<title>Home - All Categories - C8 Corvette  - Brakes  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c8-corvette/brakes/109/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6429: Addressing Customer Concerns on Brake Noises - (Jan 20, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</link>
										<description><![CDATA[#PIC6429: Addressing Customer Concerns on Brake Noises - (Jan 20, 2021)    Subject:&nbsp; Addressing Customer Concerns on Brake Noises        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Chevrolet   Corvette  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-corvette-brake-service-tips-1513.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Corvette Brake Service Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-corvette-brake-service-tips-1513.html</link>
										<description><![CDATA[The 2020 - 2021 Corvette Stingray features two brake options. RPO JL9 is the base brake system and the heavy-duty RPO J55 brake system is standard on all models with the Z51 Performance Package. (Fig. 8) The high performance brakes of the J55 system...]]></description>
										<description><![CDATA[#16-NA-059: Staining/Discoloring to Brake Caliper Paint - (Oct 14, 2020)    Subject:&nbsp; Staining/Discoloring to Brake Caliper Paint        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Cadillac   ATS-V   2016 ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-17-na-239-information-on-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-1450.html</guid>
										<title>2014 - 2020 Corvette:  Service Bulletin: #17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time</title>
										<description><![CDATA[#17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time - (Oct 2, 2020)    Subject:&nbsp; Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an...]]></description>
										<description><![CDATA[#17-NA-040: Brake Squeal or Squeak Noise Intermittently on Initial Brake Applies - (August 11, 2020)    Subject:&nbsp; Brake Squeal or Squeak Noise Intermittently on Initial Brake Applies     This Bulletin replaces PI1496C and PI0917F. Please discard...]]></description>
										<description><![CDATA[#PIC6162D: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jan 19, 2021)    Subject:&nbsp; Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use        Brand...]]></description>
