2016 Corvette: Service Bulletin: Heated and Ventilated Front Seats Inoperative with Remote Start
GM Bulletin No.:  37030
Date:  April 2016
SUBJECT: Service Update for Inventory and Customer Vehicles
Expires with Base Warranty
MODELS: 2016 Chevrolet Corvette
Equipped with Automatic Transmission (RPO M5U) and Heated and Ventilated Front Seats (RPO KQV)
PURPOSE
This bulletin provides a service procedure to reprogram the body control module on certain 2016 model year Chevrolet Corvette vehicles equipped with an automatic transmission (RPO M5U) and heated and ventilated front seats (RPO KQV). While the engine is running during a remote start, and the remote start heated and ventilated seat feature is turned on in the vehicle personalization menu, the heated and ventilated seats may not activate.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer inventory and customer vehicles that return to the dealer for any type of service during the New Vehicle Limited Warranty coverage period.
VEHICLES INVOLVED
All involved vehicles are identified by VIN in the Global Warranty Management System – Investigate Vehicle History Application. Dealership technicians should always check this site to confirm vehicle involvement prior to beginning any required inspections and/or repairs. It is important to routinely use this tool to verify eligibility because not all similar vehicles may be involved regardless of description or option content.
Additionally, a list of involved vehicles currently in dealer inventory can be found in GlobalConnect, under Departments, Service, Field Action Inventory Reports (US) or attached to the GlobalConnect message (Canada) used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's base warranty should also be checked for vehicle eligibility.
PART INFORMATION
No parts are required for this repair.
Complete bulletin is attached below:
0 (0)
Article Rating (No Votes)
Rate this article
Attached Files (1)
Comments
There are no comments for this article. Be the first to post a comment.
Name
Email
Security Code Security Code
Related Articles RSS Feed
2016 Corvette: Service Update - Performance Timer Missing
Viewed 1077 times since Tue, Apr 19, 2016
2017 Corvette: Service Bulletin: #17-NA-327: Information for Dead Battery
Viewed 1113 times since Thu, Oct 19, 2017
2014 - 2016 Corvette: Service Bulletin: #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 29, 2016)
Viewed 886 times since Thu, Jun 30, 2016
2014 Corvette: GM TechLink Article: Blank Touch Screen after Start-up and in Reverse
Viewed 4142 times since Mon, Jun 30, 2014
2015 - 2016 Corvette: Service Bulletin: #16-NA-107: DTC U0184 Set, Radio Inoperative, Blue Screen, AM Clipping Noise, HD On/Off Status Not Retained in Stations, Time Lag on Transitions, No Audio with Internal Amp, Park Assist Symbol Position Wrong i
Viewed 865 times since Thu, Sep 15, 2016
2016 - 2017 Corvette: Service Bulletin: Intermittent Loss of Rear Camera Gridlines and/or Service Rear Vision System Message
Viewed 1533 times since Thu, Sep 29, 2016
2014 Corvette: GM TechLink Article: Corvette Driver Mode Control
Viewed 4507 times since Mon, Jun 30, 2014
2016 - 2017 Corvette: Service Bulletin: #17-NA-025: Repeated Radio/display Resets, Volume Control Inoperative, Waiting for Update Media Message, Voice Command For Calling Bluetooth Phone Contacts Inoperative, Service Rear Vision System Message, Radi
Viewed 1715 times since Tue, Mar 14, 2017
2014 Corvette: GM TechLink Article: Power Memory Seat Operation
Viewed 3877 times since Mon, Jun 30, 2014
2014 - 2015 Corvette: GM TechLink: Aftermarket Equipment Connected to Multi-Media/Auxiliary Ports during Diagnosis
Viewed 1548 times since Mon, Mar 16, 2015
