2005 Corvette: Service Bulletin: Check Gauges Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Crankshaft Balancer and Washer from WPC)
Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Crankshaft Balancer and Washer from WPC)
Bulletin Number:  05-06-01-001B
2005 Chevrolet Corvette with 6.0L Engine (VIN U - RPO LS2)
Built Prior to VIN Breakpoint 55111039
Condition
Some customers may comment on the Check Gages Light or the Battery Voltage Low indicator coming on. Additionally, some customers may comment on the accessory drive belt either slipping or being missing.
Cause
The crankshaft balancer bolt may have become loose.
Correction
Install a new crankshaft balancer pulley, washer and a new balancer pulley bolt using the following procedure.
Parts Information
Part Number: 12557840
Bolt, Crankshaft Harmonic Balancer
Quantity: 1
Part Number: 12598247
Washer, Crankshaft Balancer
Quantity: 1
Part #: 12583637
Balancer, Crankshaft Harmonic
Quantity: 1
0 (0)
Article Rating (No Votes)
Rate this article
There are no attachments for this article.
Comments
There are no comments for this article. Be the first to post a comment.
Name
Email
Security Code Security Code
