<title>Home - All Categories - C5 Corvettes  - Clutch and Transmission  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/clutch-and-transmission/35/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</guid>
										<title>2006 Corvette: Service Bulletin: 6L80 Automatic Transmission (RPO MYC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-6l80-automatic-transmission-rpo-myc-351.html</link>
										<description><![CDATA[Models: 2006 Chevrolet Corvette with 6L80 Automatic Transmission (RPO MYC) Purpose This bulletin introduces and highlights features of the new Hydra-Matic 6L80 Automatic Transmission. Introduction The Hydra-Matic 6L80 is the first member of a new...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<description><![CDATA[Owners of some 2005 Chevrolet Corvettes and 2004 - 05 Cadillac XLRs may experience a no-crank condition, with no codes in any module. The concern may be followed by an inoperative transmission range indicator (PRNDL). The Tech 2 will show the...]]></description>
										<description><![CDATA[Service Bulletin #:&nbsp; 06-00-89-031 Date:&nbsp;June 2006 Subject:&nbsp; Engine and Automatic Transmission/Transaxle Identification Model(s): 2004 - 2007 GM Passenger Cars and Trucks (Including Saturn)2004-2007 Hummer H22006-2007 Hummer H32005-2007...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 02-07-30-001D Date:&nbsp;December&nbsp;2005 Subject:&nbsp; Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 Model(s): 2000 - 2006 GM Passenger&nbsp;Cars and Light Duty Trucks2003 - 2006 Hummer H22006...]]></description>
										<description><![CDATA[Service Bulletin #:&nbsp; 02-07-30-001D Date: December 2005 Subject:&nbsp; Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 Model(s): 2000-2006 GM Passenger Cars and Light Duty Trucks2003-2006 Hummer H22006 Hummer H32005-2006...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2006-corvette-service-bulletin-intermittent-neutral-from-a-stop-or-2-3-shift-433.html</guid>
										<title>1999 - 2006 Corvette: Service Bulletin: Intermittent Neutral from a Stop or 2-3 Shift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2006-corvette-service-bulletin-intermittent-neutral-from-a-stop-or-2-3-shift-433.html</link>
										<description><![CDATA[Date: April 19, 2006 Subject: Intermittent Neutral from a Stop or 2-3 Shift Bulletin: #PIP3002DModels: 1999-2006 GM Cars, Light Duty Trucks and Utilities equipped with 4L60E/4L65E transmissions The following diagnosis might be helpful if the vehicle...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</guid>
										<title>1999 - 2002 Corvette: Service Bulletin: DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html</link>
										<description><![CDATA[  Number:  01-07-30-038   Subject:  DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris)   Model Year:    1999-2002 Chevrolet Camaro, Corvette ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</guid>
										<title>1998 - 1999 Corvette: Service Bulletin: Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</link>
										<description><![CDATA[  Subject:  Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy)   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  99-07-30-013   Models:   1999 Cadillac Escalade  1998-99 Chevrolet Camaro, Corvette  1998-99 Pontiac...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</guid>
										<title>1997 - 2004 Corvette:  T-56 Borg Warner Transmission Repair Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</link>
										<description><![CDATA[This PDF file was downloaded from the Internet. This illustrated 47 page Service Manual is for the T-56 Borg Warner Tremec Transmission. This six-speed overdrive transmission is used on the C5 Corvette, F-body, Dodge Viper, Ford SVT Mustang Cobra,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</guid>
										<title>1997 - 2003 Corvette: GM TechLink: Transmission Stuck in Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</link>
										<description><![CDATA[From GM TechLink, September 2003: The 1997-2003 Corvette, or 1993-2002 Camaro and Pontiac Firebird equipped with the 6 speed manual transmission may exhibit the following.Primary Condition- Unable to shift out of fourth gear.Other Conditions- 3-4...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Automatic Transmission Service Procedure Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</link>
										<description><![CDATA[Subject: Automatic Transmission Service Procedure ChangesSource: Chevrolet Dealer Technical Service BulletinNumber:&nbsp; 99-07-30-020AModels: 2002 and Prior Passenger Cars and Light Duty Trucks with Automatic TransmissionsThis bulletin is being...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
										<description><![CDATA[The fluid in the hydraulic clutch system of 1997 &ndash; 2002 Chevrolet Corvettes may appear discolored. This discoloration is the result of carbon black used in the seal manufacturing process leaching out into the hydraulic fluid used in the clutch...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Park/Neutral Position Switch Connector Cannot Be Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</link>
										<description><![CDATA[Number: 01-07-30-021Subject: Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors)Model Year: 1997-2001 Chevrolet Camaro, Corvette1997-2001 Pontiac Firebird1995-2001 Chevrolet and GMC S/T Models1996-2001 Chevrolet...]]></description>
										<description><![CDATA[Subject: MUFFLED CLATTER TYPE NOISE COMING FROM CENTER OF PASSENGER COMPARTMENT (REPLACE TRANSMISSION MOUNT ASSEMBLY)Source: Chevrolet Dealer Technical Service BulletinNumber: 83-34-07 - (03/27/1998)Models: 1997-98 CHEVROLET CORVETTE - BUILT PRIOR TO...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Automatic Transmission Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</link>
										<description><![CDATA[ Subject:  Corvette Automatic Transmission Operation  Model and Year:  1997 - 1998 Corvette   Source:  Chevrolet Service News   Page Number: NA   Date: December 1997, Volume 6, Number 12 &nbsp; There will be a change in the operation of the 1997...]]></description>
										<description><![CDATA[Subject: Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)Source: Chevrolet Dealer Technical Service BulletinNumber: 01-07-30-023BModels:1996 Buick Roadmaster1996 Cadillac Fleetwood1999-2000 Cadillac Escalade1996...]]></description>
										<description><![CDATA[Subject: No Reverse, Second Gear, or Fourth Gear (Replace the Reaction Sun Shell)Source: Chevrolet Dealer Technical Service BulletinNumber: 00-07-30-022Models: 1996 Buick Roadmaster1996 Cadillac Fleetwood1996 Caprice1996-99 Chevrolet Camaro,...]]></description>
										<description><![CDATA[Subject: No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts)Model and Year: 1993-2005 Corvette with 4L60/65-E Automatic Transmission (RPOs M30 or M32)Source: Chevrolet Dealer Sevice&nbsp...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<description><![CDATA[Number: 02-07-30-024Subject: Info - Diagnosis of Cracked or Broken Transmission Case Model Year: 1990-1993 Buick Roadmaster, Estate Wagon1990-1996 Cadillac Fleetwood1990-1996 Chevrolet Caprice1990-2002 Chevrolet Camaro1990-2003 Chevrolet Corvette1995...]]></description>
