<title>Home - All Categories - C6 Corvettes  - Tires and Wheels  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c6-corvettes/tires-and-wheels/31/</link>
										<description><![CDATA[Source:&nbsp; GM TechLink, Page 6, July 2014 The wheels on some 2010-2014 Camaro, 2005-2014 Corvette, and 2014 SS models may collect an excessive amount of brake dust. This is due to the high-performance brake pad material &mdash; one of the by...]]></description>
										<description><![CDATA[#PIT4683F: Additional Wheel Speed Sensor Diagnostics - (Jul 31, 2012)    Subject:&nbsp; Additional Wheel Speed Sensor Diagnostics   Models:&nbsp; 2008 - 2013 Buick Enclave   2007 - 2013 Cadillac Escalade, Escalade ESV, Escalade EXT 2009 Cadillac XLR ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-service-bulletin-tire-vibration-at-speeds-above-70-mph-59.html</guid>
										<title>2009 - 2011 Corvette:  Service Bulletin:  Tire Vibration at Speeds Above 70 mph</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-service-bulletin-tire-vibration-at-speeds-above-70-mph-59.html</link>
										<description><![CDATA[Document ID: 2611355-------------------------------------------------------------------------------- #PIC5202C: Tire Vibration At Speeds Above 70 MPH - (Jul 28, 2011)Subject: Tire Vibration at Speeds Above 70 MPHModels: 2009 - 2011 Chevrolet Corvette...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-tire-vibration-64.html</guid>
										<title>2009 - 2011 Corvette:  GM TechLink: Tire Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-tire-vibration-64.html</link>
										<description><![CDATA[Source: GM TechlinkDate:&nbsp;September 2010Subject:&nbsp;&nbsp;Corvette Tire VibrationModels: 2009 - 2011 Chevrolet Corvette A slight vibration in the steering wheel may be noticed on 2009-2011 Corvette models when traveling between 72 and 78 MPH ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-refinishing-aluminum-wheels-263.html</guid>
										<title>2007 Corvette:  Service Bulletin: Refinishing Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-refinishing-aluminum-wheels-263.html</link>
										<description><![CDATA[Subject:&nbsp; Refinishing Aluminum WheelsModels:&nbsp; 2007 and Prior Passenger Cars and Trucks (Including Saturn)2003 - 2007 HUMMER H22006 - 2007 HUMMER H32005 - 2007 Saab 9-7XBulletin No:&nbsp; 99-08-51-007CDate:&nbsp; June, 2006Download PDF...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-use-recommended-tire-mounting-lubricant-to-prevent-tires-from-slipping-on-chrome-wheels-268.html</guid>
										<title>2006 Corvette: Service Bulletin:  Use Recommended Tire Mounting Lubricant to Prevent Tires From Slipping on Chrome Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-use-recommended-tire-mounting-lubricant-to-prevent-tires-from-slipping-on-chrome-wheels-268.html</link>
										<description><![CDATA[Subject:&nbsp; Use Recommended Tire Mounting Lubricant to Prevent Tires From Slipping on Chrome WheelsModels:&nbsp; 2006 and Prior Passenger Cars and Light Duty Trucks (including Saturn)2006 and Prior HUMMER H22006 HUMMER H3Bulletin No:&nbsp; 05-03...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-cold-tire-characteristics-of-gm-original-equipment-tires-272.html</guid>
										<title>2006 Corvette: Service Bulletin:  Cold Tire Characteristics of GM Original Equipment Tires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-cold-tire-characteristics-of-gm-original-equipment-tires-272.html</link>
										<description><![CDATA[Attached below is a one page PDF document detailing the cold tire characteristics that may be seen on all GM original equipment tires.General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are...]]></description>
										<description><![CDATA[#17-NA-087: Characteristics of Wide Low Aspect Ratio Tires, Vehicle Pulls Left or Right, Wanders, Follows Depressions in Road Surface, Tramlining - (Oct 12, 2020)    Subject:&nbsp; Characteristics of Wide Low Aspect Ratio Tires, Vehicle Pulls Left or...]]></description>
										<description><![CDATA[#17-NA-087: Characteristics of Wide Low Aspect Ratio Tires, Vehicle Pulls Left or Right, Wanders, Follows Depressions in Road Surface, Tramlining - (Mar 21, 2017)    Subject:&nbsp; Characteristics of Wide Low Aspect Ratio Tires, Vehicle Pulls Left or...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-tire-tips-321.html</guid>
										<title>2005 - 2013 Corvette: GM TechLink: Tire Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-gm-techlink-tire-tips-321.html</link>
										<description><![CDATA[A number of General Motors' high performance models come factory equipped with tires optimized for dry road performance. As a result, the tread life characteristics of these tires may be reduced to achieve higher performance levels. Tread life of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-low-tire-pressure-leaking-cast-aluminum-wheels-196.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Low Tire Pressure, Leaking Cast Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-low-tire-pressure-leaking-cast-aluminum-wheels-196.html</link>
										<description><![CDATA[Bulletin No:&nbsp; 05-03-10-003BDate:&nbsp; April, 2006Subject:&nbsp; Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant)Models:&nbsp; 2007 and Prior GM Passenger Cars and Light Duty Trucks (including Saturn)2003-2007...]]></description>
										<description><![CDATA[Tire Mounting and DismountingThis information applies to the 2000--05 Cadillac Deville, Seville, STS, 2004--05 Cadillac CTS, Escalade, SRX, XLR, 1999--2005 Chevrolet Corvette, 2004--05 Chevrolet Tahoe, Suburban, 2004--05 GMC Yukon, Yukon XL.When...]]></description>
