<title>Home - All Categories - C5 Corvettes  - Electrical and Ignition  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/electrical-and-ignition/36/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</guid>
										<title>2009 Corvette:  Pairing Key Fob to Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-pairing-key-fob-to-car-1284.html</link>
										<description><![CDATA[Below are instructions for pairing a key fob to a 1999 Corvette: To match transmitters to your vehicle, do the following:1. Turn the ignition key to ON.2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<description><![CDATA[Owners of some 2005 Chevrolet Corvettes and 2004 - 05 Cadillac XLRs may experience a no-crank condition, with no codes in any module. The concern may be followed by an inoperative transmission range indicator (PRNDL). The Tech 2 will show the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</guid>
										<title>2004 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-diagnostic-trouble-codes-225.html</link>
										<description><![CDATA[DTC B0016, B0017, or B0018Right Front/Passenger Frontal Deployment Loop (Stage 1) CircuitDTC B0022, B0024, or B0026Left Front/Driver Frontal Deployment Loop (Stage 1) CircuitDTC B0051Deployment CommandedDTC B0053Deployment Commanded with Loop...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</guid>
										<title>2004 - 2008 Corvette: Service Campaign: Unwanted Repeat Calls to OnStar</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2008-corvette-service-campaign-unwanted-repeat-calls-to-onstar-13.html</link>
										<description><![CDATA[10037B - Unwanted Repeat Calls to OnStar Service Campaign Bulletin Reference Number(s): 10037B Date of Issue: May 13, 2011 Affected Model(s): 2004-2008 Chevrolet Corvette CONDITION Certain 2002-2009 model-year vehicles equipped with OnStar may have a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</guid>
										<title>2003 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</link>
										<description><![CDATA[Subject: Erratic Fuel Gauge Readings, Fuel Gauge Reads Empty When There Is Fuel In Tank, DTC P0463 Set, Service Fuel System Message DisplayedNumber: 05.06.04.041AModels: 2004-2005 Cadillac XLR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</guid>
										<title>2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</link>
										<description><![CDATA[Model Year: 2002Subject: Erratic Fuel Gauge Reading (Reprogram the PCM)Source: Chevrolet Dealer Service Technical BulletinNumber: 02-06-04-010ConditionSome owners may comment about the fuel gauge intermittently indicating an empty reading and then...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</guid>
										<title>2002 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</guid>
										<title>2001 Corvette: Service Bulletin: Traction Control/Handling Lamp On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-traction-control-handling-lamp-on-407.html</link>
										<description><![CDATA[Model Year: 2001Subject: Traction Control/Handling Lamp On, Drivers Info Center Displays Service Active HandlingSource: Chevrolet Dealer Service Technical BulletinNumber: 01-05-25-004Date: March, 2001Condition:Some customers may comment that the ...]]></description>
										<description><![CDATA[Subject: Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift (Reprogram PCM)Source: Chevrolet Dealer Technical Service BulletinNumber: 02-06-04-001Date: January 2002Models:&nbsp; 2001 Chevrolet Corvette with 5...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-diagnostic-trouble-codes-226.html</guid>
										<title>2001 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-diagnostic-trouble-codes-226.html</link>
										<description><![CDATA[DTC B0016RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance LowDTC B0017RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) OpenDTC B0018RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground...]]></description>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 02-06-04-005Subject: SMU - Revised DTC P1221 Model Year: 2001-2002Revised DTC P12212001-2002 Chevrolet Corvette2001 Chevrolet and GMC C/K Pickup and Utility Models (Silverado, Sierra, Sierra C3,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</guid>
