<title>Home - All Categories - C7 Corvettes  - Brakes  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c7-corvettes/brakes/12/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</guid>
										<title>2019 Corvette Z06:  Service Bulletin: 18096 Brake Deflector for Street Use Not Installed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-z06-service-bulletin-18096-brake-deflector-for-street-use-not-installed-1400.html</link>
										<description><![CDATA[Date:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; April 17, 2018Subject:&nbsp;&nbsp; 18096 - Customer Satisfaction ProgramModels:&nbsp;&nbsp; 2019 Chevrolet Corvette Z06To:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; All General Motors...]]></description>
										<description><![CDATA[#16-NA-363: Brake Cooling Deflectors/Ducts for J56 and J57 Brakes (Track Use Only) - (Feb 26, 2018)    Subject:&nbsp; Brake Cooling Deflectors/Ducts for J56 and J57 Brakes (Track Use Only)        Brand:  Model:  Model Year:  VIN:  Engine: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</guid>
										<title>2016 - 2017 Corvette: Service Bulletin: #17267: Service Update - Brake Wear Indicator Not Functioning Properly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17267-service-update-brake-wear-indicator-not-functioning-properly-1374.html</link>
										<description><![CDATA[#17267: Service Update - Brake Wear Indicator Not Functioning Properly - (Jun 30, 2017)    Subject:&nbsp; 17267 &mdash; Brake Wear Indicator Not Functioning Properly   Models:&nbsp; 2016 &ndash; 2017 Chevrolet Corvette   Equipped with Performance...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</guid>
										<title>2015 Corvette Z06:  GM TechLink:  Brake Pad Wear Sensor Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-z06-gm-techlink-brake-pad-wear-sensor-harness-1124.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;&nbsp;  Brake Pad Wear Sensor Harness   Model and Year:&nbsp;&nbsp;  2014 - 2015 Camaro Z/28 and 2015 Corvette Stingray Z06 models   Source:&nbsp;  GM TechLink   Page Number:  &nbsp; NA   Date:&nbsp;  January 22, 2015 A Change...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pic6061b-change-brake-pads-message-displayed-in-dic-1367.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIC6061B: Change Brake Pads - Message Displayed In DIC</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pic6061b-change-brake-pads-message-displayed-in-dic-1367.html</link>
										<description><![CDATA[#PIC6061B: Change Brake Pads - Message Displayed In DIC - (Jun 6, 2017)    Subject:&nbsp; Change Brake Pads- Message Displayed In DIC   Models:&nbsp; 2014 - 2015 Chevrolet Camaro Z/28   2015 - 2017 Chevrolet Corvette equipped with RPO J57     This PI...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-front-brake-rotor-cooling-rings-20.html</guid>
										<title>2014 Corvette: Techlink Article: Front Brake Rotor Cooling Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-front-brake-rotor-cooling-rings-20.html</link>
										<description><![CDATA[ Source:  &nbsp; GM TechLink   Date:  &nbsp; October 7, 2013 During Pre-Delivery Inspection (PDI) of the 2014 Corvette Stingray, two rings and a coil of safety wire will be found in the loose items bag. There may be some question about the purpose of...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</guid>
										<title>2014 Corvette: GM TechLink Article: Brake Noise on Initial Brake Apply</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-brake-noise-on-initial-brake-apply-10.html</link>
										<description><![CDATA[ Source:  &nbsp; GM TechLink   Date:  &nbsp; February 20, 2014 An intermittent brake squeal or squeak noise on the initial brake apply may be heard on some 2013-2014 Regal GS, ATS (equipped with RPO J55), XTS (equipped with RPO J64); 2014 CTS Sedan ...]]></description>
										<description><![CDATA[#16-NA-059: Staining/Discoloring to Brake Caliper Paint - (Oct 14, 2020)    Subject:&nbsp; Staining/Discoloring to Brake Caliper Paint        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Cadillac   ATS-V   2016 ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-17-na-239-information-on-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-1450.html</guid>
										<title>2014 - 2020 Corvette:  Service Bulletin: #17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time</title>
										<description><![CDATA[#17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time - (Oct 2, 2020)    Subject:&nbsp; Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an...]]></description>
										<description><![CDATA[#17-NA-040: Brake Squeal or Squeak Noise Intermittently on Initial Brake Applies - (August 11, 2020)    Subject:&nbsp; Brake Squeal or Squeak Noise Intermittently on Initial Brake Applies     This Bulletin replaces PI1496C and PI0917F. Please discard...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIC6083A: Normal Characteristic - Vehicle Unable To Move After Being Parked For An Extended Period Of Time - (Mar 27, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pic6083a-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-mar-27-2017-1345.html</link>
										<description><![CDATA[#PIC6083A: Normal Characteristic - Vehicle Unable To Move After Being Parked For An Extended Period Of Time - (Mar 27, 2017)    Subject:&nbsp; Normal Characteristic - Vehicle Unable To Move After Being Parked For An Extended Period Of Time       ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-170-brake-pulsation-and-or-vibration-during-brake-apply-1270.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: #16-NA-170: Brake Pulsation and/or Vibration During Brake Apply</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-170-brake-pulsation-and-or-vibration-during-brake-apply-1270.html</link>
										<description><![CDATA[#16-NA-170: Brake Pulsation and/or Vibration During Brake Apply - (July 20, 2016)     Subject  :&nbsp;  Brake Pulsation and/or Vibration During Brake Apply  &nbsp;        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-weather-conditions-effect-on-high-performance-brake-components-1199.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink: Weather Conditions` Effect on High-Performance Brake Components</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-weather-conditions-effect-on-high-performance-brake-components-1199.html</link>
										<description><![CDATA[ Subject:&nbsp;&nbsp;  Weather Conditions&rsquo; Effect on High-Performance Brake Components   Model and Year:&nbsp;&nbsp;&nbsp;&nbsp;  Some 2012&ndash;2015 Camaro SS, Camaro ZL1; 2013&ndash;2016 ATS; 2014&ndash;2016 CTS (VIN A); 2014&ndash;2015...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</guid>
										<title>2009 - 2017 Corvette: Service Bulletin: #PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2017-corvette-service-bulletin-pic6162b-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-1372.html</link>
										<description><![CDATA[#PIC6162B: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jun 27, 2017)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use   Models:...]]></description>
