionSome customers may comment on the driver's or passenger's seat back twisting.CauseThis condition may be caused by...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Instrument Panel Cluster Function and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</link>
										<description><![CDATA[Scanning the Instrument Panel Cluster (IPC) while driving the Corvette will tell you the speed of the car, how much fuel is in the gas tank, the temperature of the engine coolant and other vehicle information. But it's not the IPC that's really...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-driver-seat-movement-during-acceleration-and-braking-replace-adjuster-assembly-379.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Driver Seat Movement During Acceleration and Braking (Replace Adjuster Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-driver-seat-movement-during-acceleration-and-braking-replace-adjuster-assembly-379.html</link>
										<description><![CDATA[Subject: Driver Seat Movement During Acceleration and Braking (Replace Adjuster Assembly)Source: Chevrolet Dealer Technical Service BulletinNumber: 02-08-50-002Date: April 2002Models: 1997-2002 Chevrolet Corvette with Power Seats (RPO AG1 or AG2)...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-door-rattle-with-moderate-to-high-audio-system-volume-380.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Door Rattle with Moderate to High Audio System Volume</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-door-rattle-with-moderate-to-high-audio-system-volume-380.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  01-08-64-009A   Date:  &nbsp; 06-19-2002   Subject:  Door Rattle with Moderate to High Audio System Volume   Model Year:  1997-2002 Chevrolet Corvette   This bulletin is being revised to update...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-recall-lap-belt-webbing-twisted-381.html</guid>
										<title>1997 - 2000 Corvette: Recall: Lap Belt Webbing Twisted</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-recall-lap-belt-webbing-twisted-381.html</link>
										<description><![CDATA[1997, 1998, 1999, 2000 Corvette RecallGM Service Operations DCS630Urgent - Distribute ImmediatelyDate: November 10, 2000Subject: 00034 - Product Safety Campaign Lap Belt Webbing TwistedModels: 1997-2000 Chevrolet Corvette Model VehiclesTo: All...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-squeak-type-noise-from-leather-shift-boot-when-shifting-gears-382.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Squeak Type Noise From Leather Shift Boot when Shifting Gears</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-squeak-type-noise-from-leather-shift-boot-when-shifting-gears-382.html</link>
										<description><![CDATA[Subject: Squeak Type Noise From Leather Shift Boot when Shifting Gears (Replace Leather Shift Boot)Source: Chevrolet Dealer Technical Service BulletinNumber: 99-07-29-001Models: 1997-99 Chevrolet Corvette with Manual Transmission (RPO MM6...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-smu-revised-seatback-cover-removal-procedure-383.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: SMU - Revised Seatback Cover Removal Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-smu-revised-seatback-cover-removal-procedure-383.html</link>
										<description><![CDATA[  Subject:  SMU - Revised Seatback Cover Removal Procedure   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  99-08-50-002    Models:  1997-99 Chevrolet Corvette   This bulletin is being issued to revise the seatback cover and pad...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-premature-wear-of-leather-material-on-bucket-seatback-bolster-384.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Premature Wear of Leather Material on Bucket Seatback Bolster</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-premature-wear-of-leather-material-on-bucket-seatback-bolster-384.html</link>
										<description><![CDATA[Subject: Premature Wear of Leather Material on Bucket Seatback Bolster (Replace Cover)Source: Chevrolet Dealer Technical Service BulletinNumber: 99-08-50-010Models: 1997-99 Chevrolet Corvette Built Prior to VIN Breakpoint X5116322Condition Some...]]></description>
										<description><![CDATA[ Subject:&nbsp;  Rattle Noises  Model and Year:&nbsp;  1997 - 1998 Corvette   Source:&nbsp;  Chevrolet Pro Service News   Page Number:  &nbsp; 1  Date:&nbsp; May 1998 - Volume 7 - Number 5 Two rattle noises may be heard on some 1997-98 Corvette...]]></description>