										<title>2000 Corvette: Service Bulletin: Tech - Left Headlamp Door Does Not Stay Closed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-tech-left-headlamp-door-does-not-stay-closed-408.html</link>
										<description><![CDATA[  Number:  00-08-42-002   Subject:  Tech - Left Headlamp Door Does Not Stay Closed   Model Year:  2000    Condition   Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html</guid>
										<title>2000 Corvette: Service Bulletin: Power Antenna Not Working Properly or is Completely Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html</link>
										<description><![CDATA[Number: 00-08-44-006ASubject: Power Antenna Not Working Properly or is Completely Inoperative (Replace Antenna O-Ring Assembly/Cap Nut &amp; Clean Mast)Model Year: 2000 Chevrolet Corvette, 2000 Pontiac Firebird, 2000 Chevrolet and GMC G-VanThis...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</guid>
										<title>2000 Corvette: ABS Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</link>
										<description><![CDATA[DTC/DescriptionTypeIlluminate Indicator or Turn ON DIC Message DTC B2597 Traction Control System Switch CircuitBCMNone DTC C1214 Solenoid Valve Relay Contact or Coil Circuit OpenABSABS/TCS/DIC DTC C1217 Pump Motor Relay Contact Circuit OpenABSABS/TCS...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</guid>
										<title>2000 Corvette:  Electrical Features Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-electrical-features-information-1321.html</link>
										<description><![CDATA[2000 CHEVROLET CORVETTEELECTRICAL FEATURES INFORMATION THIS SHEET DESCRIBES SOME OF THE UNIQUE ELECTRICAL FEATURES THAT YOUR NEW CORVETTE MAY HAVE. IT IS INTENDED TO BE AN AID TO NEW BUYERS. PLEASE CONSULT YOUR OWNER'S MANUAL FOR A MORE DETAILED...]]></description>
										<description><![CDATA[#PIP4925A: SES Light with Fuel Trim and or Oxygen Sensor Codes - (Mar 21, 2017)    Subject:&nbsp; SES Light with Fuel Trim and or Oxygen Sensor Codes        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      All   All...]]></description>
										<description><![CDATA[Service Bulletin #:&nbsp; 02-07-30-001D Date: December 2005 Subject:&nbsp; Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 Model(s): 2000-2006 GM Passenger Cars and Light Duty Trucks2003-2006 Hummer H22006 Hummer H32005-2006...]]></description>
										<description><![CDATA[Subject:&nbsp; OnStar Phone Number Concerns (Phone Number Incorrect/Assigned to Another Vehicle/Phone) That Occur During Diagnosis of OnStar System.Models:&nbsp; 2000-2006 GM Passenger Cars and Trucks2003-2006 HUMMER H22006 HUMMER H32003-2006 Saturn...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</guid>
										<title>2000 - 2004 Corvette: Service Bulletin: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2004-corvette-service-bulletin-twilight-sentinel-automatic-headlamp-control-not-functioning-correctly-or-is-inoperative-218.html</link>
										<description><![CDATA[Bulletin No: 03.08.42.012Subject: Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative (Reprogram BCM) 2000-2004 Chevrolet Corvette with Automatic Headlamp Control (RPO T82) ConditionSome customers may comment that...]]></description>
										<description><![CDATA[Subject: Hesitation, Sag, Stumble and/or Backfire on Acceleration Source: Chevrolet Service BulletinNumber: 99-06-04-030Models: 1999 Chevrolet Corvette with 5.7 L Engine (VIN G -- RPO LS1)Condition: Some customers may comment on a hesitation, sag,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-diagnostic-trouble-codes-222.html</guid>
										<title>1999 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-corvette-diagnostic-trouble-codes-222.html</link>
										<description><![CDATA[&nbsp;1016 Loss Of PCM Communications1064 Loss Of BCM Serial Data Communication1096 Loss Of IPC Communications1255 Generic Loss Of CommunicationsB0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance LowB0017 RF/Passenger...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</guid>
										<title>1999 - 2013 Corvette: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2013-corvette-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-1331.html</link>
