<title>Home - All Categories - C5 Corvettes  - Engine - Drivetrain  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/engine-drivetrain/37/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-ses-lamp-setting-a-p0106-and-or-p0506-1315.html</guid>
										<title>2017 Corvette:  Service Bulletin: SES Lamp Setting A P0106 And/or P0506</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-ses-lamp-setting-a-p0106-and-or-p0506-1315.html</link>
										<description><![CDATA[#PIP5423: SES Lamp Setting A P0106 And/or P0506 - (Oct 3, 2016)     Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Cadillac   Escalade   2015   2017   SOP   END   L86   All     Cadillac   CTS-V   2016   2017   SOP...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-check-gauges-light-battery-voltage-low-accessory-drive-belt-slipping-or-missing-install-crankshaft-balancer-and-washer-from-wpc-331.html</guid>
										<title>2005 Corvette: Service Bulletin: Check Gauges Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Crankshaft Balancer and Washer from WPC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-check-gauges-light-battery-voltage-low-accessory-drive-belt-slipping-or-missing-install-crankshaft-balancer-and-washer-from-wpc-331.html</link>
										<description><![CDATA[Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Crankshaft Balancer and Washer from WPC) Bulletin Number:&nbsp; 05-06-01-001B 2005 Chevrolet Corvette with 6.0L Engine (VIN U - RPO LS2)  Built Prior to VIN...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</guid>
										<title>2004 Corvette: GM TechLink: Oil Pump to Case Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</link>
										<description><![CDATA[Source:&nbsp; GM TechLink,&nbsp;July 2004:  This information applies to 2004 Light Duty Trucks, Corvette and GTO.   General Motors Powertrain has made a design change to oil pump to case oil seal on the 2004 4L60E (M30) and the 4L65E (M32). The new...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</guid>
										<title>2004 Corvette:  Campaign Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
										<description><![CDATA[See attached PDF below:
]]></description>
										<description><![CDATA[Service Bulletin #:&nbsp; 06-00-89-031 Date:&nbsp;June 2006 Subject:&nbsp; Engine and Automatic Transmission/Transaxle Identification Model(s): 2004 - 2007 GM Passenger Cars and Trucks (Including Saturn)2004-2007 Hummer H22006-2007 Hummer H32005-2007...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</guid>
										<title>2004 - 2005 Corvette: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html</link>
										<description><![CDATA[From GM TechLink, February 2004: Two new style fuel line quick connects are in use.The TI Group Global Quick Connector is used on C/K trucks, S/T trucks, Malibu Sedan, Cadillac XLR and the 2004.5 and 2005 Chevrolet Corvette.The Legris QC is used on...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Fuel Tank System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-fuel-tank-system-389.html</link>
										<description><![CDATA[  Corvette and Cadillac XLR   Partway through model year 2003, a new fuel tank system was introduced on the Corvette  (fig. 1)  . This system continues with slight differences in the 2004 Corvette and Cadillac XLR.            TIP:    For 2003...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</guid>
										<title>2003 - 2004 Corvette: GM TechLink: Coolant Leak at Cup Plugs</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-2004-corvette-gm-techlink-coolant-leak-at-cup-plugs-388.html</link>
										<description><![CDATA[From GM TechLink, June 2004: This information applies to 2003-04 Chevrolet and GMC C/K trucks, Cadillac Escalade, and Corvette, and 2004 Cadillac CTSV and Pontiac GTO with GEN III V8 engines.If coolant appears to be leaking at the head cup plugs,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</guid>
										<title>2001 Corvette: Service Bulletin: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html</link>
										<description><![CDATA[Subject: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)Source: Chevrolet Dealer Technical Service BulletinNumber: 02-06-01-021Models: 2001 Chevrolet Corvette with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)1999-2002 Chevrolet...]]></description>
										<description><![CDATA[Subject: Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift (Reprogram PCM)Source: Chevrolet Dealer Technical Service BulletinNumber: 02-06-04-001Date: January 2002Models:&nbsp; 2001 Chevrolet Corvette with 5...]]></description>
