2015 - 2017 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle
#16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle - (Apr 6, 2017)
Subject Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS
2016
2017
Automatic 8L45, 8L90 (M5T, M5N, M5U, M5X)
CTS Models
CT6
Escalade Models
2015
Chevrolet
Camaro
2016
2017
2017
Silverado
GMC
Sierra
2015
2017
Automatic 8L90 (M5U, M5X)
Yukon
Involved Region or Country
North America and N.A. Export Regions
Condition
Some customers may comment that the transmission exhibits a harsh 1-2 shift on the first shift of the day, typically under light throttle.
Cause
This condition is due to the initial clutch fill time of the 2-3-4-6-8 (C4) clutch.
Information
Some customers may experience a flare condition on the first 1-2 shift of the day or after the vehicle has been parked for several hours. The condition may have developed after the replacement of a complete transmission assembly or the replacement of the stator support to correct a delayed engagement condition. This is most likely to occur under light throttle conditions. Subsequent 1-2 shifts have acceptable shift feel. Replacing transmission components will not correct the condition.
Correction
Important: Replacing transmission components or complete assemblies will not improve the condition.
The first 1-2 shift of the day may be harsh. The customers’ vehicle should be compared to a like vehicle under the same driving conditions. Do Not replace any parts for this condition.
Note: This condition will not impact the designed performance or reliability of the vehicle.
Version
3
Modified
Nov. 18, 2016 - Revised the Cause section.
April 6, 2017 - Added models and Revised the Condition, Cause and Correction sections.
0 (0)
Article Rating (No Votes)
Rate this article
There are no attachments for this article.
Comments
There are no comments for this article. Be the first to post a comment.
Name
Email
Security Code Security Code
Related Articles RSS Feed
2017 Corvette Z06 and Grand Sport: Service Bulletin: #PIP5500: Whine growl noise cold (below 40*F/4*C)
Viewed 1047 times since Mon, Jun 12, 2017
2016 - 2017 Corvette: Service Bulletin: #PIP5447B: P3400 setting with 8 speed only - (Apr 4, 2017)
Viewed 926 times since Thu, Apr 6, 2017
2017 Corvette: Service Bulletin: #16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated
Viewed 1306 times since Sat, Apr 8, 2017
2014 Corvette: Techlink Article: Corvette Driveline Support Alignment
Viewed 1876 times since Tue, Jul 1, 2014
2015 Corvette: GM Press Release: New 8-Speed Enables Quicker, More Efficient Corvette
Viewed 1389 times since Wed, Aug 20, 2014
2015 - 2017 Corvette: Service Bulletin: #PIP5437B: 8L45 8L90 Diagnostic Tips for Harsh Shifts and Delayed or Harsh Garage Shift Engagements
Viewed 1930 times since Fri, May 26, 2017
2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill
Viewed 1604 times since Tue, Jul 4, 2017
2015 Corvette: GM TechLink: Reprogramming Procedures for the 8L90 8-Speed Transmission
Viewed 3781 times since Tue, Apr 14, 2015
C7 Corvette: Service Information: Transmission Control Lever Knob Replacement
Viewed 1202 times since Fri, Aug 5, 2016
2015 - 2017 Corvette: GM TechLink: Diagnostic Tips for Harsh Shifting Transmission Conditions
Viewed 1691 times since Thu, Aug 24, 2017