										<description><![CDATA[#PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)    Subject:&nbsp; HUD - Head Up Display Information - Multiple Conditions or Questions   Models:&nbsp; 2010 - 2013 Buick LaCrosse   1999 - 2005 Buick...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</guid>
										<title>1999 - 2011 Corvette:  GM TechLink: Head-Up Display Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</link>
										<description><![CDATA[ Source:  GM Techlink    Date:  &nbsp;January 2011    Subject:  &nbsp;&nbsp;Head-Up Display Conditions    Models:  1999 - 2011 Chevrolet Corvette   A Head-Up Display (HUD) (Fig. 9) is available on the 1999-2005 Park Avenue, 2010-2011 Lacrosse, 2004...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-411.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-411.html</link>
										<description><![CDATA[Subject: Erratic Fuel Gauge Reading (Reprogram the PCM)Source: Chevrolet Dealer Technical Service BulletinNumber:&nbsp; 02-06-04-010A - (06/27/2003)Models: 1999-2002 Chevrolet Corvette This bulletin is being revised to add models and update the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</guid>
										<title>1998 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-diagnostic-trouble-codes-223.html</link>
										<description><![CDATA[&nbsp;P0101 Mass Air Flow (MAF) Sensor PerformanceP0102 Mass Air Flow (MAF) Sensor Circuit Low FrequencyP0103 Mass Air Flow (MAF) Sensor Circuit High FrequencyP0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low VoltageP0108 Manifold Absolute...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</guid>
										<title>1998 Corvette Convertible: Service Bulletin: Rear Window Defogger Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-corvette-convertible-service-bulletin-rear-window-defogger-inoperative-413.html</link>
										<description><![CDATA[Subject: REAR WINDOW DEFOGGER INOPERATIVE (PLUG IN, REROUTE, REPAIR OR REPLACE CONNECTORS)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-81-25 - (04/08/1998)Models: 1998 CHEVROLET CORVETTE CONVERTIBLEConditionSOME CUSTOMERS MAY COMMENT...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-recall-electronic-column-lock-412.html</guid>
										<title>1998 - 2000 Corvette: Recall: Electronic Column Lock</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2000-corvette-recall-electronic-column-lock-412.html</link>
										<description><![CDATA[1998-2000 Corvette RecallGM Service Operations DCS851Urgent - Distribute ImmediatelyDate: September 6, 2001Subject: 01044A - Customer Satisfaction Campaign Corvette Electronic Column LockModels: 1998-2000 CorvetteTo: All Chevrolet DealersAttn:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</guid>
										<title>1997 Corvette: Service Bulletin: Various Driveability Issues (Repair/Secure Wire Harness at PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-various-driveability-issues-repair-secure-wire-harness-at-pcm-414.html</link>
										<description><![CDATA[Subject: VARIOUS DRIVEABILITY CONDITIONS (REPAIR/SECURE WIRE HARNESS AT PCM)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-81-24 - (03/03/1998)Models: 1997 CHEVROLET CORVETTECondition:SOME CUSTOMERS MAY REPORT ONE OR MORE DRIVEABILITY...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-erratic-fuel-gauge-readings-415.html</guid>
										<title>1997 Corvette: Service Bulletin: Erratic Fuel Gauge Readings</title>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  73-83-22    SUBJECT: ERRATIC FUEL GAUGE READINGS (REPAIR PINCHED WIRES)     MODELS:  1997 CHEVROLET CORVETTE    CONDITION:    SOME OWNERS MAY COMMENT ON ERRATIC READINGS FROM THE FUEL GAUGE.   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</guid>
										<title>1997 Corvette: Product Campaign: PCM Calibration Reflash</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-product-campaign-pcm-calibration-reflash-416.html</link>
										<description><![CDATA[Subject: CAMPAIGN CALIBRATION REFLASH Source: Chevrolet Campaign BulletinNumber: 97040AModels: 1997 Chevrolet CorvetteNOTE: GM OF CANADA VERSION OF CAMPAIGN 97040A IS LOCATED BELOW THE U.S. VERSION  PRODUCT CAMPAIGNS 97040(A) APRIL, 1998THIS BULLETIN...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-diagnostic-trouble-codes-224.html</guid>
