<title>Home - All Categories - C5 Corvettes  - Brakes  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c5-corvettes/brakes/33/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-incomplete-brake-pedal-return-449.html</guid>
										<title>2001 Corvette: Service Bulletin: Incomplete Brake Pedal Return</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-incomplete-brake-pedal-return-449.html</link>
										<description><![CDATA[Model Year: 2001 CorvetteSubject: Incomplete Brake Pedal Return - (Replace Vacuum Brake Booster)Source: Chevrolet Dealer Service Technical BulletinNumber: 01-05-22-002Date: April, 2001Condition:Some owners may comment that after the brake pedal is...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</guid>
										<title>2001 - 2002 Corvette: Service Bulletin: Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg.</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html</link>
										<description><![CDATA[Number: 01-05-25-004ASubject: Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg (Handling) (repair/Reprogram ABS Module)Model Year: 2001-2002 Chevrolet Corvette Built Prior to VIN Breakpoint 25106536This bulletin...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</guid>
										<title>2000 Corvette: ABS Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-abs-diagnostic-trouble-codes-229.html</link>
										<description><![CDATA[DTC/DescriptionTypeIlluminate Indicator or Turn ON DIC Message DTC B2597 Traction Control System Switch CircuitBCMNone DTC C1214 Solenoid Valve Relay Contact or Coil Circuit OpenABSABS/TCS/DIC DTC C1217 Pump Motor Relay Contact Circuit OpenABSABS/TCS...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
										<description><![CDATA[ Source:  GM Techlink    Date:  November 2010    Subject:  &nbsp;&nbsp;Aftermarket Braided Stainless Steel Brake Lines    Models:  &nbsp;1997 - 2011 Chevrolet Corvette   Aftermarket braided stainless steel brake lines installed (from the front...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</guid>
										<title>1997 - 2004 Corvette: GM TechLink: Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-gm-techlink-stainless-steel-brake-lines-451.html</link>
										<description><![CDATA[From GM TechLink, July 2004: Owners of some Corvettes have experienced Service ABS, Service Active Handling and Service Traction Control messages. Wheel speed sensor codes may be set. This condition may be caused by replacing the OEM rubber brake...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</guid>
										<title>1995 - 2002 Corvette: Service Bulletin: Warranty Admin. - Brake Rotor Warranty Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</link>
										<description><![CDATA[Number: 00-05-22-002ASubject: Brake Rotor Warranty Service ProcedureModel Year: 1995-2002 Passenger Cars and Light Duty TrucksThis bulletin is being revised to add model years, change the service category and update the information. Please discard...]]></description>