										<description><![CDATA[2001 Corvette RecallGM Service Operations DCS890Urgent - Distribute ImmediatelyDate: February 14, 2001Subject: 00103 - Product Emission Campaign Emission Label ErrorModels: MODELS: CERTAIN 2001 CHEVROLET CAMARO, CORVETTE; PONTIAC FIREBIRD EQUIPPED...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
										<description><![CDATA[Subject: Engine Knock or Lifter Noise (Replace O-Ring)Model and Year: 2001-2002 Chevrolet Camaro2001-2003 Chevrolet Corvette2001-2002 Pontiac Firebird2002-2003 Cadillac Escalade, Escalade EXT2000-2003 Chevrolet Suburban, Tahoe2001-2003 Chevrolet...]]></description>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 02-06-04-005Subject: SMU - Revised DTC P1221 Model Year: 2001-2002Revised DTC P12212001-2002 Chevrolet Corvette2001 Chevrolet and GMC C/K Pickup and Utility Models (Silverado, Sierra, Sierra C3,...]]></description>
										<description><![CDATA[#PIP4925A: SES Light with Fuel Trim and or Oxygen Sensor Codes - (Mar 21, 2017)    Subject:&nbsp; SES Light with Fuel Trim and or Oxygen Sensor Codes        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      All   All...]]></description>
										<description><![CDATA[Subject: Hesitation, Sag, Stumble and/or Backfire on Acceleration Source: Chevrolet Service BulletinNumber: 99-06-04-030Models: 1999 Chevrolet Corvette with 5.7 L Engine (VIN G -- RPO LS1)Condition: Some customers may comment on a hesitation, sag,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-higher-than-expected-oil-consumption-308.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Higher Than Expected Oil Consumption</title>
										<description><![CDATA[Subject: Higher Than Expected Oil Consumption (Replace Rings and Engine Valley Cover)Source: Chevrolet Dealer Technical Service BulletinNumber: 01-06-01-023AModels: 1999-2001 Chevrolet Camaro, 1999-2002 Chevrolet Corvette, 1999-2001 Pontiac Firebird,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Needle Bearings Found In Oil Pan (Replace Rocker Arms)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</link>
										<description><![CDATA[Subject: Needle Bearings Found In Oil Pan (Replace Rocker Arms)Source: Chevrolet Dealer Technical Service BulletinNumber: 02-06-01-029Models:1998-2002 Chevrolet Camaro, Corvette1998-2002 Pontiac Firebird2002 Cadillac Escalade, Escalade EXT1999-2002...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
										<description><![CDATA[  Subject:  Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  02-06-04-023    Models:  1998-2002 Chevrolet...]]></description>
										<description><![CDATA[#PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)    Subject: Torque Tube Fully Serviceable   Models: 2004 - 2009 Cadillac XLR, XLR-V   1997 - 2011 Chevrolet Corvette, Corvette Z06   2009 - 2011 Chevrolet Corvette ZR1     This PI was...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-vehicle-is-difficult-to-fuel-or-filling-station-pump-shuts-off-before-tank-is-full-405.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Vehicle is Difficult to Fuel or Filling Station Pump Shuts Off Before Tank is Full</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-vehicle-is-difficult-to-fuel-or-filling-station-pump-shuts-off-before-tank-is-full-405.html</link>
										<description><![CDATA[Service Bulletin #: 04-06-04-031 - Issued: 4/22/04  Vehicle is difficult to fuel or filling station pump shuts off before tank is full 1997 - 2004Chevrolet Corvette Condition: You may find that when attempting to fill your fuel tank with gas, the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-fluid-leak-at-rear-axle-replace-left-differential-side-cover-0-ring-and-left-axle-shaft-seal-add-sealant-to-side-cover-flange-404.html</guid>
										<title>1997 - 2004 Corvette: Service Bulletin: Fluid Leak at Rear Axle (Replace Left Differential Side Cover 0-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-service-bulletin-fluid-leak-at-rear-axle-replace-left-differential-side-cover-0-ring-and-left-axle-shaft-seal-add-sealant-to-side-cover-flange-404.html</link>
										<description><![CDATA[Drivetrain - Rear Differential Fluid LeakBulletin No.: 03-04-20-006Date: November 18, 2003TECHNICALSubject:Fluid Leak at Rear Axle (Replace Left Differential Side Cover 0-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange)Models:2004...]]></description>
										<description><![CDATA[Method 1  Turn the ignition on, but make sure the engine is off. Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage. Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 99%" will appear on the display. ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</guid>
