2014 - 2017 Corvette: Service Bulletin: #PIP5179C: Extended Crank Cold With DI (Direct Injected) Engines - (Apr 5, 2017)
Subject Extended Crank Cold With DI (Direct Injected) Engines
Models 2016–2017 Chevrolet Camaro
2016–2017 Cadillac CTS-V
2015-2017 Cadillac Escalade
2014-2017 Chevrolet Corvette
2014-2017 Chevrolet Silverado 1500 Suburban, Tahoe
2014-2017 GMC Sierra 1500 Yukon
with engines 4.3L, 5.3L, 6.2L RPO's LV3, L83, L86, LT1, LT4
This PI was superseded to update Model Years. Please discard PIP5179B.
Condition/Concern
DI (Direct Injected) Engines with concerns of extended or long crank time during cold ambient airtemps
Recommendation/Instructions
Direct Injection engines may have slightly longer cold crank times than that of port fuel engines.
Direct Injection systems run at higher pressures, and the mechanical pump on the engine must buildup the required pressure before the first injection event occurs.
The below are typical Direct Injection engine crank times on GASOLINE
Start up Coolant Temperature Crank Time
Above 10° C up to 1.5 sec
Between 10°c (50F) and (- 10°c 14F) up to 2.5 sec
Between (-10°c 14F) and (-20°c -4F) up to 3.5 sec
Between (-20°c -4F) and (-25°c -13F) up to 5 sec
Between (-25°c -13F) and (-30°c -22F) up to 7 sec
Below -30 deg. C -22F, the recommendation is to perform an assisted start (such as use of a blockheater).
Note: For ETHANOL fuel see #PIP5174: Extended Engine Crank Times When Using E85
0 (0)
Article Rating (No Votes)
Rate this article
There are no attachments for this article.
Comments
There are no comments for this article. Be the first to post a comment.
Name
Email
Security Code Security Code
