<title>Home - All Categories - C6 Corvettes  - Brakes  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c6-corvettes/brakes/23/</link>
										<description><![CDATA[#PIC6162D: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jan 19, 2021)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use        Brand...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</guid>
										<title>2009 - 2017 Corvette: Service Bulletin: #PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
										<description><![CDATA[#PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jun 27, 2017)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use   Models:...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<description><![CDATA[Source: GM TechlinkDate: October 2010Subject:&nbsp;&nbsp;Electronic Brake Control Module CommunicationModels: 2009 - 2011 Chevrolet Corvette On some 2008-2011 Enclave; 2007-2011 Escalade, Escalade ESV, Escalade EXT, Avalanche, Silverado, Suburban,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</guid>
										<title>2006 Corvette: GM TechLink: Brake Pads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-gm-techlink-brake-pads-356.html</link>
										<description><![CDATA[Brake PadsFor 2006, a new brake pad is introduced on the Z51 Corvettes for reduced operating noise. It is quieter than the pad used in 2005.TIP: Use European specification brake pads for autocross competition. However, operating noise will be noticed...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-hydraulic-brake-line-leak-359.html</guid>
										<title>2005 Corvette: Recall: Hydraulic Brake Line Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-hydraulic-brake-line-leak-359.html</link>
										<description><![CDATA[Make : CHEVROLETModel : CORVETTEYear : 2005Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 04V525000 Recall Date : OCT 27, 2004Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGSPotential Number...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-04086-rear-brake-lining-routing-358.html</guid>
										<title>2005 Corvette: Recall: 04086 -- Rear Brake Lining Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-recall-04086-rear-brake-lining-routing-358.html</link>
										<description><![CDATA[Recall #: 04086 Date:&nbsp;n/a Subject:&nbsp; 04086 -- Rear Brake Lining Routing Model(s): 2005 Chevrolet Corvette ConditionGeneral Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2004 and 2005 model year...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</guid>
										<title>2005 Corvette: GM TechLink: Cross-Drilled Rotors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-cross-drilled-rotors-357.html</link>
										<description><![CDATA[Cross-drilled brake rotors (fig. 16 -attached) are being used on the 2005 1/2 Pontiac Grand Prix GXP, and available on the 2005 Chevrolet C6 Corvette and the upcoming Cadillac XLR-V.If required, these brake rotors can be machined on a lathe in a...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Information on Visual Brake Rotor Surface Cracking</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-information-on-visual-brake-rotor-surface-cracking-201.html</link>
										<description><![CDATA[Service Bulletin #:&nbsp; 05-05-23-007 Date:&nbsp;August 2005 Subject:&nbsp; Information on Visual Brake Rotor Surface Cracking Model(s): 2005 - 2006 Chevrolet Corvette with Heavy Duty Brakes (RPO J55) Attached below is the PDF document for this...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
										<description><![CDATA[ Source:  GM Techlink    Date:  November 2010    Subject:  &nbsp;&nbsp;Aftermarket Braided Stainless Steel Brake Lines    Models:  &nbsp;1997 - 2011 Chevrolet Corvette   Aftermarket braided stainless steel brake lines installed (from the front...]]></description>
