<title>Home - All Categories - C8 Corvette  - Engine - Drivetrain  </title>
<link>https://www.corvetteactioncenter.com/tech/knowledgebase/category/c8-corvette/engine-drivetrain/104/</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</guid>
										<title>2020 Corvette: GM TechLink: 2020 Corvette Stingray Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</link>
										<description><![CDATA[2020 Corvette Stingray Powertrain March 31, 2020 GM TechLink The all-new 2020 Corvette Stingray delivers exceptional performance through a combination of rear weight bias, aerodynamics, chassis tuning and its new mid-engine small block V8 and 8-speed...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-update-n202319660-service-update-valve-spring-failure-nov-20-2020-1472.html</guid>
										<title>2020 Corvette: Service Update: #N202319660: Service Update - Valve Spring Failure - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-update-n202319660-service-update-valve-spring-failure-nov-20-2020-1472.html</link>
										<description><![CDATA[#N202319660: Service Update - Valve Spring Failure - (Nov 20, 2020)    Subject:&nbsp; N202319660 &mdash; Valve Spring Failure   Models:&nbsp; 2021 Cadillac Escalade (RPO L87)   2021 Chevrolet Camaro (RPO LT1/LT4)   2020 Chevrolet Corvette (RPO LT2)  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-179-malfunction-indicator-lamp-mil-illuminated-dtcs-p0521-and-or-p06dd-set-oct-23-2020-1463.html</guid>
										<title>2020 Corvette: Service Bulletin:: #20-NA-179: Malfunction Indicator Lamp (MIL) Illuminated - DTCs P0521 and/or P06DD Set - (Oct 23, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-179-malfunction-indicator-lamp-mil-illuminated-dtcs-p0521-and-or-p06dd-set-oct-23-2020-1463.html</link>
										<description><![CDATA[#20-NA-179: Malfunction Indicator Lamp (MIL) Illuminated - DTCs P0521 and/or P06DD Set - (Oct 23, 2020)    Subject:&nbsp; Malfunction Indicator Lamp (MIL) Illuminated &ndash; DTCs P0521 and/or P06DD Set        Brand:  Model:  Model Year:  VIN...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752M: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jun 1, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</link>
										<description><![CDATA[#PIP5752M: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jun 1, 2021)    Subject:&nbsp; Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752g-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-nov-20-2020-1474.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752G: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752g-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-nov-20-2020-1474.html</link>
										<description><![CDATA[#PIP5752G: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Nov 20, 2020)    Subject:&nbsp; Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752F: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Oct 28, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html</link>
										<description><![CDATA[#PIP5752F: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Oct 28, 2020)    Subject:&nbsp; Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752a-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-sep-22-2020-1441.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752A: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - (Sep 22, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752a-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-sep-22-2020-1441.html</link>
										<description><![CDATA[#PIP5752A: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - (Sep 22, 2020)    Subject:&nbsp; Service Engine Light misfire engine noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</link>
										<description><![CDATA[#20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)    Subject:&nbsp; Engine Overheats or Coolant Leak Under Rear of Vehicle        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to     ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</guid>
										<title>2020 Corvette: GM TechLink: Rushing Air Sound in PCV Tube</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</link>
										<description><![CDATA[2020 Corvette: Rushing Air Sound in PCV Tube GM TechLink May 21, 2020 Some 2020 Corvette models may have a rushing air or hissing sound coming from the engine compartment during normal engine operation. The hiss or vacuum leak sound is at the foul...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-misfire-and-engine-noise-condition-1467.html</guid>
										<title>2020 Corvette: GM TechLink: Misfire and Engine Noise Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-misfire-and-engine-noise-condition-1467.html</link>
										<description><![CDATA[2020 Corvette: Misfire and Engine Noise Condition October 28, 2020 Some 2020 Silverado, Sierra; 2020-2021 Camaro; 2021 Corvette, Tahoe, Suburban, Yukon, and Escalade models equipped with the 5.3L engine (RPOs L82, L84), 6.2L engine (RPOs L87, LT1,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-loose-carbon-patch-in-air-cleaner-housing-1416.html</guid>
