<title>Home - All Categories - C5 Corvettes  - Chassis, Frame and Suspension  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/chassis-frame-and-suspension/34/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</guid>
										<title>Road Test: Active handling: Corvette`s revolutionary new option increases safety and performance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</link>
										<description><![CDATA[Description:Hib Halverson reviews the C5 Corvette's Active Handling system. Excerpt:"When ordered on a C5, Active Handling combines with the car's traction control system (TCS) to enhance control in maneuvers having high yaw rates. TCS (or "ASR,"; as...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</guid>
										<title>2004 Corvette: Recall: Lower Control Arm Ball Stud Washer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</link>
										<description><![CDATA[Recall Bulletin 04043 &ndash; Lower Control Arm Ball Stud Washer&nbsp;&nbsp; Date: August 2004 Subject: 04043 &ndash; Lower Control Arm Ball Stud Washer Models: 2004 Cadillac CTS, SRX and XLR 2004 Chevrolet Corvette CONDITION General Motors has...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</guid>
										<title>2003 Corvette: Technical Article: Magnetic Ride - Star Wars Meets the 50th Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</link>
										<description><![CDATA[Magnetic Ride - Star Wars Meets the 50th Car &nbsp;         by Hib Halverson,  &copy;2003 Shark Communications  no use without permission  I hit the last dip at 100 or so, on the brakes, getting ABS as the rear suspension kissed the rebound stops,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - New Vehicle Preparation for Magnetic Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</link>
										<description><![CDATA[  Subject:  Info - New Vehicle Preparation for Magnetic Selective Ride Control   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  &nbsp; #02-03-11-002 - (07/18/2002)   Models:  2003 Chevrolet Corvette with Magnetic Selective Ride...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</guid>
										<title>2003 Corvette:  Technical Article:  Magnetic Selective Ride Control - First Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</link>
										<description><![CDATA[Magnetic Selective Ride Control---First Drive by Hib Halverson,Technical Writer for Internet &amp; Print MediaCopyright 2002, Hib HalversonI finally had a chance to drive a six-speed, 50th Anniversary Corvette yesterday (Wed. 7/31) at a GM regional...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-manual-update-revised-wheel-drive-shaft-outer-joint-and-seal-replacement-and-wheel-drive-shaft-inner-joint-and-seal-replacement-procedures-446.html</guid>
										<title>2001 - 2003 Corvette: Service Manual Update: Revised Wheel Drive Shaft Outer Joint and Seal Replacement and Wheel Drive Shaft Inner Joint and Seal Replacement Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-manual-update-revised-wheel-drive-shaft-outer-joint-and-seal-replacement-and-wheel-drive-shaft-inner-joint-and-seal-replacement-procedures-446.html</link>
										<description><![CDATA[  Subject:  Revised Wheel Drive Shaft Outer Joint and Seal Replacement and Wheel Drive Shaft Inner Joint and Seal Replacement Procedures   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  &nbsp; 03-04-95-001 - (01/09/2003)   Models: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</guid>
										<title>1999 - 2000 Corvette: Service Bulletin: SMU - Deletion of Variable Effort Steering Description</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</link>
										<description><![CDATA[Source: Chevrolet Dealer Service BulletinNumber: 00-02-36-002ASubject: SMU - Deletion of Variable Effort Steering DescriptionModel Year: 1999-2000This bulletin is being revised to clarify that the Variable Effort Steering is not dealer adjustable...]]></description>
										<description><![CDATA[ Subject: Corvette Active Handling   Model and Year:  1998 Corvette with RPO JL-4  Source:  Chevrolet Pro Service News   Page Number:&nbsp;&nbsp; 1  Date:&nbsp; April 1998 - Volume 7, Number 4
]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</guid>
										<title>1998 - 2004 Corvette:  Press Release: Active Handling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</link>
										<description><![CDATA[Description:The following text appeared in a GM Press Release that was issued at the Las Vegas SEMA Show in the Fall of 1998. The Active Handling System, RPO JL4, debuted on the 1998 Corvette and became standard equipment on the 2001 model.Excerpt:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-recall-notice-rear-suspension-tie-rod-assembly-1154.html</guid>
										<title>1997 Corvette:  Recall Notice:  Rear Suspension Tie Rod Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-recall-notice-rear-suspension-tie-rod-assembly-1154.html</link>
										<description><![CDATA[ Subject:  &nbsp;&nbsp; Rear Suspension Tie Rod Assembly   Model and Year:&nbsp;  1997 Chevrolet Corvette   Source:&nbsp;&nbsp;  Product Recall Campaign / Product Safety Campaign    Bulletin No:&nbsp;  97014    Section:&nbsp;  NA    Date:&nbsp; ...]]></description>
										<description><![CDATA[#PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)    Subject:&nbsp; Composite Transverse Spring Damage   Models:&nbsp; 2004 - 2009 Cadillac XLR   1997 - 2013 Chevrolet Corvette     This PI was superseded to update model years and...]]></description>
										<description><![CDATA[Service Bulletin #: 05-03-08-004  Date: 3/31/05 Subject:&nbsp; Revised Front and Rear Upper and Lower Ball Joint Stud Nut Tightening SpecificationsRevised Front and Rear Upper and Lower Ball Joint Stud Nut Tightening Specifications Model(s): 1997 -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-technical-article-corvette-crossmember-design-and-manufacturing-797.html</guid>
										<title>1997 - 2004 Corvette: Technical Article: Corvette Crossmember Design and Manufacturing</title>
										<description><![CDATA[Description:This is an in-depth article that takes a look at the design, engineering and benefits of the C5 Corvette's frame and crossmembers. It was first published in the SAE Automotive Engineering Magazine - August 1997.Excerpt:"The new C5...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-rear-axle-assemble-procedure-and-special-tools-448.html</guid>
										<title>1997 - 2003 Corvette: Service Manual Update: Revised Rear Axle-Assemble Procedure and Special Tools</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-rear-axle-assemble-procedure-and-special-tools-448.html</link>
										<description><![CDATA[  Subject:  Service Manual Update: Revised Rear Axle-Assemble Procedure and Special Tools   Source:  Chevrolet Dealer Technical Service Bulletin   Number:  &nbsp; 03-04-20-001 - (01/29/2003)   Models:  1997-2003 Chevrolet Corvette  This bulletin is...]]></description>