										<title>1997 - 2004 Corvette:  Technical Article: The Millenium Motor: Inside C5`s LS1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-the-millenium-motor-inside-c5-s-ls1-engine-386.html</link>
										<description><![CDATA[The Millennium Motor: Inside C5's, LS1 Engine Your first, in-depth look at what will power Corvettes into the next century. by Hib Halverson&copy;1996,1997 Shark CommunicationsAdapted from material published on the Vettenet and ZR1 net mail lists in...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-output-shaft-seal-replacement-procedure-397.html</guid>
										<title>1997 - 2003 Corvette: Service Manual Update: Revised Output Shaft Seal Replacement Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-output-shaft-seal-replacement-procedure-397.html</link>
										<description><![CDATA[  Subject:  Revised Output Shaft Seal Replacement Procedure   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  &nbsp; 03-04-20-002 - (01/31/2003)   Models:  1997-2003 Chevrolet Corvette  This bulletin is being issued to revise the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: SMU - Revised Side Cover and Gasket Replacement (RH)/Differential Carrier Cover and Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  02-04-20-003   Date:  &nbsp; 07-18-2002   Subject:  SMU - Revised Side Cover and Gasket Replacement (RH)/Differential Carrier Cover and Seal Replacement - Right   Model Year:  1997-2002...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Intermittent Accessory Drive Rumble During Garage Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html</link>
										<description><![CDATA[Subject: Intermittent Accessory Drive Rumble Noise During Garage Shift and/or During Parking Lot Maneuvers (Install New Generator with Decoupler Pulley and Accessory Drive Tensioner)Source: Chevrolet Dealer Technical Service BulletinNumber: 99-06-04...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</guid>
										<title>1997 - 1999: Service Bulletin: Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-service-bulletin-engine-low-coolant-light-comes-on-inspect-rad-surge-tank-replace-reposition-400.html</link>
										<description><![CDATA[  Subject:  Engine Low Coolant Light Comes On At Start-Up (Inspect for 2nd Design Radiator Surge Tank and Replace/Reposition)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  99-06-02-016    Models:  1997-1999 Chevrolet Corvette ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-accessory-drive-squeak-replace-idler-pulley-401.html</link>
										<description><![CDATA[  Subject:  Technical - Accessory Drive Squeak (Replace Idler Pulley)   Source:  Chevrolet Service Bulletin   Number:  99-06-01-007   Models:   1997 - 1999 Chevrolet Corvette  1998 - 1999 Chevrolet Camaro  1998 - 1999 Pontiac Firebird  with 5.7 L...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Reduced Engine Power Message Along With Partic. Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-reduced-engine-power-message-along-with-partic-powertrain-402.html</link>
										<description><![CDATA[Subject: REDUCED ENG. POW. MESSAGE ALONG W/ PARTIC. PWRTRAIN Source: Chevrolet Dealer Technical Service BulletinNumber: 87-65-16Models: 1997-98 CHEVROLET CORVETTE WITH 5.7L V8 ENGINE (VIN G - RPO LS1)ConditionCONDITION #1: INTERMITTENT REDUCED ENGINE...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Belt Rumble Noise at Low Idle Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-belt-rumble-noise-at-low-idle-speeds-403.html</link>
										<description><![CDATA[Subject: BELT RUMBLE NOISE AT LOW IDLE SPEEDS (INSTALL ACCESSORY DRIVE BELT TENSIONER/ACCESSORY DRIVE BELT)Source: Chevrolet Dealer Technical Service BulletinNumber: 87-61-13Models: 1997-1998 CHEVROLET CORVETTE WITH 5.7L ENGINE (VIN G - RPO LS1) AND...]]></description>
										<description><![CDATA[ Subject:&nbsp;  Rattle Noises  Model and Year:&nbsp;  1997 - 1998 Corvette   Source:&nbsp;  Chevrolet Pro Service News   Page Number:  &nbsp; 1  Date:&nbsp; May 1998 - Volume 7 - Number 5 Two rattle noises may be heard on some 1997-98 Corvette...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Corvette Engine Low Coolant MIL</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-corvette-engine-low-coolant-mil-1048.html</link>
										<description><![CDATA[ Subject:&nbsp;  Corvette Engine Low Coolant MIL   Model and Year:&nbsp;  1997 - 1998 Corvette   Source:&nbsp;  Chevrolet Pro Service News   Page Number:  &nbsp; 2   Date:&nbsp;  May 1998 - Volume 7 - Number 5 The engine low coolant MIL may come on...]]></description>