										<title>1997 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-diagnostic-trouble-codes-224.html</link>
										<description><![CDATA[&nbsp;P0101 Mass Air Flow (MAF) Sensor Performance P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage P0108 Manifold...]]></description>
										<description><![CDATA[Method 1  Turn the ignition on, but make sure the engine is off. Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage. Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 99%" will appear on the display. ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-special-policy-adjustment-electronic-column-lock-system-158.html</guid>
										<title>1997 - 2004 Corvette: Recall: Special Policy Adjustment  - Electronic Column Lock System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-special-policy-adjustment-electronic-column-lock-system-158.html</link>
										<description><![CDATA[NOTE:&nbsp; A copy of this recall notice is attached below in PDF format.  Bulletin #: 04006C Date: February 6, 2006 Subject:&nbsp; Electronic Column Lock Model(s):  1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUALTRANSMISSION 1997-2000 CHEVROLET...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</guid>
										<title>1997 - 2004 Corvette: Recall: Electronic Column Lock System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-recall-electronic-column-lock-system-418.html</link>
										<description><![CDATA[NOTE:&nbsp; A copy of this recall is attached down below in PDF format.  Subject: GMP04-112 - 04006A - Electronic Column Lock System MODELS: CERTAIN 1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUAL TRANSMISSION, 1997-2000 CHEVROLET CORVETTE...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Instrument Panel Cluster Function and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-instrument-panel-cluster-function-and-diagnosis-385.html</link>
										<description><![CDATA[Scanning the Instrument Panel Cluster (IPC) while driving the Corvette will tell you the speed of the car, how much fuel is in the gas tank, the temperature of the engine coolant and other vehicle information. But it's not the IPC that's really...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-misfire-dtcs-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-419.html</link>
										<description><![CDATA[Subject: Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems Source: Chevrolet Dealer Technical Service BulletinNumber: 02-06-05-004Models: 2003 and Prior GM Passenger Cars and Light Duty Trucks, 2003 HUMMER H2, 2003 and...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</guid>
										<title>1997 - 2003 Corvette: Service Bulletin: Info - PCM Reprogramming and Data Line Diagnosis using J 44236-A</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-pcm-reprogramming-and-data-line-diagnosis-using-j-44236-a-427.html</link>
										<description><![CDATA[  Subject:  Info - PCM Reprogramming and Data Line Diagnosis using J 44236-A   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  &nbsp; #02-06-04-022 - (05/09/2002)     Models:  1997 - 2003 Chevrolet Corvette  All 1997-2003 Chevrolet...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-inaccurate-erratic-fuel-level-gauge-readings-420.html</guid>
										<title>1997 - 2000 Corvette: Service Bulletin: Inaccurate/Erratic Fuel Level Gauge Readings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-inaccurate-erratic-fuel-level-gauge-readings-420.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  01-06-04-022   Subject:  Inaccurate/Erratic Fuel Level Gauge Readings (Install New Sensor, Strainer and/or RH Fuel Sender Assembly)   Model Year:  1997-2000 Chevrolet Corvette    Condition   ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</guid>
										<title>1997 - 2000 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</link>
										<description><![CDATA[The following information is for reference only. Check the service manual for your particular model year of Corvette.To enter the "diagnostic mode", use the following procedure:   Turn the ignition key to the ON position, but don not start the car....]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-no-start-condition-non-functional-pcm-after-reprogramming-422.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: No Start Condition, Non-Functional PCM After Reprogramming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-no-start-condition-non-functional-pcm-after-reprogramming-422.html</link>