										<title>2020 Corvette: GM TechLink: Loose Carbon Patch in Air Cleaner Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-loose-carbon-patch-in-air-cleaner-housing-1416.html</link>
										<description><![CDATA[2020 Corvette: Loose Carbon Patch in Air Cleaner Housing GM TechLink April 30, 2020 A loose carbon patch in the air cleaner housing may be restricting air flow across the Mass Airflow (MAF) sensor on some 2020 Corvette models. (Fig. 11) DTCs P0101 ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-cooling-system-draining-and-filling-tips-1429.html</guid>
										<title>2020 Corvette: GM TechLink: Corvette Cooling System Draining and Filling Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-cooling-system-draining-and-filling-tips-1429.html</link>
										<description><![CDATA[Corvette Cooling System Draining and Filling Tips July 22, 2020GM TechLink The cooling system of the 6.2L V8 engine (RPO LT2) on the 2020 Corvette (Fig. 1) is designed to help maintain engine performance under extreme track environments. When filling...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</guid>
										<title>2020 Corvette: #PIP5733B: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</link>
										<description><![CDATA[#PIP5733B: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History - (Aug 6, 2020)    Subject:&nbsp; Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History &nbsp;        Brand:  Model:  Model...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752h-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jan-20-2021-1485.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752H: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jan 20, 2021)</title>
										<description><![CDATA[#PIP5752H: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jan 20, 2021)    Subject:&nbsp; Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752B: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - Possible Valve Stem - (Oct 13, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</link>
										<description><![CDATA[#PIP5752B: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - (Oct 13, 2020)    Subject:&nbsp; Service Engine Light misfire engine noise With DTC P0300 P0106 P0506        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5715b-rough-idle-with-misfire-counts-on-random-cylinders-feb-15-2021-1491.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIP5715B: Rough Idle With Misfire Counts On Random Cylinders - (Feb 15, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5715b-rough-idle-with-misfire-counts-on-random-cylinders-feb-15-2021-1491.html</link>
										<description><![CDATA[#PIP5715B: Rough Idle With Misfire Counts On Random Cylinders - (Feb 15, 2021)    Subject:&nbsp; Rough Idle With Misfire counts On Random Cylinders        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to      Chevrolet  ...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-may-5-2021-1511.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set - (May 5, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-may-5-2021-1511.html</link>
										<description><![CDATA[#20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set - (May 5, 2021)    Subject:&nbsp; Fuel Gauge May Intermittently Display Erratic and/or Empty Readings,...]]></description>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</guid>
										<title>2019 - 2024 Corvette: Crankshaft Bearing Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</link>
										<description><![CDATA[March 21, 2024 A growling, knocking or rhythmic thumping sound may be heard on some 4.3L engines (RPO LV3), 5.3L engines (RPO L82, L84) and 6.2L engines (RPO L87, LT1, LT2, LT4, L8T) on some 2019-2024 Camaro, Corvette, Silverado 1500, Sierra 1500;...]]></description>
										<description><![CDATA[#19-NA-218: Ticking Noise from the Engine - (Dec 16, 2020)    Subject:&nbsp; Ticking Noise from the Engine     This bulletin replaces PIP5606E. Please discard PIP5606E.     Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from ...]]></description>
										<description><![CDATA[#19-NA-218: Ticking Noise from the Engine - (Dec 1, 2020)    Subject:&nbsp; Ticking Noise from the Engine     This bulletin replaces PIP5606E. Please discard PIP5606E.     Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to  from  to...]]></description>
										<description><![CDATA[#17-NA-078: Information on Corvette and Camaro Exhaust Tone During Wide Open Throttle While in Sport or Track Modes - (Sep 18, 2020)    Subject:&nbsp; Information on Corvette and Camaro Exhaust Tone During Wide Open Throttle While in Sport or Track...]]></description>
										<description><![CDATA[#20-NA-038: Information on Active Fuel Management (AFM) and Dynamic Fuel Management (DFM) Usage - (Apr 8, 2021)    Subject:&nbsp; Information on Active Fuel Management (AFM) and Dynamic Fuel Management (DFM) Usage     This bulletin replaces PIP5663....]]></description>
										<description><![CDATA[#PIP5212C: Concern Of An Engine Thermostat Tick Noise And/Or Running Hot - (Mar 30, 2021)    Subject:&nbsp; Concern Of An Engine Thermostat Tick Noise And/Or Running Hot        Brand:  Model:  Model Year:  VIN:  Engine:  Transmission:   from  to ...]]></description>
