1984 - 1996 Corvette: Re-Dyeing Seats
Title:  Re-Dyeing Leather Seats
Posted:  11-16-06
I wanted to show you the job I just finished on my seats. My 1994 sport seats were, like nearly everyone's, showing wear. Particularly in the drivers seat and back bolster area. I did quite a bit of research and reading before I decided to try this. I can say that it turned out to be a much easier job than I was expecting (so far). I did most of the research on Leatherique.com and bought my products from them as well. The process that they preach works very well. The leather in my 94 was getting kind of hard and "cardboardish". The "Rejuvenator Oil" (two applications) took care of that. They leather is now soft and supple. Then the bolster areas were rubbed, in spots, down to raw leather. Thank goodness they weren't ripped or torn, this would have made the job much more difficult. Below are some before and after pictures. Now mind you, the "prepping process" makes the seats actually look better than they did before the process, but the leather now looks new. Let me know what you think. The seats must now dry/cure for 48 hours, so i will reinstall them in the car sometime this weekend.
The drivers side seat bolster before (the flash, I guess, makes it look better than it really did)
Drivers side seat ( originally had an orange streak through the center, doesn't show up in picture)
The bolster after re-dyeing.
Seat bottom after re-dye.
Another shot of the seat back after re-dye.
DISCLAIMER:   This How-To article contains information from other Corvette owners and enthusiasts that are members of the Corvette Action Center forums. Any information used from this How-To section is used at your own risk. Although we do our best to screen and verify the information provided here, the Corvette Action Center is not responsible for any inaccuracy in this How-To section. Always consult your service manual and/or a qualified automotive service technician before conducting any type of automotive repairs or modifications on your own. For further information, please review our Legal Disclaimer .
0 (0)
Article Rating (No Votes)
Rate this article
There are no attachments for this article.
Comments
There are no comments for this article. Be the first to post a comment.
Name
Email
Security Code Security Code
Related Articles RSS Feed
1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years
Viewed 2300 times since Wed, Aug 6, 2014
1985 - 1991 Corvette: L-98 Engine Start Sequence
Viewed 2506 times since Tue, Aug 5, 2014
1984 Corvette: Increasing Instrument Cluster Illumination
Viewed 2191 times since Tue, Aug 5, 2014
1995 Corvette: Replacing Rear Wheel Bearings
Viewed 1166 times since Tue, Aug 5, 2014
1993 Corvette: Air Filter Replacement
Viewed 1305 times since Tue, Aug 5, 2014
1990 - 1996 Corvette: Fixing Erratic Digital Display
Viewed 2752 times since Tue, Aug 5, 2014