										<description><![CDATA[  Subject:  NO START CONDITION, NON-FUNCTIONAL PCM AFTER REPROGRAMMING (REPLACE/REPROGRAM PCM)   Source:  Chevrolet Service Bulletin   Number:  87-65-10   Models:  1997-99 CHEVROLET CORVETTE WITH 5.7L ENGINE (VIN G - RPO LS1)    Condition:    SOME...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</guid>
										<title>1997 - 1999 Corvette: Service Bulletin: Chime Sounds When Key is Removed from Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-chime-sounds-when-key-is-removed-from-ignition-423.html</link>
										<description><![CDATA[  Subject:  Chime Sounds When Key is Removed from Ignition, Intermittent Operation of Power Door Locks, Keyless Entry, Steering Column Lock or Memory Seats (Inspect/Replace Lock Cylinder Actuator or Lock Cylinder Assembly)   Source:  Chevrolet Dealer...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</guid>
										<title>1997 - 1999 Corvette:  Service News:  Corvette Illuminated Check Gauges Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-news-corvette-illuminated-check-gauges-light-882.html</link>
										<description><![CDATA[Subject: Corvette Illuminated Check Gauges Light  Model and Year:  1997 - 1999 Corvette   Source:  Chevrolet Pro Service News   Page Number:  NA   Date: November 1998 - Volume 7, Issue #11 Some 1997 - 1999 Corvettes may exhibit an illuminated "check...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</guid>
										<title>1997 - 1998, 2000 Corvette: Service Bulletin: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-2000-corvette-service-bulletin-electronic-steering-column-lock-may-refuse-to-operate-dic-service-message-displayed-426.html</link>
										<description><![CDATA[  Source:  Chevrolet Dealer Service Bulletin   Number:  01-02-35-008   Subject:  Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed (Update Column Lock Wiring, Install Revised Relay and/or Replace Electronic Column...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Inoperative Remote Keyless Entry System and/or Tire Pressure Monitor System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html</link>
										<description><![CDATA[Subject: INOPERATIVE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR TIRE PRESSURE MONITOR (TPM) SYSTEM (REPLACE RECEIVER) Source: Chevrolet Dealer Technical Service BulletinNumber: 83-90-14Models: 1997-1998 Chevrolet CorvetteCONDITION:SOME CUSTOMERS MAY...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Fuel Pump Noise Coming From Fuel Pump/Tank (Replace Fuel Pump Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-fuel-pump-noise-coming-from-fuel-pump-tank-replace-fuel-pump-assembly-425.html</link>
										<description><![CDATA[  Subject:  FUEL PUMP NOISE COMING FROM FUEL PUMP OR FUEL TANK AREA (REPLACE FUEL PUMP ASSEMBLY)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  83-63-10 - (04/28/1998)   Models:  1997-98 CHEVROLET CORVETTE BUILT PRIOR TO VIN...]]></description>
										<description><![CDATA[This information applies to 1996-2005 passenger cars, trucks and utilities.In the past, star washers have been used under most ground connections. It was believed using a star washer would improve continuity to ground and prevent the ground fastener...]]></description>
										<description><![CDATA[ Subject:&nbsp;  Passive Keyless Entry   Model and Year:&nbsp;  1995 - 2004 Corvette   Source:&nbsp;  Chevrolet Pro Service News   Page Number:  &nbsp; 2   Date:&nbsp;  May 1998 - Volume 7 - Number 5
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Diagnostics and Procedures to Prevent Codes 16 and 26 Due to Corrosion Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-diagnostics-and-procedures-to-prevent-codes-16-and-26-due-to-corrosion-revised-561.html</link>
										<description><![CDATA[ Subject:  SERVICE MAN. UPDATE SEC.9J A/B REV. SIR DIAGNOSTIC PROCEDURE   Model and Year:  1990 CORVETTE   Source:  Chevrolet Service Bulletin   Bulletin Number:  90-436-9J - (11/07/1991) Some 1990 Corvettes have set SIR Sensor Codes 16 and 26. The...]]></description>
