<title>Home - All Categories - C8 Corvette  - Transmission - Dual Clutch  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c8-corvette/transmission-dual-clutch/105/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</guid>
										<title>2020 Corvette: GM TechLink: 2020 Corvette Stingray Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</link>
										<description><![CDATA[2020 Corvette Stingray Powertrain March 31, 2020 GM TechLink The all-new 2020 Corvette Stingray delivers exceptional performance through a combination of rear weight bias, aerodynamics, chassis tuning and its new mid-engine small block V8 and 8-speed...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-corvette-transmission-external-canister-filter-and-maintenance-update-labor-code-added-1527.html</guid>
										<title>2020 - 2024 Corvette: Corvette Transmission External Canister Filter and Maintenance Update, Labor Code Added</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-corvette-transmission-external-canister-filter-and-maintenance-update-labor-code-added-1527.html</link>
										<description><![CDATA[July 23, 2024 The Tremec DCT TR9080 dual clutch transmission (RPO M1L, M1M) on 2020-2024 Corvettes features an external canister filter that should be replaced at the initial 7,500-mile (12,000-km) maintenance service. After the initial service, the...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2024-corvette-z06-service-bulletin-n232413030-service-update-lack-of-auto-park-function-mar-25-2024-1523.html</guid>
										<title>2024 Corvette Z06: Service Bulletin: #N232413030: Service Update - Lack of Auto Park Function - (Mar 25, 2024)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2024-corvette-z06-service-bulletin-n232413030-service-update-lack-of-auto-park-function-mar-25-2024-1523.html</link>
										<description><![CDATA[#N232413030: Service Update - Lack of Auto Park Function - (Mar 25, 2024)    Subject:&nbsp; N232413030 &mdash; Lack of Auto Park Function &nbsp;   Models:&nbsp; 2024 Chevrolet Corvette         Release Date:  March 2024   Revision:  00     &nbsp;    ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709g-dual-clutch-transmission-part-restriction-dec-1-2020-1476.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5709G: Dual Clutch Transmission Part Restriction - (Dec 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709g-dual-clutch-transmission-part-restriction-dec-1-2020-1476.html</link>
										<description><![CDATA[2020 Corvette: #PIP5709G: Dual Clutch Transmission Part Restriction - (Dec 1, 2020)    Subject:&nbsp; Dual Clutch Transmission Part Restriction        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Chevrolet  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709c-dual-clutch-transmission-exchange-program-aug-28-2020-1439.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5709C: Dual Clutch Transmission Exchange Program - (Aug 28, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709c-dual-clutch-transmission-exchange-program-aug-28-2020-1439.html</link>
										<description><![CDATA[2020 Corvette: #PIP5709C: Dual Clutch Transmission Exchange Program - (Aug 28, 2020)    Subject:&nbsp; Dual Clutch Transmission Part Restriction &nbsp;        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to     ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202316880-service-update-transmission-control-module-tcm-software-error-mismatch-nov-12-2020-1471.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202316880: Service Update - Transmission Control Module (TCM) Software Error/Mismatch - (Nov 12, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202316880-service-update-transmission-control-module-tcm-software-error-mismatch-nov-12-2020-1471.html</link>
										<description><![CDATA[#N202316880: Service Update - Transmission Control Module (TCM) Software Error/Mismatch - (Nov 12, 2020)    Subject:&nbsp; N202316880 &mdash; Transmission Control Module (TCM) Software Error/Mismatch   Models:&nbsp; 2020 Chevrolet Corvette        ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-noise-from-the-transmission-area-1528.html</guid>
										<title>2020 - 2024 Corvette: Noise From the Transmission Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-noise-from-the-transmission-area-1528.html</link>
										<description><![CDATA[July 23, 2024 There may be a noise from the bell housing area of the DCT TR9080 transmission (RPO M1L, M1M) on some 2020-2024 Corvettes along with a number of DTCs set in the Transmission Control Module (TCM). The noise may be due to a dislodged snap...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5797-m1l-internal-transmission-faults-related-to-components-not-serviceable-at-the-dealer-level-mar-30-2021-1503.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIP5797: M1L Internal Transmission Faults Related To Components Not Serviceable At The Dealer Level - (Mar 30, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5797-m1l-internal-transmission-faults-related-to-components-not-serviceable-at-the-dealer-level-mar-30-2021-1503.html</link>
										<description><![CDATA[#PIP5797: M1L Internal Transmission Faults Related To Components Not Serviceable At The Dealer Level - (Mar 30, 2021)    Subject:&nbsp; M1L Internal Transmission Faults Related To Components Not Serviceable At The Dealer Level        Brand:  Model: ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5709j-dual-clutch-transmission-part-restriction-jan-27-2021-1487.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIP5709J: Dual Clutch Transmission Part Restriction - (Jan 27, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5709j-dual-clutch-transmission-part-restriction-jan-27-2021-1487.html</link>
										<description><![CDATA[#PIP5709J: Dual Clutch Transmission Part Restriction - (Jan 27, 2021)    Subject:&nbsp; Dual Clutch Transmission Part Restriction        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Chevrolet   Corvette   2020 -...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-multiple-transmission-dtcs-set-1492.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Multiple Transmission DTCs Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-multiple-transmission-dtcs-set-1492.html</link>
										<description><![CDATA[March 1, 2021 GM TechLink Some 2020 - 2021 Corvette models may have multiple DTCs set in the Transmission Control Module (TCM). The DTCs may be caused by an internal transmission solenoid or switch sticking due to debris in the DCT TR-9080...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-internal-transmission-faults-not-serviceable-at-the-dealership-1508.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Internal Transmission Faults Not Serviceable at the Dealership</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-internal-transmission-faults-not-serviceable-at-the-dealership-1508.html</link>
										<description><![CDATA[Internal Transmission Faults Not Serviceable at the Dealership April 13, 2021 GM TechLink A Service Transmission message or a Service Engine Soon message may be displayed on the Driver Information Center of some 2020-2021 Corvettes equipped with the...]]></description>
