<title>Home - All Categories - C6 Corvettes  - Chassis, Frame and Suspension  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c6-corvettes/chassis-frame-and-suspension/24/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-61.html</guid>
										<title>2005 - 2009 Corvette:  Service Bulletin:  Tapping or Scraping Noise From Rear Wheel Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2009-corvette-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-61.html</link>
										<description><![CDATA[ Subject:  Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut)  Models:  2005-2009 Cadillac XLR  2005-2009 Chevrolet Corvette   This bulletin is being revised to add the 2009 model year. Please discard Corporate Bulletin...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
										<description><![CDATA[Subject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710 Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007) Models:2004-2008 Cadillac...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-drive-axle-boot-pliers-100.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Drive Axle Boot Pliers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-drive-axle-boot-pliers-100.html</link>
										<description><![CDATA[New drive axle boot pliers  (fig. 6)  CH-48894 have been released for these vehicles:  2005 XLR   2005-08 Corvette, Equinox, Impala, Monte Carlo, Grand Prix, Torrent   2006-08 HHR, Hummer H3   2007 Acadia, Outlook, VUE, Rainier, Enclave   2008 VUE  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-power-steering-shudder-or-vibration-at-idle-153.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Power Steering Shudder or Vibration at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-power-steering-shudder-or-vibration-at-idle-153.html</link>
										<description><![CDATA[Date: October 18, 2006 Bulletin #:&nbsp; #06-02-32-012B Subject: Power Steering Shudder or Vibration at Idle (Replace Power Steering Inlet (Pressure) Hose)Models: 2005-2007 Chevrolet Corvette with Automatic Transmission ConditionSome customers may...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<description><![CDATA[Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid and Add Specified Limited-Slip Axle Additive) Number:&nbsp; #07-04-20-002Date:&nbsp; (04/16/2007)Models: 2004-2007 Cadillac XLR (Including V-Series and...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 06-02-35-002 Date:&nbsp;January 2006 Subject:&nbsp; Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</guid>
										<title>2005 - 2006 Corvette: Rear Wheel Drive Shaft Nut Torque Specification Requirements and Information on Replacement Shafts for Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-rear-wheel-drive-shaft-nut-torque-specification-requirements-and-information-on-replacement-shafts-for-service-317.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 05-04-95-001 Date: November 11, 2005 Subject:&nbsp; Rear Wheel Drive Shaft Nut Torque Specification Requirements and Information on Replacement Shafts for Service Model(s): 2005-2006 Chevrolet CorvetteRear Wheel Drive Shaft...]]></description>
										<description><![CDATA[#PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)    Subject:&nbsp; Composite Transverse Spring Damage   Models:&nbsp; 2004 - 2009 Cadillac XLR   1997 - 2013 Chevrolet Corvette     This PI was superseded to update model years and...]]></description>
										<description><![CDATA[Service Bulletin #: 05-03-08-004  Date: 3/31/05 Subject:&nbsp; Revised Front and Rear Upper and Lower Ball Joint Stud Nut Tightening SpecificationsRevised Front and Rear Upper and Lower Ball Joint Stud Nut Tightening Specifications Model(s): 1997 -...]]></description>
