<title>Home - All Categories - C8 Corvette  - Chassis and Suspension  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c8-corvette/chassis-and-suspension/108/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<description><![CDATA[2020 Corvette: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)    Subject:&nbsp; Improved Electronic Limited Slip Differential (eLSD) Calibration        Brand:  Model:  Model Year:  Breakpoint Date: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-servicing-the-front-leveling-system-1430.html</guid>
										<title>2020 Corvette: GM TechLink: Servicing the Front Leveling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-servicing-the-front-leveling-system-1430.html</link>
										<description><![CDATA[2020 Corvette: Servicing the Front Leveling System  July 22, 2020GM TechLink There may be a Service Front Leveling System message displayed on the Driver Information Center on some 2020 Corvette models. DTC U3000 SYM49 (Control Module Internal...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6434-service-front-suspension-lift-system-message-setting-a-c103c-and-or-c103e-symptom-64-mar-23-2021-1501.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6434: Service Front Suspension Lift System Message Setting A C103C And/Or C103E Symptom 64 - (Mar 23, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6434-service-front-suspension-lift-system-message-setting-a-c103c-and-or-c103e-symptom-64-mar-23-2021-1501.html</link>
										<description><![CDATA[#PIC6434: Service Front Suspension Lift System Message Setting A C103C And/Or C103E Symptom 64 - (Mar 23, 2021)    Subject:&nbsp; Service Front Suspension Lift System Message Setting A C103C And/Or C103E Symptom 64        Brand:  Model:  Model Year: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-recall-n202321570-customer-satisfaction-program-incorrect-front-suspension-lift-reservoir-cap-export-only-mar-8-2021-1495.html</guid>
										<title>2020 - 2021 Corvette: Recall: #N202321570: Customer Satisfaction Program - Incorrect Front Suspension Lift Reservoir Cap - Export Only - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-recall-n202321570-customer-satisfaction-program-incorrect-front-suspension-lift-reservoir-cap-export-only-mar-8-2021-1495.html</link>
										<description><![CDATA[#N202321570: Customer Satisfaction Program - Incorrect Front Suspension Lift Reservoir Cap - Export Only - (Mar 8, 2021)    Subject:&nbsp; N202321570 - Incorrect Front Suspension Lift Reservoir Cap&nbsp;- Export Only   Models:&nbsp; 2020 - 2021...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-service-front-suspension-lift-system-message-1504.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Service Front Suspension Lift System Message</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-service-front-suspension-lift-system-message-1504.html</link>
										<description><![CDATA[2020 - 2021 Corvette: Service Front Suspension Lift System Message March 30, 2021  Some 2020-2021 Corvettes may display a Service Front Suspension Lift System message on the Driver Information Center (DIC). DTCs C103C (Left Front Strut Position...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-19-na-046-information-on-electronic-limited-slip-differential-elsd-operation-and-driver-information-center-1458.html</guid>
										<title>2014 - 2020 Corvette: Service Bulletin: #19-NA-046: Information on Electronic Limited Slip Differential (eLSD) Operation and Driver Information Center</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-19-na-046-information-on-electronic-limited-slip-differential-elsd-operation-and-driver-information-center-1458.html</link>
										<description><![CDATA[#19-NA-046: Information on Electronic Limited Slip Differential (eLSD) Operation and Driver Information Center (DIC) Wheel Slip Screen - (Oct 13, 2020)    Subject:&nbsp; Information on Electronic Limited Slip Differential (eLSD) Operation and Driver...]]></description>
